It is currently Sat Jul 26, 2025 9:10 am
 Post subject: Gold Gotoh tuner trouble
PostPosted: Sat Mar 06, 2021 8:17 am
First name: Cas
Hiya,
Just getting round to installing some Gotoh Baby 510s, but the gold plating seems too thick. If you try to twist the nuts in, it just sounds like they are going to cross-thread.
Not come across this before on a decent make of tuners, anyone know of any good remedies?
PostPosted: Sat Mar 06, 2021 9:06 am
I assume you mean Mini's? Also - use the model number. 510 is the series.
PostPosted: Sat Mar 06, 2021 5:44 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
I've sold Grover tuners for over 30 years and I've seen that issue a number of times. If it is just 1 bushing, sometimes you can bevel the end on a sander and that will fix the issue. If it is the actual housing thread, your supplier should replace it no problem.-Bob
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
These users thanked the author Pegasusguitars for the post: Pmaj7 (Sat Mar 06, 2021 8:48 pm)
PostPosted: Sun Mar 07, 2021 12:09 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
If you can thread it in at all, you can put some rubbing compound on the threads and turn it back and forth several times to lap the threads. This should loosen it up a little. Then clean the threads of all compound and apply a bit of machine oil.
Sent from my SM-G950U1 using Tapatalk
