It is currently Sat Aug 16, 2025 11:15 pm
 Post subject: Show your butt joints?
PostPosted: Tue Nov 09, 2021 8:34 pm
Hey so I joined this forum to gain knowledge in the art of lutherie particularly Gypsy Jazz style guitars. I have found much valuable info on the Selmer style Gypsy instruments and interpretations of. One thing I stumbled upon during my search on olf and viewing different neck joint discussions I keep stumbling upon folks referring to using a butt joint to fasten the neck? I mean no offense but am I understanding this correctly? Could I possibly see some pics of this and how you are doing it? How does this hold up in your opinion?
PostPosted: Tue Nov 09, 2021 8:48 pm
the neck wasnt butt jointed according to the plans
PostPosted: Tue Nov 09, 2021 9:56 pm
Here's how I do mine, two stainless steel inserts embedded in the heel of the neck, no dowel, which a lot of people do with inserts. You can also use hangar bolts, but I prefer 1/4-20 furniture bolts.
No mortise or tenon involved. Plenty strong enough, plenty out in the world without issue. I glue down the extension with a tiny bead of titebond around the very edge.Image
These users thanked the author meddlingfool for the post (total 3): bcombs510 (Wed Nov 10, 2021 4:13 pm) • Robbie_McD (Wed Nov 10, 2021 10:16 am) • Slim (Tue Nov 09, 2021 10:54 pm)
PostPosted: Tue Nov 09, 2021 10:47 pm
Yeah thank you sir sorry for the confusion but I didn’t mean to insinuate I was considering a butt joint for a Selmer but just that I had discovered much talk about them in various places on the forum. I had never seen a butt joint used on a neck.
PostPosted: Tue Nov 09, 2021 10:54 pm
Meddlingfool thanks for the pic! Hey it’s looks like you route out a small pocket out where the tenon might would go am I seeing this correctly? Do you have a shallow mortise on the block?
PostPosted: Wed Nov 10, 2021 1:20 am
Yes, most neck joints don’t touch all the way across the part that touches the body.
Only the edges of the heel need to connect…
PostPosted: Wed Nov 10, 2021 4:08 pm
Did something happen to the picture? It's showing as a broken link for me.
PostPosted: Wed Nov 10, 2021 4:26 pm
Pic works for me
PostPosted: Wed Nov 10, 2021 4:33 pm
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Pic is gone here
Hutch
PostPosted: Wed Nov 10, 2021 5:43 pm
I’m using Tapatalk
PostPosted: Wed Nov 10, 2021 8:56 pm
Seen this fellow and he seems interesting but he shows his butt joint at the end. Looks like he cut its flush with neck angle built in the adds a couple of recessed cut to glue in hardwood strips to strengthen the are for inserts. https://youtu.be/eRAIkjaoRXo
PostPosted: Sat Nov 13, 2021 9:32 am
First name: R.M.
Last Name: Mottola
Here is another view of a joint similar to the one meddlingfool posted above. The neck shaft and heel are fully carved but there is no heel cap, so you can see the end of the channel in the body contact surface of the heel. Also visible is the end of a reinforcing dowel glued into the heel.
I use this joint often in my instruments. It is modeled after one used by Godin/Seagull, but most I have seen are very similar. This joint is featured in my book Building the Steel String Acoustic Guitar, because it is ideal for lutherie novices. It is very easy to fit the neck to the body when this joint is used. With some simple special-purpose neck fitting sanding boards, adjusting yaw and pitch is practically mindless. Construction of these boards is described in the book and also in my American Lutherie article "Aligning the Bolt-on Butt Neck Joint" (American Lutherie #126, 2016, p. 52). I'll see if I can dig up a photo.
BTW neck joints of this type generally require access to the bolts through the soundhole. A small mouth Selmer-style guitar may present a problem.
These users thanked the author rmmottola for the post (total 3): JimWomack (Mon Nov 15, 2021 8:55 am) • James Orr (Mon Nov 15, 2021 12:15 am) • Slim (Sat Nov 13, 2021 8:50 pm)
PostPosted: Sat Nov 13, 2021 11:23 am
I'm by far not the first, but I have done a number of archtops with bolt-on necks using a a long piece of hex bar and a socket and hex wrench on the end while reaching through the jack/endpin hole.
PostPosted: Sat Nov 13, 2021 12:14 pm
Assuming you are using hex bar the same size as the hex bolt? Where do you find something like that?
Was thinking to do a neck reset on a cheaper archtop, and just cutting it off and making it a bolt on might be the best way to go...
PostPosted: Sat Nov 13, 2021 1:50 pm
It's 1/4" x 24" hex bar but I took the socket piece off of one of those screwdriver thingies with a socket on the end for hex bits as the hex bit for the furniture bolts I use are smaller than 1/4". The socket is hammered on to the end of the bar with a drop of epoxy. It's a nice, thin walled socket so easily fits through the jack hole. If it's a regular endpin sized hole, you would have to come up with another solution. Perhaps a thinner hardened rod and a modified socket that could be put on to the rod through an F hole. I just use a 1/4" ratchet on the end of it for screwing in the bolts. I bought the bar at a Metal Superstore near me.
These users thanked the author Darrel Friesen for the post: Pmaj7 (Sat Nov 13, 2021 2:01 pm)
PostPosted: Sat Nov 13, 2021 8:58 pm
Thanks Rmmotolla for that awesome pic and your information that’s good stuff. I don’t think I will try that on the Selmer I probably will go with the usual m/t but will definitely give it a shot on something in the future.
PostPosted: Sun Nov 14, 2021 9:01 am
I use a variation of a Johann G. Stauffer (1778 -1853) butt joint design for my "travel" guitars. It uses a metal plate reinforcement in the neck heel and a T nut in the neck block. A small diameter socket head cap screw holds the neck to the body. I use a recess in the neck block, which along with a couple of alignment pins holds the neck in position.
This system allows the action to be adjusted with the twist of an Alan wrench, to suit a player's playing style or seasonal variations of humidity, as well as making the neck removable to store inside the body.
PostPosted: Sun Nov 14, 2021 8:27 pm
Wow Clay S and the neck store’s away in the body?
PostPosted: Sun Nov 14, 2021 10:21 pm
Since it is a travel guitar I wanted to make as compact a package as reasonable for transporting it. I still wanted it to be a full sized guitar with a normal sound and playability when assembled. Storing the neck inside the body seemed like a good way to accomplish this. To keep the neck from flopping around the peghead slips into a recess in the neck block, and the bolt that normally holds the neck on is reversed and screws into the tail block (previous photos). The screw that holds the tail port cover in place incorporates a strap button.
I've used this design to build various models - dreadnought, OM, OOO-12fret, OO-12 fret, and my favorite - size 1. I also built a travel harp (contra) guitar, but I'm not sure it would fly with the airlines for the overhead.
Most of the design elements have been used before (bolt on butt joint neck, tail port, pinless bridge) I just combined them for this design. I've made minor refinements over the years, but the basic concept has remained the same.
With the neck locked down inside the body the guitar can be put in a gig bag and the neck of the bag folded over and pinned to the body of the bag as carry on luggage.
Neck block:
These users thanked the author Clay S. for the post: Slim (Sun Nov 14, 2021 10:44 pm)
Users browsing this forum: guitarjtb and 15 guests
