It is currently Fri Jul 25, 2025 4:48 am
PostPosted: Sun Aug 28, 2022 10:38 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Paint is nitrocellulose.
Bind before or after painting? (taping is a pain)
Is there a glue for plastic binding that won't react with Nitro?
PostPosted: Sun Aug 28, 2022 10:59 am
Bind first, then spray. Scrape the finish from the binding before adding clear.
PostPosted: Sun Aug 28, 2022 1:58 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Hey there Chris. I tried that. Scraping not so much fun. Lead to minor scratches. Tried taping too. Somewhat better. Was hoping there was a glue better for this.
PostPosted: Sun Aug 28, 2022 3:27 pm
Fish glue?
These users thanked the author Colin North for the post: Cal Maier (Sun Aug 28, 2022 4:30 pm)
PostPosted: Sun Aug 28, 2022 4:28 pm
I use a sharp razor blade, Mike. You don't need a lot of the blade sticking out of your fingers to scrape off the finish. Do it in a smooth motion. I tried masking in the 70's. Made a ridge that I did NOT like, looked horrible.
Here is a quick tutorial from the great Tom Murphy!
https://www.youtube.com/watch?v=TNbsZsS ... el=StewMac
These users thanked the author Chris Pile for the post (total 2): John Steele (Tue Aug 30, 2022 6:56 am) • bcombs510 (Sun Aug 28, 2022 4:38 pm)
PostPosted: Sun Aug 28, 2022 5:58 pm
I use CA to glue plastic bindings. Never had a problem with nitro reacting with the glue. If I do a burst I scrape the bindings before the final clear coats, as Chris mentioned.
PostPosted: Sun Aug 28, 2022 6:43 pm
By the way, Mike - I always used Duco Cement in the green & yellow tube for gluing binding. I suppose Titebond might work. CA should be good if used sparingly.
PostPosted: Sun Aug 28, 2022 6:56 pm
wood glue doesn't hold any plastic
PostPosted: Sun Aug 28, 2022 7:51 pm
First name: D
Last Name: S
Straight acetone works very well. Also, a solvent cement such as Duco, Welden #16, or stew macs stuff works.
I’ve never had any issues spraying nitro on it.
I mask and scrape the binding after color coat.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Aug 28, 2022 8:35 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I’m guessing this is a technique issue
PostPosted: Sun Aug 28, 2022 9:39 pm
Well...yeah. And practice makes perfect. You'll get the hang of it, Mike. I don't think any of us started out awesome.
PostPosted: Mon Aug 29, 2022 12:43 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Binding is typically leveled by scraping it flush after installation. While it is possible to do this on a finished instrument, it is not recommended. As tedious as masking binding can be, it is far easier than the alternative.
Sent from my SM-G950U1 using Tapatalk
PostPosted: Mon Aug 29, 2022 2:41 pm
Last Name: Bradley
Country: United Kingdom
Bind using UHU Hart glue, then paint/burst, seal with shellac then scrape with razor blades. The scraping is easy after a little practice. You can even make a blade holder which adjusts for the width of binding, which helps with the bulk of scraping, to be finessed by hand.
PostPosted: Mon Aug 29, 2022 4:37 pm
I made a bladeholder like Michael's and it works good (his is prettier though). I also use mine for scraping a rabbet around the bridge before I glue it down.
PostPosted: Mon Aug 29, 2022 6:39 pm
Last Name: Bradley
Yes Steve, I use it for the bridge too, with the exposed area of the blade set to around 1mm or thereabouts. It works well for that.
Mike.
These users thanked the author mikeyb2 for the post: SteveSmith (Tue Aug 30, 2022 11:44 am)
PostPosted: Tue Aug 30, 2022 4:12 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
As mentioned, shellac the channels and use CA, then scrape level and prep. For shell work especially, CA makes life much easier in terms of leveling and filling. Once the body is prepped and sealed (do not spray colored lacquer directly on wood...you will thank me after your first ruined burst), a good mask just outside the desired trim line is done and the color coats are added.
Also think about the purfling scheme... an added thin black purfling line on a burst or other darker painted scheme makes it easy to get a clean scrape without revealing top wood, while something like a single light-colored binding strip without purfling forces the trim line to be inset from the edge of the plastic (see just about every painted Les Paul 's side scrape in the cutaway section and fretboard binding for a tutorial as to how the factory handles the job).
The most difficult scraping I did at Greenridge was on the rosettes of burst acoustic tops... no degree of fine line masking gets a truly clean edge on a ring-style rosette, so either the 'by eye and hand' method used by Gibson or a soundhole-mounted jig and thin-line scraper jig must be used.
What is not generally mentioned in these discussions is that lacquer has a defined window of time within which to get a clean scrape, and that window varies by lacquer used, thinner type and mix, any added plasticizer such as butyl cellosolve used, thickness of the coating, shop temperature, and air movement. Scrape too soon and the lacquer strings or is tugged/stretched, leaving a wavy or ragged line. Too much time between application and scrape allows the lacquer to harden to the point of fracturing and chipping out...even with a sharp, fresh edge on the scraper. A clean scrape is achieved only when the lacquer is at the right degree of drying and hardness to scrape without tears, pulls or chipping.
Where a color coat has gone too long to allow a clean scrape, a light coat of 50/50 clear lacquer can be applied to restart the clock, but keep in mind that the thicker the coating to be scraped, the more difficult it will be to scrape back, and the greater the number of top coats must be over the binding and purfling to allow leveling. Also note that after scraping, that first clear sealer coat needs to be light enough to avoid adding a bunch of solvent and allowing the color to flow, causing a soft edge, but with enough lacquer to get at least a full satin coat to seal. Subsequent coats can be the usual 70/30 full wet coat once that seal coat is on, and for bindings, a couple extra coats to build up over the scraped areas can be done with a round fan pattern and reduced pressure to minimize overlap beyond the binding and purfling.
- Beth Brower
These users thanked the author Woodie G for the post: Chris Pile (Tue Aug 30, 2022 6:57 am)
PostPosted: Tue Aug 30, 2022 6:58 am
^^^ WISDOM RIGHT HERE! ^^^
PostPosted: Tue Aug 30, 2022 8:51 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I see the blade holder holding a single-edged razor blade. My experience with a Stanley knife blade instead of a razor blade to scrape with told me that the Stanley blade makes a far better scraper than a razor blade. For one, it won't chatter like the razor blade, nice and stiff.
Peter Havriluk
PostPosted: Tue Aug 30, 2022 11:43 am
Last Name: Arnold
City: Newport
I also like to use scraper blades that are thicker than a razor blade. I have them from 0.012" to 0.024" thick. And rather than a knife edge, I tend to do square edge and roll a bur using a burnisher. Old habits die hard.
These users thanked the author John Arnold for the post: Chris Pile (Tue Aug 30, 2022 12:29 pm)
