It is currently Mon Jul 28, 2025 6:32 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: Cutting Nut Slots
PostPosted: Sat Sep 03, 2022 8:47 am
doncaparker wrote:
Oh, great. Once you start calling it a pecker, Hesh won’t be able to use it without giggling. :lol:
I'm more worried about letting the world know after I measure the one at work tomorrow that my pecker is on .007" thick.... :)
PostPosted: Sat Sep 03, 2022 8:57 am
bcombs510 wrote:
I have a question , Hesh. In the pics at the top I see you’re using this tool with the strings off. In the pic of the underside it appears to be a thin edge. I presume this is because you may need to use it with strings on. Is that right?
When I use other tools like this, for example the relief gauge from SM, it’s easy to change the reading when leaning the tool side to side.
I guess if I never planned to use it with strings on I could make the surface wider to avoid being able to tilt L/R.
Good observation Brad.
Yes it is designed to be used if we want with strings on and the string lifted out of the slot and set to one side. I don't use it that way but we can show a client in real time that his sitar sound is a precision measured low nut slot.
And yes again the tool changes values since we are measuring near nothing the measurement is so fine when you rock it but it's lowest value is always then it is straight up or down.
Making one that dos not have the narrower base to fit between strings would reduce or eliminate rocking but as someone who uses the tool for every Floyd Rose I have to set-up (I hate them....) which is several times a week (sadly) (we charge more for them too because Hesh hates them...) the rocking is never an issue for me.
What is worse in my experience is when setting intonation and watching the swings from how much fretting pressure I apply with my finger. I can change the reading far more cents than the threshold of human hearing. As such both my right hand and my fretting hand are simulating the average player with a moderate attack unless I know more about them. I used to ask them to play for me but now I am not there when the germ infested covid carriers come in during the day. 91 year old blind Mom we are tying to keep alive here ya know.
It is not easy to set-up an instrument well for a generic player you have to set a bit higher knowing they may be a heavy hitter.
Good catch Brad are you going to make one?
These users thanked the author Hesh for the post: bcombs510 (Sat Sep 03, 2022 12:29 pm)
PostPosted: Sat Sep 03, 2022 10:00 am
Awesome looking tool there for sure.
These users thanked the author jfmckenna for the post: Hesh (Sat Sep 03, 2022 1:02 pm)
PostPosted: Sat Sep 03, 2022 12:04 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
As with any tool, it's what you do with it that matters. :D
These users thanked the author doncaparker for the post: Hesh (Sat Sep 03, 2022 1:03 pm)
PostPosted: Sat Sep 03, 2022 12:35 pm
First name: Brad
Last Name: Combs
I feel that I must. :D
I use the SM nut slotting gauge which, as I’m sure you know, shows the string height over the first to give a reference number of how low the slot is. What I like about this approach is doing it without being strung up.
Thanks for sharing it and watch out for your pecker.
These users thanked the author bcombs510 for the post: Hesh (Sat Sep 03, 2022 1:03 pm)
Users browsing this forum: DennisK and 18 guests
