It is currently Mon Jul 21, 2025 11:10 am
 Post subject: My Neck Butt Joint
PostPosted: Fri Aug 11, 2023 11:39 pm
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
In case someone is looking for a simple neck joint to replace a more complicated mortise and tenon or dovetail joint, etc., I thought I'd show a few details of my bolted butt joint. Since, I didn't take pictures with this tread in mind I don't have the views that I'd like to have, but some random pictures I happened to find capture enough detail to give you a good idea of my approach.
Big picture: The neck's heel sits right on the head of the body and the fretboard tongue is glued to the top. Allen head bolts with Bellville washers, from inside the body, go through the body's head block and screw inside threaded inserts in the neck's heel. They are easily tightened with an allen wrench from inisde the body. (With the Belleville washers, I've not seen this bolts work loose.)
This is the top of a raw head block before cutting to final size, shape and drilling. Note the 3 laminations which make up the final thickness. Hard quarter sawn maple is sandwiched between 2 pieces of mahogany with non-aligned grain. The thicker piece of mahogany will be glued to the head of the body's rim after the block's face is radiused to fit the curvature of the rim.
This is the same block as shown above, but turned to show it's side. Note the non-aligning mahogany grain.
Here the head block has been shaped, drilled and glued to the body's rim. There is a small hole for the truss rod at the top, and two larger holes for 1/4-20 threaded allen bolts. The bolts are counter sunk into the head block so that the Belleville washers will bear against the hard maple in the block instead of the softer mahogany. This allows the washers to deform and lock the bolts tight. Unlike the Martin and Gibson head blocks of solid mahogany which break (fail) in two pieces along grain lines after years of service, I don't think that these blocks will break.
This view shows the rough neck. A channel was routed completely through the heel from top to bottom. Then a large piece of hard maple was pressed and glued into the heel with it's side grain showing all around (it's end grain is at the bottom & top of the heel.) This allowed the maple to be glued to mahogany side grain on 2 sides of the maple block. It also gives hard maple side grain instead of fragile mahogany end grain for the threaded inserts to cut securely into. (I don't understand why people put inserts into the end grain of mahogany or other woods in guitar building. It is understandable as to why a joint depending on end grain fails.) A typical threaded insert for wood is very course and dull, and tends to crush the wood as it enters the pilot hole. These inserts were made to cut into metal and therefore cut their threads/groves into the maple. It would take a very big force to pull these two inserts out.
Note that the maple and part of the mahogany has been relieved about 1/8" from the heel's face leaving about 1/4" of mahogany on each side of the heel to kiss the face of the body's rim. This is so it is easy to get the neck flush on the body and to easily adjust the neck's angle in any direction. Without this relief, much more material would have to be removed to adjust the neck's angle and get a tight fit to the body. Since the body curves here, this difficult task is eliminated.
Here are the 3 parts times two. Note the dome/bell shape of the lock washers which will flatten under force and push back aginst the bolts. They are superior to standard type lock washers. Monte Montgomery, an excellent player, does neck bends on a regular basis. He has an Alverez Yari guitar with, I believe, a dove tail joint. Over the years, his neck has come off the guitar twice while doing a neck bend. I don't see that as being the case with this butt joint.
This is a full scale drawing of the side profile of the neck, and a full scale cutout of the neck's section. The bottom of the heel ends up being about 1.125" deep (out from the rim) due to the pointed design. This is the same as a Taylor guitar and close to Martin's. If this is rounded it will suck back closer to the rim. This shape can be made a little smaller, but mine is a fairly traditional shape and size. In other words, I don't see that my butt joint design has caused an increase in size compared to many leading factory makers making millions of guitars.
Here's a view of a completed neck joint.
Here's a neck that is about to have finish applied.
My name is cut/routed into the peghead veneer and then filled with white epoxy. The interesting thing is, of EVERYTHING I have done in guitar building this gave me the most difficulty to accomplish. (I've never built a kit guitar. My first one was scratch built from mahogany that I re-sawed.)
Back strap epoxy filled and waiting for sanding.
This is a side view of a Taylor neck. I'm not trying to duplicate Taylor, but given how well accepted their shape and size neck heel is, I though it would be a decent reference point.
These users thanked the author Ed Haney for the post (total 6): joshnothing (Sat Aug 12, 2023 7:18 am) • Ken Nagy (Sat Aug 12, 2023 7:16 am) • SteveSmith (Sat Aug 12, 2023 6:05 am) • Michaeldc (Sat Aug 12, 2023 5:39 am) • Hesh (Sat Aug 12, 2023 3:23 am) • bcombs510 (Sat Aug 12, 2023 2:00 am)
 Post subject: Re: My Neck Butt Joint
PostPosted: Sat Aug 12, 2023 7:21 am
First name: Ken
Last Name: Nagy
City: Goodrich
Thanks Ed.
I think I saw this before, and is one reason why I wrote in the posts on "blasphemies" that a bolt on neck sounded viable. Your entire plan is well thought out.
Why be normal?
PostPosted: Sat Aug 12, 2023 10:11 am
First name: Brad
Last Name: Combs
Agreed, very well thought out process. Thanks for sharing it!
PostPosted: Sat Aug 12, 2023 3:23 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Your design does offer the option of installing tee nuts or similar on the back side of the maple insert before gluing it in. That would eliminate any possible issues that can occur with threaded inserts.
I used one 10-32 lag screw on the bolt-on necks I made. I prefer fine threads to prevent loosening. A 1/2" maple dowel was installed vertically in the heel for strength.
Martin neck heels are on the small side....approximately 7/8" wide and tall. IMHO, that is purely an aesthetic preference. Check out the wide, flat heels used on Gibson and Guild.
PostPosted: Sat Aug 12, 2023 4:10 pm
fine vs. coarse thread arguments are really only valid when the fastener size is the same...a #10 is at 3/16" and a thread pitch of 32 is definitely preferable over one of 24 when considering strength as coarser threads result in a smaller solid material diameter of the fastener.
the finest pitch for a #12 or larger is 24 and those fasteners are by definition stronger than a #10 if they are of the same material
PostPosted: Sat Aug 12, 2023 5:28 pm
I do my bolt ons with two 10-32's and although 1/4-20's are stronger I don't think that extra strength is necessary for a guitar neck joint.
PostPosted: Sat Aug 12, 2023 6:26 pm
I like the idea of drilling into that type of grain rather than end grain, simply because when drilling into end grain the bit can wander off center depending on the grain, leading to some creative time with the rat tail files and the holes in the block.
That said, I’ve hundreds of guitars out there with the inserts drilled right into the the mahogany or khaya. The only ones I’ve ever had trouble with were Spanish cedar, solved by drilling a maple dowel into the heel, and with brass inserts with too fine threads. So I use coarse threaded steel ones.
I like the idea of using t nuts mounted behind, but I’d be concerned about stripping the T nuts, the only ones I’ve ever seen have been pretty soft metal.
I like the bolt on butt joint as you can do a reset in about 15 minutes without having to remove the neck…
PostPosted: Sat Aug 12, 2023 8:15 pm
Last Name: Arnold
City: Newport
Strength of the bolt or screw is definitely a nonissue. A single 10-24 or 10-32 screw is plenty strong enough, and much less weight than 1/4".
I have seen Taylor inserts pull out of the neck. I repaired them by epoxying the inserts back into place. To be fair, those were very shallow inserts.
My bolt-on necks always had a tenon, which allows the anchor to be set deeper in the heel. That is not only a more secure anchor, but it makes the heel inherently stronger.
My straight tenons were about 5/8" wide, while Collings uses a vee shape. The end view of the Collings tenon mimics the Martin dovetail, but the cheeks are straight, rather than angled. That allows the neck to be inserted with lag screws attached to it.
Users browsing this forum: bobgramann, Powdrell1, pullshocks and 26 guests
