It is currently Sun Jul 27, 2025 4:11 pm
 Post subject: Fret tang width .
PostPosted: Sun Aug 27, 2023 1:35 am
First name: David
Last Name: Harris
So , my first actual newbe question . After cutting the fret slots with a .53mm Pax saw , I have come to realise that all the fret wire I have is .71mm tang width . Exactly what size tang fret wire should I be using ? My first build used a precut finger board with .71mm slots . Something I didn't even consider when buying fret wire .
 Post subject: Re: Fret tang width .
PostPosted: Sun Aug 27, 2023 2:11 am
At 0.71 mm width I think you're actually talking the width across the tips of the barbs.
https://jescarmusic.com/pages/fret-wire-specifications
0.53 mm slot should be good for most tangs, just slightly larger, although it's best to check before cutting slots, some are larger, DAMHIK.
The barbs bite into the wood to secure them in the slot.
PostPosted: Sun Aug 27, 2023 3:03 am
First name: David
Last Name: Harris
Yeah , these frets are .71 at the tang and .96 across the barbs . Others I have are .58 and .86 which I bought ready cut and trimmed. I think they might fit if I have enough . Cheers .
PostPosted: Sun Aug 27, 2023 5:59 am
OK.
That's a pretty big tang width....
PostPosted: Sun Aug 27, 2023 6:07 am
Colin North wrote:
OK.
The thicker tang might be good for doing refrets on guitars that have been refretted a few times and have worn out fret slots. bliss
PostPosted: Sun Aug 27, 2023 10:18 am
City: Lawrence
Zip/Postal Code: 66047
Do we need a zero after the point?
maybe .071 instead of .71 and .096 instead of .96.
These users thanked the author Dave Rickard for the post (total 2): Hesh (Mon Aug 28, 2023 9:16 am) • bcombs510 (Sun Aug 27, 2023 10:18 am)
PostPosted: Sun Aug 27, 2023 10:19 am
First name: Brad
Last Name: Combs
Puts a new spin on “jumbo” don’t it?
PostPosted: Sun Aug 27, 2023 10:26 am
City: U.P.
I think they are using that alien metric system.
Glad Windows 10 has a built in calculator with a conversion tool.
0.71mm = 0.028"
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: bcombs510 (Sun Aug 27, 2023 10:34 am)
PostPosted: Sun Aug 27, 2023 10:37 am
First name: Brad
Last Name: Combs
I did not know that! Thanks for the tip! :)
PostPosted: Sun Aug 27, 2023 6:12 pm
First name: David
Last Name: Harris
Not with Metric we don't .
These users thanked the author BlindGuitar for the post: Dave Rickard (Sun Aug 27, 2023 9:08 pm)
PostPosted: Mon Aug 28, 2023 9:22 am
Where is your wire from and what is the part number?
Frets should fit the slot with moderate pressure but not be too tight. If they are too tight they force the neck into back bow which is yet another reason to always use a quality double action truss rod.
It's common for us to press one fret in just to observe the fit and then adjust accordingly.
In the Martin guitar world, vintage Martins before the early 70s did not have truss rods so the neck is manipulated in its shape with every fret installed with a different tang width. Can't remember if there are 5 or 7 Martin tang sizes we have them all so when a fret fits too snug and I want to avoid back bow I can go to a narrower tang.
These users thanked the author Hesh for the post: BlindGuitar (Mon Aug 28, 2023 5:31 pm)
PostPosted: Mon Aug 28, 2023 4:48 pm
City: Lawrence
DOOOH.
My bad.
Next time I'll try actually reading what the OP says before I post!
These users thanked the author Dave Rickard for the post: BlindGuitar (Mon Aug 28, 2023 5:30 pm)
