It is currently Wed Aug 06, 2025 4:41 pm
 Post subject: Mixing Plastics
PostPosted: Mon Oct 23, 2023 9:43 am
First name: Rob
Last Name: Roither
City: Williamsburg
Zip/Postal Code: 23188
My previous guitars have all been done with ABS binding and pfurlings from LMI. Now with their limited stock I'm forced to mix ABS and PVC if I want to continue my usual design. Any thoughts on mixing ABS and PVC?
 Post subject: Re: Mixing Plastics
PostPosted: Mon Oct 23, 2023 2:18 pm
Last Name: Russell
State: Michigan USA
I have never tried it and I would be hesitant to say it would work. I have done a number of binding using ABS but have not tried mixing them.
I know from working on plumbing it is a no-go to glue ABS and PVC and under code you must have mechanical connection. The joint will fail.
Maybe someone here has experience with mixing the two but I wouldn't think they will stick together.
Otherwise you might go with ABS and that wood-like fiber stuff that is dyed
Cheers,
Bob
PostPosted: Mon Oct 23, 2023 4:08 pm
If you use CA then it would probably work. Test on scrap.
Also, abrading the surfaces of the plastic with sandpaper will always help with mechanical adhesion.
PostPosted: Mon Oct 23, 2023 5:36 pm
I’m guessing they would also age differently down the road, if that’s a concern, but don’t really know.
