It is currently Mon Jun 16, 2025 6:59 pm
PostPosted: Wed Oct 30, 2024 9:02 am
First name: Brad
Last Name: Combs
Hey folks,
In the last roundtable we talked about double sides, solid lining & vacuum bags. Here is a couple short videos showing making and then installing solid lining. Hope it’s useful.
https://youtu.be/FrWOZYaufd4?si=_fZsg5NfXNdVsqs6
https://youtube.com/shorts/1hX_2emssRs? ... SBIAKlQZfF
Brad
These users thanked the author bcombs510 for the post (total 2): SteveSmith (Wed Oct 30, 2024 3:09 pm) • bionta (Wed Oct 30, 2024 2:26 pm)
PostPosted: Wed Oct 30, 2024 12:06 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
Thank you, Brad. That makes perfect sense. I even thought I smelled the epoxy in the first video.
These users thanked the author bobgramann for the post: bcombs510 (Wed Oct 30, 2024 12:22 pm)
PostPosted: Wed Oct 30, 2024 2:27 pm
Last Name: Ionta
City: Hopkinton
State: Massachusetts
Zip/Postal Code: 01748
Very cool, Brad! Thanks for making this video.
These users thanked the author bionta for the post: bcombs510 (Wed Oct 30, 2024 4:21 pm)
PostPosted: Wed Oct 30, 2024 6:38 pm
Cool, I use clamping cauls but otherwise pretty similar. I usually leave clamped for at least 12 hrs. Do you leave the vacuum pump running that long?
With the solid linings that is an extremely rigid rimset. I have noticed that while increased mass/stiffness definitely increases volume too much can affect tone in a negative way. Have you seen a similar correlation?
PostPosted: Wed Oct 30, 2024 6:56 pm
First name: Brad
Last Name: Combs
The pump I have uses a reservoir and kicks off once it pulls the vacuum. It cycles once every few hours. I typically leave it for 8 hours / overnight.
I haven’t noticed an issue with too much volume on the latest 00 builds, but it’s been awhile since I’ve built a dred so will report back.
These users thanked the author bcombs510 for the post (total 2): Terence Kennedy (Wed Oct 30, 2024 10:51 pm) • Pmaj7 (Wed Oct 30, 2024 7:56 pm)
Users browsing this forum: Bing [Bot], doncaparker and 38 guests
