It is currently Sun Jun 15, 2025 12:24 am
PostPosted: Mon Jan 13, 2025 3:27 pm
Was just looking for some opinions on this construction method.
I generally use a Scarf Joint for the headstock angle with an additional 5mm slip of Wenge between the two pieces (mainly for aesthetics). I'm looking to do some proper "serious" builds with really nice quality woods. When it comes to the neck does the scarf joint construction negate the advantages of quarter sawn maple?
I may be overthinking things, as I usually have some carbon rods in there as well but just looking to get opinions.
Thanks!
PostPosted: Tue Jan 14, 2025 9:06 am
City: U.P.
Cip123
Quartersawn wood is generally stiffer than flat sawn wood and it also shrinks and swells less across the grain making the neck more stable under the fingerboard.
Those are the primary reasons many builders prefer quartersawn wood for necks.
Neither will suffer any adverse effects in a scarf joint.
Personally I probably wouldn't add a layer of another wood in the joint because it's shrink/swell rate might be different than the maple adding some unnecessary stress to the scarf.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post (total 2): cip123 (Sat Jan 18, 2025 9:15 am) • Kbore (Thu Jan 16, 2025 6:59 pm)
PostPosted: Tue Jan 14, 2025 11:07 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
The maple will still be in vertical grain orientation just one piece will be upside down in the scarf joint. So, it will still behave as quarter sawn. I have done a few maple necks with scarf joints and never gave it a second thought.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post (total 2): cip123 (Sat Jan 18, 2025 9:15 am) • Kbore (Thu Jan 16, 2025 6:59 pm)
PostPosted: Sat Jan 18, 2025 9:17 am
Thanks very much for your input guys!
As for the wood between the scar joint, I really like the aesthetic. But I will trial a clean joint with no extra timber, or a veneer. I just think it looks very nice on the back of the neck.
