It is currently Sat Jul 19, 2025 1:30 am
PostPosted: Sun Feb 26, 2023 5:20 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Some of us, due to having significant spine problems, really need ways of avoiding strain on our backs caused by hunching over a guitar on a bench. Others of us just don’t enjoy all that bending over. I’m in the latter category. About a year and a half ago, I started this thread to show photos of a work positioning tool I had added to my shop at that time, the Wilton Pow-R-Arm:
viewtopic.php?f=10101&t=54436&hilit=wilton
The Pow-R-Arm works pretty well, but it has its limitations, so I kept my eyes out for something better. I think I have found it by using three products together from Howard’s Total Vise. Here are the three products, attached to my workbench:
Shown above are:
The S Mac Vise Pedestal Conversion Plate ($59.95 USD)
The Crossover Mini ($179.95 USD)
The Bench Vise Mounting Plate ($49.95 USD)
Together, these three products give me the ability to rotate and tilt my workboards in any direction and then (here is the kicker) lock them down with the highest rigidity I have ever seen from tools like this. How rigid? So rigid that, when I lock these tools into place and put my full weight on them, I am more in danger of turning over my workbench than flexing the tools or loosening the clutch mechanisms. That’s solid! I could never count on my Wilton Pow-R-Arm to be that solid.
The Total Vise products rely on two basic mechanisms to provide these levels of both adjustability and rigidity. First, concentric steel pipes with the outer pipe outfitted with a clutch screw mechanism provide a full 360 degree rotation of anything placed into a mounting base. Below is a photo of the S Mac Vise Pedestal Conversion Plate, which has one of the clutch mechanisms:
I have this base mounted on a thick piece of laminated maple, which is connected to my workbench via bolts into threaded inserts through dogholes. This way, I can put it on or take it off in less than a minute.
The next piece of gear is the Crossover Mini, which combines the ability to tilt (via a different clutch mechanism) with the ability to rotate 360 degrees whatever you mount in it:
The third piece of gear is a mounting plate that matches up perfectly with the 6” hole spacing I had already established for all my workboards:
This gives me the ability to fully rotate the workboard, as well as tilt it up to 90 degrees in one direction and 45 degrees in the other. Since the Crossover Mini itself can be rotated inside the base, the tilting can be done in any direction, limited only by the surroundings (like the workbench itself).
I’ve attached several workboards and platforms to this Total Vise stack (photos only upon request):
Brace carving workboards
Body Mold (mounted to a holder that provides access to everything inside and out)
Neck carving platform
I even went semi-crazy and built a Moxon-style guitar body vise:
It gives me the same Troji-type body clamping that I get from my twin screw vise, but adds the benefit of full rotation and tilting. I have to work without a sling (since there is no up or down), so I have to keep my wits about me and not drop a guitar when I loosen the handwheels, but I think I can handle that.
If you browse the Howard’s Total Vise website, you will see lots of products beyond what I am using. Some of them might be a better fit for you than what I am using. Others might not be useful to you at all. One product I did not like is the Quick Docking Station. It has a lot of flex in the mounting plate, and that allowed whatever I mounted in it to flex around that point. I switched to the S Mac Vise Pedestal Conversion Plate as my base, and it is much more stable.
I hope this is helpful to some of you, particularly those who have back problems. It is definitely the best work positioning tool I have ever used. It puts my Wilton Pow-R-Arm to shame.
These users thanked the author doncaparker for the post (total 10): Kbore (Fri Feb 28, 2025 5:37 pm) • JimWomack (Thu Jul 06, 2023 7:19 pm) • Durero (Mon Feb 27, 2023 9:51 pm) • joshnothing (Mon Feb 27, 2023 5:02 am) • Pmaj7 (Mon Feb 27, 2023 4:15 am) • Pat Foster (Sun Feb 26, 2023 9:46 pm) • J De Rocher (Sun Feb 26, 2023 7:35 pm) • Robbie_McD (Sun Feb 26, 2023 7:13 pm) • Barry Daniels (Sun Feb 26, 2023 5:39 pm) • bcombs510 (Sun Feb 26, 2023 5:36 pm)
PostPosted: Sun Feb 26, 2023 6:14 pm
Looks like that would make a handy neck carving jig holder…
These users thanked the author meddlingfool for the post: Kbore (Fri Feb 28, 2025 6:04 pm)
PostPosted: Sun Feb 26, 2023 6:18 pm
Last Name: Parker
City: Charleston
Indeed!
These users thanked the author doncaparker for the post (total 2): Kbore (Sat Jun 08, 2024 8:30 pm) • Robbie_McD (Mon Feb 27, 2023 9:45 am)
PostPosted: Sun Feb 26, 2023 7:38 pm
Wow! Nice Don. Great set up.
PostPosted: Sun Feb 26, 2023 9:59 pm
Thanks! I'm just about ready for this!
Formerly know as Mandodiddle.
PostPosted: Mon Feb 27, 2023 8:50 am
That looks like a very nice set up!
I can get most of the positioning features with my versa vise (parrot vise), but I like the mounting plate feature that allows you to rotate the fixtures you have made.
I may try making a "poor mans" version by boring a hole in a block of wood, clamping it in the vise and using a pipe nipple and flange for the mounting plate.
I like the Moxxon style vise you made. Where did you find the hardware for it?
PostPosted: Mon Feb 27, 2023 10:09 am
Last Name: Parker
City: Charleston
Clay--
Regarding the Moxon hardware, it wasn't easy, for these reasons:
1. Different Moxon vise kits use different threads.
2. All Moxon vise kits that I saw online used shorter threaded rod than I thought I needed (and I was right).
I had a Moxon hardware kit I had bought used from someone, and tried to buy longer threaded rod to match it, but that wound up being too much trial and error (they don't make Thread Detectives this large). So, I started from scratch, picked a thread size in which I could buy all four things (handwheels, threaded rod, nuts, and washers), and ordered them separately. It all worked out that way, and I still have that other Moxon vise hardware kit if I ever want to build a more traditional one.
Here are eBay links to the parts I used:
https://www.ebay.com/itm/111894752797?var=410855758643
https://www.ebay.com/itm/383891808965
https://www.ebay.com/itm/175198799383
https://www.ebay.com/itm/164947305641?var=464482144663
I had to cut the 36" threaded rod in half and then both halves down to the perfect size (once the whole thing was together and I could figure out the perfect rod length), but that was just an expenditure of elbow grease and wear and tear on a hacksaw blade.
The vise works great, by the way. I used the same closed cell foam I used for my twin screw bench vise, and cut curves in it so that it only grabs the edges of the guitar body.
These users thanked the author doncaparker for the post (total 3): CraigG (Fri Feb 21, 2025 8:50 pm) • Kbore (Mon Nov 20, 2023 1:23 pm) • Clay S. (Mon Feb 27, 2023 12:22 pm)
PostPosted: Mon Feb 27, 2023 1:03 pm
Very cool, Don. I'm glad you found a solution that helps you work more comfortably!
I also really like your Moxon setup. I made a Moxon about 7 or 8 years ago to learn dovetailing. I've used it off and on for some body holding tasks and see a lot of potential, but my acme threaded rods are just long enough. I'm going to look into the hardware you linked to.
I also really like the addition of the closed cell foam. Is it just thick closed cell foam?
PostPosted: Mon Feb 27, 2023 1:46 pm
Last Name: Parker
City: Charleston
James—
Yes, it’s 2 inches thick, and it looks like it is two 1 inch thick pieces fused together. I cut the curve on the bandsaw. Open cell foam (like seat cushion foam) is too squishy for my taste, for this job. But the closed cell foam could exert too much pressure on the middle of plates if I didn’t cut the curve.
These users thanked the author doncaparker for the post: James Orr (Mon Feb 27, 2023 2:03 pm)
PostPosted: Thu Jul 06, 2023 5:35 pm
Last Name: Parker
City: Charleston
I had an "aha" moment today regarding another tool I can mount on my work positioner: My bending iron. I normally work with my bending iron standing up vertically, bolted to my bench. But there are some bending operations that are easier to do when the iron is horizontal, so that I can push down on the work. I can go from vertical to horizontal in a moment using this work positioner. But there's more! With the bending iron sitting horizontal, I can rotate the iron 360 degrees in the work positioner, and get easy "pushing down" access to every curve on the ellipse-shaped iron's profile. The same is true with the iron sitting vertical; no more standing at odd angles to access a specific curve on the iron. I can just rotate the iron in the work positioner and have the desired curve situated across from me.
This work positioner is really earning its keep around here. Money well spent, IMHO.
These users thanked the author doncaparker for the post (total 3): Kbore (Fri Feb 28, 2025 6:05 pm) • Robbie_McD (Fri Jul 07, 2023 7:17 am) • bcombs510 (Thu Jul 06, 2023 6:26 pm)
PostPosted: Fri Jul 07, 2023 9:39 am
I’ve been looking at these a while now…. As we know positioning is a really big deal.
I’ve also considered a vac clamp but for holding jigs as well this looks great
These users thanked the author SnowManSnow for the post: Kbore (Fri Feb 28, 2025 6:06 pm)
PostPosted: Sat Jul 29, 2023 6:23 pm
Last Name: Parker
City: Charleston
This Total Vise work holding setup made today's brace carving waaaaaay easier on my back than what I used to do. End result (and no back pain):
These users thanked the author doncaparker for the post (total 6): Kbore (Mon Nov 20, 2023 1:26 pm) • Pat Foster (Tue Aug 01, 2023 8:40 pm) • Durero (Tue Aug 01, 2023 1:04 am) • James Orr (Sun Jul 30, 2023 1:47 pm) • Clay S. (Sat Jul 29, 2023 8:30 pm) • bcombs510 (Sat Jul 29, 2023 6:51 pm)
PostPosted: Fri Feb 21, 2025 6:58 pm
Last Name: Parker
City: Charleston
I just wanted to bump this thread to highlight how responsive Total Vise is. I had an idea this evening (Friday) of a specific custom-made adapter I would like to have from Total Vise (details not important). I e-mailed Jeff Howard about it. He e-mailed back within 5 minutes, said yes, and asked me to call him tomorrow (Saturday) to discuss details. This was not the first time we have had this sort of e-mail and follow up phone call over the weekend.
Hats off to Jeff Howard at Total Vise for above and beyond interaction with the customer!
Oh, and I am still smitten with the quality and utility of these tools. They are super solid, reliable pieces of gear.
These users thanked the author doncaparker for the post (total 3): Kbore (Fri Feb 28, 2025 6:07 pm) • Durero (Sat Feb 22, 2025 1:50 pm) • bcombs510 (Fri Feb 21, 2025 7:45 pm)
PostPosted: Fri Feb 21, 2025 7:31 pm
That looks really practical and efficient! What is your actual workbench?
PostPosted: Fri Feb 21, 2025 7:42 pm
Last Name: Parker
City: Charleston
Ed—
The top is 30” wide, 60” long, 2.25” thick, laminated maple (store bought) mounted on the cast iron bench legs that Lee Valley used to sell. I have 3/4” diameter dog holes all around the edges and up the middle. There is also a twin screw vise on one end. I love my free standing workbench. It’s one of the best decisions I made in setting up this shop 18 years ago. I can move it, but it takes some effort, and it will not tip over unless I do something really stupid. The total Vise stuff, mounted on my bench, is very solid.
These users thanked the author doncaparker for the post (total 2): meddlingfool (Fri Feb 21, 2025 10:31 pm) • bcombs510 (Fri Feb 21, 2025 7:46 pm)
PostPosted: Fri Feb 21, 2025 8:12 pm
First name: Brad
Last Name: Combs
+1 for Jeff being awesome. I described what I needed in an email as an add-on for the spray station. I have the custom parts a couple weeks later.
These users thanked the author bcombs510 for the post (total 2): Kbore (Fri Feb 28, 2025 6:07 pm) • Durero (Sat Feb 22, 2025 1:51 pm)
PostPosted: Sat Feb 22, 2025 5:10 pm
I've had a bad back for years and things such as standing at a bench or the kitchen counter particularly doing dishes just kill my back.
I learned a long time ago that it's a bench/counter height issue for me if it makes me look downward with my chin in to my body too far.
Dave raised my benches at work 12 years ago and my back issues from work went away. So I raised my home shop benches and the same happened, my issues went away.
When I was building those 5 amplifiers my back was killing me so I raised that bench and no more back issues.
I have degenerative disc disease per my doc's office and the whole spine, like a guitar is a system so when I have to look too far down that's when I irritate it.
With all this said how the work piece is secured if it needs to be is one thing to consider as you are and I'm going to also suggest for those who want an alternative to a proprietary system that the height of the work piece, bench, whatever was the ticket for me. I would not still be working had I not learned this my back was so bad at one point.
Back issues suck for sure, can't do much of anything without our backs.
These users thanked the author Hesh for the post: Kbore (Fri Feb 28, 2025 6:08 pm)
PostPosted: Sun Feb 23, 2025 3:56 pm
Very cool vise. I have a Veritas Tucker vise that can handle pretty much everything that one does with a few fixtures. Can never have enough vises though! I must have at least 10 different bench vises but the Tucker is king. I paid around $700 Cdn way back when before the tooling got damaged and they were discontinued due to the cost of re-tooling and modest sales figures. I did see one in the box go for $3500 USD a few years ago though. Rare to see any listed these days.
These users thanked the author Darrel Friesen for the post: Kbore (Fri Feb 28, 2025 6:03 pm)
PostPosted: Fri Feb 28, 2025 5:58 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Here are 12" and 18" screws with crank handles- Jorgensen Pony.
Pony Tools 6712 12 inches, Heavy Duty Press Screw @ amazon
https://a.co/d/7ptldJU
Pony Press Screws Item 17F0252, Pony 18" Press Screw @ Lee Valley
https://www.leevalley.com/en-us/shop/to ... em=17F0252
Measure Twice,
Karl Borum
PostPosted: Sun Mar 02, 2025 1:30 pm
State: Illinois
Anyone else using a lift table? It plugs in, mine goes from 27 1/2" up to 45". I use a stool height office chair with it and my favorite type of vise, which is easily removable when necessary. The lift hardware is purchased separately, you add your own top.
These users thanked the author Resophonic for the post (total 3): Durero (Sun Mar 02, 2025 5:24 pm) • rbuddy (Sun Mar 02, 2025 3:25 pm) • Kbore (Sun Mar 02, 2025 3:15 pm)
Users browsing this forum: Michaeldc and 19 guests
