It is currently Thu Jul 17, 2025 9:47 pm
PostPosted: Sun Mar 09, 2025 3:38 pm
First name: Brad
Last Name: Combs
Hi folks,
Is there any real reason to keep the aluminum foil in the bending sandwich if I’m also using craft paper? Seems like I can drop the foil altogether and remove a step and also remove worry about staining certain woods?
My slats are stainless I think.
Brad
These users thanked the author bcombs510 for the post: Kbore (Fri Mar 14, 2025 11:34 am)
PostPosted: Sun Mar 09, 2025 4:43 pm
No need for it. I wrap mine in brown paper. Often an old paper bag cut apart or the paper packing from a package. Never broken a side this way, but I probably use thicker ss slats than you all.
These users thanked the author Jim Watts for the post (total 2): Kbore (Fri Mar 14, 2025 11:35 am) • bcombs510 (Sun Mar 09, 2025 4:50 pm)
PostPosted: Sun Mar 09, 2025 6:58 pm
Only paper for me…
These users thanked the author meddlingfool for the post (total 3): Durero (Sat Mar 15, 2025 3:10 pm) • Kbore (Fri Mar 14, 2025 11:36 am) • bcombs510 (Sun Mar 09, 2025 7:11 pm)
PostPosted: Sun Mar 09, 2025 8:20 pm
Last Name: Colbert
City: Anacortes
Agree with the comments above - I bought stainless slats from Mr Hall so I wouldn’t need the foil. A also use a 6” lightweight painters masking paper to hold a little extra moisture and to help keep any resins in the wood off of the slats.
Cheers, M
These users thanked the author Michaeldc for the post (total 4): Robbie_McD (Sun Mar 23, 2025 7:50 am) • Durero (Sat Mar 15, 2025 3:10 pm) • Kbore (Fri Mar 14, 2025 11:36 am) • bcombs510 (Sun Mar 09, 2025 8:25 pm)
PostPosted: Mon Mar 10, 2025 1:40 am
From outside in, blanket, steel, paper, wood, paper, steel, form.
These users thanked the author meddlingfool for the post (total 3): Durero (Sat Mar 15, 2025 3:11 pm) • Kbore (Fri Mar 14, 2025 11:36 am) • bcombs510 (Mon Mar 10, 2025 6:33 am)
PostPosted: Mon Mar 10, 2025 3:54 am
I didn't use foil either.
My stack had three slats from bottom up:
1) stainless slat (kept stainless on the bottom so the spring back did not risk cracking a site upon removal)
2) wood wrapped in spritzed craft paper (I never used Super soft or fabric softener mixed in water)
3) spring steel slat
4) blanket from my buddy John Hall
5) spring steel slat.
I also had a second caul and spring set on my bender on the lower bought.
I avoided foil because I made likely built over ten guitars out of Koa and Blackwood was a favorite too. Wanted to avoid the dreaded mean, green staining.
The third slat, spring steel on the top of the stack was to help direct more blanket heat downward.
Worked great I never cracked a single side.
These users thanked the author Hesh for the post (total 2): Kbore (Fri Mar 14, 2025 11:37 am) • bcombs510 (Mon Mar 10, 2025 6:33 am)
PostPosted: Mon Mar 10, 2025 9:15 am
Spring steel will rust really badly if you have it next to wet craft paper. Stainless steel is fine though.
These users thanked the author Barry Daniels for the post (total 2): Kbore (Fri Mar 14, 2025 11:38 am) • bcombs510 (Mon Mar 10, 2025 9:26 am)
PostPosted: Sun Mar 23, 2025 7:56 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Agreed Barry, I have a set of Spring Steel Slats from Blues Creek from way back....
Have always used spritzed Kraft paper and foil in a sandwich to keep the sides away from the spring steel to avoid the inevitable staining and rusting...
PostPosted: Sun Mar 23, 2025 9:46 am
So if you keep your shop or where you store your slats at 45% RH they won't rust even spring steel. Mine never did. Where people may run into corrosion problems is when they have a part time lutherie shop without 24/7, year round humidity and temp control.
It's interesting since I keep my entire condo at 45% RH nothing, none of my tools have ever rusted here and they all look like new. I have around 30 guitars on the walls too and the hardware never rusts either. And as a human I feel very comfortable in 45% RH too.
Our city/commercial shop is the same deal, year around, 24/7 strict humidity and temp control and nothing corrodes as a result.
My slats were also from my buddy John Hall and from way back around 2005ish.
PostPosted: Sun Mar 23, 2025 10:26 am
First name: David
City: Napa
Zip/Postal Code: 94558
I'll be the one dark horse lol I still like the foil with hard to bend woods, even though I use brown craft paper as well. I feel like it retains the moisture better. If I'm bending a species that is really easy to bend I'll leave the foil out.
These users thanked the author dofthesea for the post: Hesh (Sun Mar 23, 2025 11:54 am)
PostPosted: Sun Mar 23, 2025 2:13 pm
I use alufoil and damp wallpaper lining paper between the my blued spring steel slats and the wood.
I like these slats because the blued slats spring straight back completely flat.
Occasionally the foil breaks/tears a bit but the slats don't rust much if at all, and a quick wipe 000 steel wool cleans it off easily.
These users thanked the author Colin North for the post (total 2): bcombs510 (Sun Mar 23, 2025 5:37 pm) • Hesh (Sun Mar 23, 2025 3:07 pm)
PostPosted: Tue Mar 25, 2025 6:50 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
When I made my 'Fox' bender, I has access (and free-of-charge, besides) to 2024 aluminum sheet and made my slats out of that. I don't think there's much difference between that aluminum alloy and SS.
Peter Havriluk
These users thanked the author phavriluk for the post: Hesh (Wed Mar 26, 2025 5:50 am)
