It is currently Mon Sep 15, 2025 3:43 pm
PostPosted: Sun Jul 16, 2006 6:47 pm
Do you guys have any advice for me?
It will be bear claw sitka on EI rosewood with a Florentine cutaway.
Where do you get cases?
PostPosted: Sun Jul 16, 2006 10:28 pm
Steve, I do believe that Access have a SJ case in the works... If not you'll have to go with the Access 3 if your guitar has a lower bout larger than 15.75. The 3 is 16.125 in the lower bout and around 12 for the upper...
I find the Access cases fatastic for the money but you have to buy a lot of 4 at a time... You can check them out here:
Access Cases
I hear good things about TKL and of course there's always the higher end Ameritage's and then the ultimate Calton's...
TKL Cases
Ameritage Cases
Calton Cases
Hope this helps,
PostPosted: Sun Jul 16, 2006 11:54 pm
Steve the OLF SJ is a bit of an odd size. It will fit An access Small body Stage 5 case if you take the removable heal pad out. Ceder creek will make one for you as will any other custom case.
PostPosted: Mon Jul 17, 2006 12:43 am
yep Ameritage has the OLF specs and will make them available. Also Cedar creek has those specs but these are considered customs.
PostPosted: Mon Jul 17, 2006 1:10 am
Hesh, all I have is the Access 3... I really wanted the 5 but the max. width at the upper and lower bouts were about .25 to .5 inches too narrow. (My mod dread is 16.125 LB and 12.0 UB).   Since I FP, I didn't want to compress the sides too and I thought it would too much of a tight fit...
The Access 3 is about .5 to .75 inches wider in the bouts than the 5. Why? I wish I knew! They probably use the same shell but just add thicker padding to the 5's... Too bad...
For the money, though, the 3 is a very nice case indeed. I think Taylor uses these cases now for their instruments.
Cheers!
PostPosted: Mon Jul 17, 2006 1:18 am
They use a 5/8" padding with plush interior on Stage 3 cases and 1" padding with valour interior on Stage 5 cases
PostPosted: Mon Jul 17, 2006 1:23 am
I guess this is a good time to mention that Access will be changing the foam they use on both Stage 3 and Stage 5 cases They will be going to a smaller closed cell foam that can be squeezed and will return to it original shape, much like memory foam. I learned this at the NAMM Summer Session Friday.
PostPosted: Mon Jul 17, 2006 1:45 am
Hesh I just looked it over for the first time at the NAMM show this weekend. If I remember right it has a slight dome. This is a 3 ply case as apposed to the Sage 5 that is a 5 ply. but out side of that this is a great case for the price.
PostPosted: Mon Jul 17, 2006 2:23 am
Hesh, have a look here:
Acces pics.
The 3 is not as nice or fancy looking as the 5, but it's still a very handsome case for the money...
PostPosted: Mon Jul 17, 2006 2:59 am
Yep that is what I remembered shallower thatn the Stage 5.
PostPosted: Tue Jul 18, 2006 4:11 am
Hmmm,
I have read all the responses and I'm not sure of anything.
Is there a case that will work with the OLF SJ?
PostPosted: Tue Jul 18, 2006 4:34 am
Both Heritage and Cedar Creek will custom pad a suitable case for you if you fill out their spec sheet and send them a tracing. I use Cedar Creek and have been very satisfied with the results. The spec sheet is downloadable at the site and it takes 8 weeks. I get the 600 series and if you tell them you are a luthier you will get a break. They even have what they call the builder series but it's not as nice as the 600 series. If you order 4 cases you will get a bigger break. I can't tell you what the prices are but they are definately in the reasonable range. It's simple really, just call'm up, they're nice folks.John How38916.5669328704
PostPosted: Tue Jul 18, 2006 4:38 am
Ameritage, Cedar Creek, Calton all have the specs for it. Of course these would be customs. I will be receiving the build #2 OLF SJ case from Ameritage the middle of next month. It is built explicit for The OLF SJ. Hesh said the Access Stage 5 Small body is too shallow but it has worked for me if I remove the removable back pad back pad and the removable heel support. It is a bit of a tight squeeze because you have to squeeze the lower and upper bout about 1/4" to the side but after you do it fits pretty well. However you can't build over 4 1/2" deep at the lower bout at all. So the answer is I do not believe there is a Stock case the perfectly fits the OLF SJ but cases that will are available.MichaelP38916.5697337963
Users browsing this forum: Bing [Bot] and 20 guests
