It is currently Sat May 30, 2026 11:27 pm
PostPosted: Sun Aug 29, 2010 7:32 am
Here are the steps I use to do a sunburst on an F5 mandolin.
The binding is taped off. There is usually a lot of bleed through, but it saves some work in scraping so it's worth doing.
The instrument is dyed antique yellow/amber.
Three airbrushings of the brown. I do another 3 to darken further.
Eight to ten drops of black dye are added to the brown left in the bottle and I darken the edges.
I'll shoot a coat of spirit varnish on and tomorrow I'll peel the tape and scrape the binding.
PostPosted: Sun Aug 29, 2010 7:59 am
First name: Tim
Last Name: Warren
State: Ok
Zip/Postal Code: 73020
Haans, thanks for that. I never realized it could be that simple. So I take it that you don't actually spray the sides, they just catch the over spray when you shoot the top and back, correct?
Tim
PostPosted: Sun Aug 29, 2010 8:41 am
Thanks, Haans...nice process...I love your KISS practical approach.
PostPosted: Sun Aug 29, 2010 10:59 am
First name: Big
Last Name: Jim
I tried to do it with rags and brushes ! [headinwall] [headinwall] Man Your way is soooooooo simple . [:Y:] Thanks BTW what type airbrush u using ? Is an expensive one necess , or are the cheaper ones sufficent ?
PostPosted: Sun Aug 29, 2010 6:26 pm
Tim88, I do spray the sides...there is a definite pattern to F5 ribs and sections are very dark. So, here's the rest of it. I use utility knife blades and grind a bit off the point on one to get the scroll.
Xacto knife blades are used to get to the side of the binding. The non-sharp edge is ground to a square edge to scrape with.
The scroll is finished on the top.
A steel rule is taped to the fingerboard to use as a guide for scraping the F/B binding.
One coat of oil varnish.
The airbrush is an Iwata, but you can get by with a Paasche. The important part is to keep the brush extremely clean.
PostPosted: Sun Aug 29, 2010 9:45 pm
Hans,
thanks for the great information. Is that a big chunk of binding material in the background of the next to last picture? What is that? Did you make it?
Walter
Walter Lay
"It's taken me so long, but now that I know
I can see. All that I do or say, is all I ever will be"
- Billy Joe Shaver
PostPosted: Mon Aug 30, 2010 6:24 am
Walter, that is a block of purling for a new style I'm working on. You can see more in the first couple of photos. A slice is cut off that block and that slice is cut into tiny pieces to form the purfling. See my website for the process. Here is a fairly final look...
PostPosted: Wed Sep 01, 2010 8:43 am
Hans,
Nice website. Thanks again for the great info. I really admire the clever methods you have come up with (neck joints etc.)
Walter
Walter Lay
- Billy Joe Shaver
PostPosted: Fri Mar 18, 2011 5:17 pm
Well done - love it!
PostPosted: Tue Mar 22, 2011 8:34 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
nice - thanks for posting!
http://www.PeakeGuitars.com
PostPosted: Fri Jul 29, 2011 10:22 am
First name: Ben
Last Name: Bryant
City: Matsumoto
State: Nagano
Zip/Postal Code: 3900852
Country: Japan
excellent.... bursts are an art form.
