It is currently Thu Aug 14, 2025 12:12 pm
 Post subject: Buffer Questions
PostPosted: Tue Sep 25, 2012 6:38 pm
I am in the market to add a buffer to my shop. I have been eye ballin' the StewMac buffer kit but at $650, lookin' is all I am doing right now. I found a used Jet JSB-10L 1ph, 1725 rpm buffer in excellent condition for $200. MUCH better price!!! My question is, how will the 1725 RPM work for buffing guitars? I have not used a buffer before so have no idea what is ideal. Everything I have done to date has been done by hand or with my RO sander and micromesh. Will this speed generate too much heat with a 12" buff? If I did the math correctly, the StewMac at 750 RPM with a 14" buff has a speed of 62.5 MPH. The Jet at 1725 rpm with a 12" buff will have a speed of 123.2 MPH.
Carl.
 Post subject: Re: Buffer Questions
PostPosted: Tue Sep 25, 2012 7:21 pm
I use a 400 and 700 rpm buffer. I use a shop fox buffing arbor with a 1/4 hp motor. I use a 12 and 16 inch buffing wheel. Can make this for about $250 or less.
http://www.grizzly.com/products/Buffing-Assembly/H3559
PostPosted: Wed Sep 26, 2012 6:37 am
I have been using the Shop fox but I do use an oversize 16 inch buffing wheel. After 5 years I haven't had a problem and have plenty of room for buffing but I agree the longer shaft is nice.
You have to be aware of the clearance of the guitar body as you work on a buffer so you don't bump into things. That is why I used the over sized wheels . Also you don't need a lot of power . I use a 1/4 hp 1725 motor and it is set so that I can stop the wheel by hand. This is a buffer not a grinder. Also think about padding the floor in case you throw one. It isn't a good thing to happen.
PostPosted: Wed Sep 26, 2012 6:45 am
Last Name: coloccia
Country: States
I thought I was the only one that did that. I have my belt set so it slips too. I find there's no other way to get into tight spots without ripping right through the lacquer.
It's also nice that it lets me know when I'm pushing too hard. Just a light touch is really all it takes.
I happen to have the previous version of the SM buffer...I just picked it up a few months ago. The new version is probably even nicer. I have to admit that it's expensive, but I don't think it's overpriced. The entire system is very nice. I just ordered more buffs for it. I have a dedicated coarse compound buff for metal. It's basically black now so I can't use it for anything else. I LOVE polishing nuts with the fine compound. It's so much quicker than buffing it by hand.
PostPosted: Wed Sep 26, 2012 9:33 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I use the same ShopFox John H is talking about. With 14" wheels. I would like to find the 16" wheels, but no luck so far. I get mine from Casewell. They last forever. I bet I have $250 in my buffer. I found an excellent 1750 rpm, 1/3 hp motor on ebay (I think). Loose fit belt. I believe I use the Canton Flannel wheels. Two on each side. I can stop the thing with my hand. RPMS are about 800. Snagging the guitar and it getting tossed is always a risk, but not a huge risk with a setup like this. Take your HP & RPMs up, and it becomes way more likely. I have yet to get a snag that even remotely worried me.
Mike (hoping John H will reveal his source for 16" wheels!)
PostPosted: Wed Sep 26, 2012 10:52 am
I found them at Grizzly on the
http://www.grizzly.com/search/search.as ... 1091033430
you may need to make a bushing 3/4 inch schedule 40 pipe worked for me.
PostPosted: Wed Sep 26, 2012 11:08 am
After looking at the Shop Fox and Grizzly ones, I bit the bullet and bought the previous generation SM buffer ( they just announced a new one in the last month or so). It was the biggest single tool expense I've had in years, but I have no regrets. I did junk their belt and put on a link belt. Much smoother.
PostPosted: Wed Sep 26, 2012 8:16 pm
Thanks for all the input. Think I am going to continue saving my pennies and get the SM version.
PostPosted: Fri Sep 28, 2012 5:13 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I use a Caswell buffer.
http://www.caswellplating.com/buffing-polishing/buffing-machines/3-4-hp-buffing-machine-1100-rpm-machine-only.html
No belts or external motors to deal with, and cost alot less than the SM deal. I don't tighten the buffs super tight so they'll slip if it grabs the guitar.
Users browsing this forum: doncaparker and 39 guests
