It is currently Tue Aug 05, 2025 10:57 pm
 Post subject: Pickups
PostPosted: Thu May 30, 2013 4:44 pm
Last Name: Ward
Country: UK
Hi all,
I've decided that I'm going to have a go at winding my own pickups, but in the true nature of most of us I don't want to do things by halves, so I've decided that as well as winding them I want to make as much of the structure as I can, I've worked out, I think, how to make covers for them where necessary but I also want to make the flat work for them.
The problem I'm having is not being able to find the standard sizes of these in a format I can work with. I'm in the UK so work mainly in metric, I can to an extent work in imperial but only in fractions I.e 1/4, 1/8, 1/16 etc. I get totally lost when we start in decimal inches.
Does anyone know of any diagrams or charts of the flatworm in metric?
~Nil carborundum illegitemi~
 Post subject: Re: Pickups
PostPosted: Thu May 30, 2013 5:13 pm
First name: Derek
Last Name: Dowding
City: Wallsend
Zip/Postal Code: 2287
Chris,
All you have to do to convert thousands of an inch to metric is multiply the imperial value by 25.4
This will give you the metric equivalent value. For example:-
1/2" = 0.500" x 25.4 = 12.7mm
If you want to convert metric to inches, you multiply the metric value by 0.039
This will give you the imperial equivalent value. For example:-
13mm x 0.039 = 0.507"
I've got a mind like a steel......whatsername!!?
PostPosted: Thu May 30, 2013 6:13 pm
Last Name: Ward
Country: UK
Doh... How stupid am I? Thanks for that, it really hasn't crossed my mind, I got so caught up in the search for mm that I just never stopped to think.
Thank you so much for pointing this out.
PostPosted: Thu May 30, 2013 9:21 pm
First name: Stuart
Last Name: Gort
This has always been a helpful site for any kind of conversion question.
http://www.onlineconversion.com/
StuMusic
PostPosted: Fri May 31, 2013 4:30 am
...or just type "0.5 inches in mm" in google and it does it for you. Works for almost any conversion you can think of, no third party websites needed. Also handy for quick corrency conversions using standard codes (i.e. 100 USD in GBP provides the conversion).
