It is currently Tue Aug 05, 2025 10:49 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2
PostPosted: Sat May 25, 2013 7:23 pm
I like the cleanness of your work. It looks great!
As to finish, I'm with you there. It's one of the things about building that takes a huge amount of time and patience, but a good finish really sets off all of your hard work. I'm sure you'll do great!
PostPosted: Sun May 26, 2013 11:11 am
First name: Mark
Last Name: Warner
I got it assembled last night and noodled around a bit on it. It sounds great. The passive EMG pickup have a clear, ringing, bright tone, but with the neck pup mixed in, it sounds large and bassy. I'm happy with the tone.
The neck feels good, and the thing isn't terribly heavy...but the body carving has to change. It's just not comfortable when seated. So...I'm going to round over the edges on the mahogany, and leave the sharper lines on the walnut. It'll keep the basic look of the carving, but hopefully make it more comfortable.
PostPosted: Sun May 26, 2013 2:38 pm
I think that will work just fine. I also think you'll find that it will make the design look a lot smoother and sleeker. Can't wait for pics. Hurry up. :mrgreen:
PostPosted: Mon May 27, 2013 12:58 pm
First name: Mark
Last Name: Warner
A couple of photos all put together, wired and working.
PostPosted: Mon May 27, 2013 1:48 pm
I think that's absolutely one of the nicest basses I've seen. To put that into perspective, to me the epitome of bass design begins and ends with a P bass. So for me to say that about as modern a design as yours is saying quite a bit. With finish on, that's gonna be sweet!
PostPosted: Mon May 27, 2013 1:49 pm
By the way, I noticed the Hartke Kickback in the corner. Love 'em!
PostPosted: Mon May 27, 2013 6:15 pm
First name: Mark
Last Name: Warner
Thank you, Mr. Baker. Your words mean a lot!
But alas, it is not a Hartke kickback in the corner. It's just a crappy old Rogue 1x15, 120w practice amp.
Also, I finished rounding the edges. Here's a taste:
The darkish what-looks-like mineral stain is a bit annoying...but...not much I can do about it at this point. C'est la vie.
PostPosted: Mon May 27, 2013 6:26 pm
Sweet! I'm a big fan of a nice roundover (P bass again). Makes the instrument look nice and sleek, makes it feel nice and comfy.
The mineral stain isn't too bad. I have a big, huge mineral stain on an ash tele I built. Didn't show up until after finish. Oh well, it's wood. Doesn't bother me much. Yours will actually look good under finish, IMHO. Kinda like a knot or a darker grain swirl.
PostPosted: Tue May 28, 2013 9:01 am
Last Name: Brumbaugh
That looks great! Love the lines in the carving on the body. Also, the shape is really appealing. Good clean work man.
PostPosted: Mon Jun 10, 2013 10:45 pm
First name: Mark
Last Name: Warner
I put the finish on the body.
- 2 coats of Zinsser's dewaxed shellac sanding sealer, and a shitload of sanding
- 4 coats of rattlecan Minwax Satin Polyurethane
- a light ""sanding" with 4000 grit 3M polishing paper
And I'm pleased as heck:
Front:
Back:
All that's left for the body is to shield the cavities and re-assemble.
The neck still needs some work....a small adjustment to the backside taper and some adjustments to the headstock. Then it'll get the same satin poly finish.
PostPosted: Tue Jun 11, 2013 7:23 am
Lovely work. Love the satin look, and the roundover really gives it a graceful appearance.
PostPosted: Tue Jul 23, 2013 11:18 am
First name: Mark
Last Name: Warner
And she's done.
Frontal:
Headstock:
Body:
Tummy cut:
Neck lamination:
Compound side dots:
Headstock lamination:
To recap:
The body has a Honduran mahogany core with Tropical walnut top and back, with maple veneer accents between. The neck is Hard maple with Tropical walnut stringers and mahogany veneer accents between. The headstock cap is Tropical walnut with a maple and mahogany veneer layers. The fretboard is indian rosewood. The finish is Minwax satin polyurethane. About 5 coats each on the body and neck, with Zinsser's dewaxed shellac sanding sealer on the body.
Frets are medium height nickel steel. The fretboard markers are 1/4" Paua abalone dots. The side-dots are 1/16" aluminum rod inside 3/32" brass tubing. The bridge is a Carvin 5-string bridge with 19mm spacing, the nut is Graphtech Tusq XL, and the tuners are Gotoh GB7s. The pickup are EMG 40HZ passive humbuckers. Controls are passive with master volume, master tone, and pickup blend. It is presently strung with a Circle K Balanced .136ga balanced string set. The sound is evocative of a grand piano. Very bright and ringing, but with a lot of bottom presence.
PostPosted: Wed Jul 24, 2013 8:21 am
Very nice work. It's got a great shape and flow to it. Probably sounds great too.
PostPosted: Thu Aug 01, 2013 11:22 pm
First name: Mark
Last Name: Warner
Thanks, Steve.
I changed the controls a bit today.
I took out the blend knob and replaced it with a simple 3-way toggle switch for pickup selection. Les Paul style. I also replaced the plain black Vol and Tone knobs with abalone inlaid knobs. It adds some color to the body, and I am pretty happy with the results.
PostPosted: Tue Aug 06, 2013 10:39 am
Lovely!
PostPosted: Tue Aug 06, 2013 10:02 pm
First name: Garett
Last Name: Dixon
State: WY
Wow that's sweet [:Y:]
