It is currently Tue Aug 05, 2025 10:52 am
 Post subject: Issues gluing Sapele
PostPosted: Thu Aug 22, 2013 9:54 am
Last Name: Schrider
City: Fort Myers
State: FL
Zip/Postal Code: 33913
Very weird....I'm building my first electric guitar, but I've been working with wood for a long time. I'm putting a 1/4 sapele face on the back and for some reason I'm having trouble gluing the book-matched pieces together. I've always used Titebond, but for some reason the joint won't hold and I can actually just pull the two pieces apart after letting it dry for about 24 hours. Has anyone else had this issue? Any suggestions? Thanks!
 Post subject: Re: Issues gluing Sapele
PostPosted: Thu Aug 22, 2013 10:56 am
How old is your Titebond?
PostPosted: Thu Aug 22, 2013 11:10 am
Last Name: Schrider
City: Fort Myers
State: FL
That is a good question. Probably less than 8 months old. It's Titebond II and it's been working fine on maple.
PostPosted: Thu Aug 22, 2013 11:23 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Sapele is usually not a problem to glue.....try cleaning your freshly joined edges with some DA prior to glue up. Perhaps this piece has a high resin content, that should take care of that.
Brian
PostPosted: Thu Aug 22, 2013 11:26 am
Silly question, Brian: What is DA? I'll be needing some for gluing Teak soon, I'm sure, if it helps with high resin/oil content.
Cheers,
Nick
PostPosted: Thu Aug 22, 2013 11:32 am
Last Name: Schrider
City: Fort Myers
State: FL
Denatured Alcohol.
Thanks, Brian that is a good idea. I will try that and re-post.
PostPosted: Thu Aug 22, 2013 11:40 am
I knew it was a silly question. What's 2+2 again? :)
PostPosted: Thu Aug 22, 2013 11:49 am
Last Name: Schrider
City: Fort Myers
State: FL
No silly questions! Just don't drink the DA!
PostPosted: Thu Aug 22, 2013 11:54 am
Not even with a mixer? :)
PostPosted: Thu Aug 22, 2013 2:47 pm
First name: Stuart
Last Name: Gort
There are no silly questions...just silly assumptions.
When joining Sapele I only use Titebond and have never had problems.
I can only think of two things...bad glue...or contaminated surfaces.
StuMusic
These users thanked the author Stuart Gort for the post: Nick Royle (Fri Aug 23, 2013 2:14 pm)
PostPosted: Fri Aug 23, 2013 1:14 pm
Last Name: Schrider
City: Fort Myers
State: FL
Third attempt on this glue up. Re-jointed, wiped down with DA, and tight clamps. Just a little bit better but still able to bend the joint. I think it's time to give up on this billet! I'm pissed that I already planned to add the thickness on the back and planed down my mahogany body. Now I need to find a maple cap for the back.
PostPosted: Fri Aug 23, 2013 3:46 pm
First name: Jimmy
Last Name: Edwards
City: Boston
State: MA
Next time only try to use Titebond I, with the red label. The other one should have held, but you probably didn't have a clean joint and not enough surface to glue. I know titebond II is not recommended by all the luthiers I have ever seen talk about it.
PostPosted: Sat Aug 24, 2013 6:09 pm
Last Name: Howard
City: Magnolia
State: Delaware
I agree, titebond 1 is preferred for this game. But I have glued more Sapele than I can remember with the type 2 without any problems.
Brian
PostPosted: Wed Aug 28, 2013 1:41 pm
Last Name: Schrider
City: Fort Myers
State: FL
Thank you JEguitars and everyone else. I re-jointed AGAIN and used Titebond Original and it worked. Thank you for the help everybody!
