It is currently Wed Aug 06, 2025 1:13 am
PostPosted: Sat Dec 14, 2013 1:03 am
First name: Travis
Last Name: talley
City: moneta
State: va
Zip/Postal Code: 24121
Ok so obviously im wiring a flying v here. It's a two humbucker, two volume, one tone, three way switch, the cap is a paper and oil .015 uf Emerson. All pots are 500k
My question is about a 50's style wiring diagram vs a newer style as seen on the semor Duncan website.
Basically the neck and bridge volumes are wired exactly the same. The tone however is different.
The old style has the switch output split, one way to the hot output jack, and the other to the cap, then to the 500K pot, and finaly ground.
The newer diagram has the pot first and cap second, then ground.
Does the order of cap and resister make any difference sound wise?
Also does the bridge need to be grounded? The new shows this but the old does not...
Sent from Tapatalk 2
PostPosted: Sat Dec 14, 2013 1:36 am
City: chicagoland
State: illinois
the Seymour Duncan schematics sound like safety modifications...electric guitarists in the past have been electrocuted when their amps malfunctioned and sent 400+ volts to the guitar strings. i don't think the modern configuration should affect tone/output; i'd go with it
PostPosted: Sat Dec 14, 2013 9:10 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I think it's the same as vintage vs newer Les Paul wiring?
If so, here
http://www.seymourduncan.com/tonefiend/ ... bs-or-bfd/
Kevin Looker
I'm not a luthier.
PostPosted: Sat Dec 14, 2013 9:52 am
And, yes - the bridge needs to be grounded (unless you like a lot of hum).
PostPosted: Sat Dec 14, 2013 10:01 am
First name: Eric
Last Name: Reams
City: Hudson
State: FL
Zip/Postal Code: 34667
It shouldn't affect tone either way.
PostPosted: Sun Dec 15, 2013 6:20 am
First name: Travis
Last Name: talley
City: moneta
State: va
Cool, thanks guys. So ground the bridge, and I believe I'll wire in the old school style configuration
