It is currently Sun Aug 03, 2025 9:19 am
 Post subject: ES-339 Construction...
PostPosted: Thu May 08, 2014 2:40 pm
Last Name: Sollod
I've been looking at the Gibson ES-339 and wondered how they make that carved look in the top and back. These guitars are laminated top and backs. I assume that they mold them in some way... Do they use a mold of some kind? Wet the plates...? Any idea how this is done? I would like to build this type of guitar... or a CS-336 type which is a solid top on a routed out mahogany body. I understand this type of construction and carving makes sense. But what about the ES-339? Any thoughts on this? Are planes available? ...Building discussions...?
www.swiftcreekguitars.com
PostPosted: Thu May 08, 2014 3:27 pm
Yes, they are molded - but I do not know Gibson's process for doing so.
PostPosted: Thu May 08, 2014 5:50 pm
First name: D
Last Name: S
Might give Ken Mckay a holler.
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri May 09, 2014 6:37 am
Steve, you are right the ES-339 is a smaller bodied version of the classic ES-335. The construction is also very similar in that the ES-339 uses pressed tops and backs or in the case of Ken McKay's - veneer laminated. Have a look at Ken McKay's current thread http://www.luthiersforum.com/forum/view ... 23&t=43370 that has links to threads on other forums that shows how he builds a ES-335 like guitar. If you follow the threads on the two other forums, they are about the best that I have seen on how a ES style guitar can be luthier built.
PostPosted: Fri May 09, 2014 3:36 pm
Last Name: Killin
Here is a video where they show the body being constructed in the factory in Memphis.
I've been on the tour twice and this video shows more details that you get on the tour. At about 4:37 they start showing the plate\veneer info. There isn't a detail shot of the top and back molds but they show the press that is used.
PostPosted: Fri May 09, 2014 3:47 pm
That's pretty cool. I had no idea the maple block was so large in a 335.
PostPosted: Tue May 13, 2014 7:28 am
Chris, in the ES-335 the soft maple block is 4" wide by about 17+" in length and the thickness of the ribs and weighs just over 3 lbs. Newer ES-335's have a small cut out notch around where the bridge pickup is to facilitate wiring. Lift a 335 then a 330 and you'll feel the weight difference.
I have always wondered what a 335 style guitar would sound like if it had a mahogany or basswood block instead of a maple block.
If you are serious about building this style of guitar, check out the thread on the other site that I referenced above.
PostPosted: Sun May 18, 2014 5:02 pm
First name: James
Last Name: Tonguet
City: Duluth
State: Ga
Zip/Postal Code: 30096
Most of the semi-hollows on the market use laminated pressure molded tops and backs Gibson, Gretsch along with several others.
In regards to the sound of a Mahogany block version , try a CS-356 . I have both the ES-339 and CS-356 .. same body shape /size same pickups , the ES is wonderfully open and has a great vintage vibe, it does tend to feedback easy at the higher end of volume. The CS is a bit different , being a heavily routed mahogany billiet and a carved top is much more like a semi hollow Les Paul .
PostPosted: Wed May 21, 2014 7:25 pm
James, can you hear a difference in the CS with a mahogany block? I am not really familiar with the CS 356 or ES 339 and their construction other than that they are a smaller body version of the ES-335 series.
PostPosted: Sat May 24, 2014 2:28 pm
First name: James
Last Name: Tonguet
City: Duluth
State: Ga
Yes indeed . The CS has better sustain and handles high volume better , it is a bit punchier as well .
I love both , but the CS is in a class by itself . I'd say it is between an ES and Les Paul in tone . I have a '79 LP custom and playing wise they are very close in feel .
I'm happy that both the ES and CS have Ebony fretboards , the newer ones have Richlite ... not my cup of tea.
