It is currently Mon Jul 28, 2025 1:16 am
 Post subject: Heel rabbet
PostPosted: Sun Dec 10, 2017 3:17 pm
First name: Jonny
Last Name: Fifield
Hi Folks
Looking for as many methods as possible for cutting the rabbet in the heel(face)leaving a nice ledge around the edges before flossing??
Please post pics of process if possible [:Y:]
"Practice enough till the results aren't hopes but expectations" forum member Peter Havriluk
PostPosted: Sun Dec 10, 2017 3:21 pm
First name: Brad
Last Name: Combs
I don’t have any pics but a I use a little burr bit in the dremel to cut out most of the material and then a chisel to clean it up.
Actually I do have a pic from a repair of a Uke a couple months back.
I think I first saw the idea of the burr bit from a tutorial here. Probably from Hesh.
Edited to add: You can get a lot closer to the edge than I do. I just get nervous. ;)
These users thanked the author bcombs510 for the post: Hesh (Sun Dec 10, 2017 7:07 pm)
 Post subject: Re: Heel rabbet
PostPosted: Sun Dec 10, 2017 4:15 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
A sharp chisel only takes a few minutes, just dont pull a George!
(Hope you are healing up George)
These users thanked the author Bri for the post: George L (Mon Dec 11, 2017 10:53 am)
PostPosted: Sun Dec 10, 2017 4:21 pm
I use a laminate trimmer with a 1/4" spiral bit. I have the edges marked where the heel shape goes, then route the rabbet staying around 1/8" inside the lines, careful to stay above the inserts height wise. Do thus befor adding the fingerboard so you have full access to the heel.
PostPosted: Sun Dec 10, 2017 6:17 pm
I do like Med. If I had a heel design that had straight sides, I would totally use the router table with a fence.
PostPosted: Sun Dec 10, 2017 7:07 pm
Sharp chisel.
I used to use a bur in a Dr*mel but I prefer a chisel these days.
Be very sure to have the work piece immobilized and not in your lap..... We were just talking about a Luthier who castrated themselves or very nearly did so holding a neck in his lap and using a sharp chisel. Leg vices are great for holding necks down range safely.
PostPosted: Sun Dec 10, 2017 7:52 pm
Chisel for me too, usually 1/4”. I tried the Dremel but also went back to the chisel. I put the neck in the StewMac vise one of my few indispensable shop accoutrements.
PostPosted: Mon Dec 11, 2017 4:31 am
Neck in a vice, sharp chisels
PostPosted: Mon Dec 11, 2017 9:13 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Neck in the vise heel up and a sharp 1/4” chisel. Faster than getting a router out and setting it up.
Bryan Bear PMoMC
PostPosted: Mon Dec 11, 2017 11:01 am
First name: George
City: Seattle
I use a chisel. Just don't ever, EVER, do so without first securing the workpiece in a manner that allows you to employ proper safety techniques. Not ever. Just don't do it, no matter what. Trust me on this one.
George :-)
These users thanked the author George L for the post (total 2): Pmaj7 (Mon Dec 11, 2017 2:41 pm) • Bryan Bear (Mon Dec 11, 2017 11:08 am)
PostPosted: Mon Dec 11, 2017 11:12 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
To George's point. I meant to but forgot to say that I always put the neck blank in the vice with the FB side facing me and the heel cap side away from me. That way, If I feel I need to put my left hand around the blank as I am paring the endgrain, the heel is covering my fingers keeping them far away from a slip.
Bryan Bear PMoMC
Users browsing this forum: Bing [Bot], Durero and 13 guests
cron
