It is currently Sun Sep 21, 2025 4:02 pm
PostPosted: Sun Jan 27, 2019 8:14 pm
Hi All,
In the process of building a Quilted Maple body guitar. I have the body done. The problem I'm having, is the quilted maple is "bumpy". It will not sand flat. I've tried two sets of sides. After bending them, the problem seems to happen. I've used water (not soaked) on the first set, and no water on the second set. No difference. Has anyone experienced this with this wood before?
Thanks in advance.
PostPosted: Sun Jan 27, 2019 9:36 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
How are you sanding? Are you using a hard block?
PostPosted: Sun Jan 27, 2019 10:25 pm
Tried hard rubber block, orbit sanding, all. It is something in the wood. Never had this issue with any other wood.
PostPosted: Mon Jan 28, 2019 6:46 am
First name: Victor
Last Name: Seal
City: Osseo
State: MI - Michigan
Zip/Postal Code: 49266
Keep sanding, by hand with 220 on a wood block about 6 inches long x 2 inches wide. Take your time .long strokes.
PostPosted: Mon Jan 28, 2019 7:19 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Highly figured Maple is known for this quality. The grain reverses that cause the figure also present harder and softer sections of wood. Less sanding pressure will help a lot.
Brian
These users thanked the author B. Howard for the post: Pmaj7 (Mon Jan 28, 2019 9:38 am)
PostPosted: Mon Jan 28, 2019 7:32 pm
First name: Tim
Last Name: Allen
City: San Francisco
Agree about lowering the pressure and the hard block. In terms of a curved, hard sanding block for sides: I read of someone who uses a piece spring steel with adhesive backed sandpaper adhered to it. (Sorry I can't remember who--maybe a luthier who contributed to a Stew-Mac Trade Secrets piece.) I didn't have any spring steel, but I had some Formica-type plastic laminate, which I thinned with my thickness sander till it was springy but could be bent fairly easily to conform to a side. It works well!
I think this would be hard enough to sand out high spots in quilted maple but flexible enough to save a lot of time when sanding sides. Whatever you try, mark the whole side with pencil lines so you can quickly observe if the high spots are being sanded first.
Tim Allen
"Never hurry, never rest."
These users thanked the author TimAllen for the post: CarlD (Mon Jan 28, 2019 9:40 pm)
PostPosted: Tue Jan 29, 2019 12:08 am
Thanks Guys, I'll give it a try.
PostPosted: Tue Jan 29, 2019 6:27 am
Would it help to flood with CA first, outside of course for ventilation?
