It is currently Sun Sep 21, 2025 9:33 am
PostPosted: Mon Sep 23, 2019 7:29 am
Here is the latest Luthier Tips du Jour video. - In this video I show a go bar base idea that I saw in Heidi Litke's shop in Prince Edward, Island.
This video as well as all my other videos are available via my website, http://www.obrienguitars.com/videos , LMI's website or on youtube.
PostPosted: Mon Sep 23, 2019 7:58 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
Nice one robbie PEI is beautiful. But can you shave your braces while its mounted on the barbers chair ??
PostPosted: Mon Sep 23, 2019 9:06 am
Yes it certainly is. I don't see why you couldn't shave your braces in the go bar deck but I usually remove the soundboard to do that.
These users thanked the author Robbie O'Brien for the post: Ernie Kleinman (Mon Sep 23, 2019 2:01 pm)
PostPosted: Tue Sep 24, 2019 2:21 pm
Shave..
Yuk yuk
PostPosted: Wed Sep 25, 2019 7:13 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Robbie i confess it was a bad pun , referring to the barbers chair!
PostPosted: Wed Sep 25, 2019 7:32 am
It might be interesting to make a go bar deck where you could raise the base but leave the top of it stationary to adjust the space between. An automotive floor jack or even a couple of scissor jacks might work for that if you didn't want to spring for the hydraulic barber chair base.
PostPosted: Wed Sep 25, 2019 7:40 am
I’ve been wanting to do this. My idea is to have the 4 supports built in such a way that you either had notches, could insert a dowel or had a sliding mechanism you could tighten in order to give 4 corners of adjustable height. The base would slip out ... you’d adjust it and slip the base back in.
PostPosted: Wed Sep 25, 2019 9:02 am
haha, I completely missed that one!
PostPosted: Wed Sep 25, 2019 10:19 am
It would be good for trimming brace ends. Clipping strings to.
PostPosted: Wed Sep 25, 2019 6:41 pm
Not a gobar deck, but I did this for my old 1950s Delta bench top drill press. There is no rack and pinion for the table height, so loosening the table adjust bolt resulted in the heavy cast iron table crashing to the base every time. A cheap $15 harbor freight scissor jack is nothing I would ever trust to lift a car, but it works great as an aftermarket lift on a drill press table.
These users thanked the author Paul Micheletti for the post: Clay S. (Wed Sep 25, 2019 6:49 pm)
PostPosted: Wed Sep 25, 2019 8:00 pm
Thanks Paul,
I have a bench top Delta radial drill press that lacks the rack and pinion. The scissor jack sounds like a good option. The older you get the more of a struggle it becomes. I would pile up scrap to raise the work piece rather than fight with raising the table, but jacking it up would be the better (and safer) way to go.
Does anyone know how to change the chuck on a Delta radial press?
