It is currently Sat Sep 20, 2025 9:49 pm
PostPosted: Tue May 19, 2020 1:34 pm
Last Name: Giltzow
City: Boise
State: Idaho
Zip/Postal Code: 83709
Hi All
I do not usually use plastic bindings, but I am using white (Stewart McDonald ABS bindings) on an East Indian Rosewood B & S guitar. After scraping them flush and sanding I am getting a lot of EIR dust coloring in the white plastic. I am sanding to 220. Should I go finer on the grit? Or should I use Naptha, acetone or lacquer thinner to get the coloring out. How do you handle that? Thanks in advance for any help - Mike G
guitarsbygiltzow.com
PostPosted: Tue May 19, 2020 2:23 pm
First name: Chuck
Last Name: Skarsaune
City: Butler
Scrape -just- the binding. Don't sand after scraping.
These users thanked the author Skarsaune for the post: giltzow (Tue May 19, 2020 3:33 pm)
PostPosted: Tue May 19, 2020 3:25 pm
I sand white plastic bindings up to 320 grit in order to keep sawdust from sticking. Then a blast of compressed air should get it clear. Scraping binding (especially the side of it) is challenging to get a mar free surface.
These users thanked the author Barry Daniels for the post: giltzow (Tue May 19, 2020 3:32 pm)
PostPosted: Tue May 19, 2020 3:37 pm
Sanding to a finer grit as Barry suggested usually works. If you do decide to try scraping one thing I have found to work is to use a single edge razor blade and "round" the ends with a sharpening stone or sandpaper. That eliminates the sharp points that can create deep scratches in the plastic (or wood). I use plastic on most of the instruments I build.
These users thanked the author Clay S. for the post: giltzow (Wed May 20, 2020 11:57 am)
Users browsing this forum: No registered users and 49 guests
