It is currently Sat Sep 20, 2025 7:00 pm
PostPosted: Fri Jul 10, 2020 2:24 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I wonder has anyone ever used safety wire for bolt on necks?
It's basically a bolt with a hole drilled through the head, and a wire is threaded through that hole and twisted together, and then anchored to a neighboring bolt in such a way that the bolt could never possibly twist loose.
Because split washers do not work, belleville washers work but it still does not prevent the bolt from turning by itself due to vibrations...
Typhoon Guitars
PostPosted: Fri Jul 10, 2020 3:07 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I haven't heard of a safety wire being used, but it seems like Loctite Blue or Purple would be a much simpler solution if one was worried about the bolts loosening.
These users thanked the author J De Rocher for the post: Colin North (Fri Jul 10, 2020 3:48 pm)
PostPosted: Fri Jul 10, 2020 3:41 pm
Anyone in aircraft can tell you safety wire is about keeping the nut from turning, not about keeping tension ON the nut. Besides, how do you propose we do this, Tai? You want the nut or the bolt sticking out of the guitar? Wouldn't a cotter pin work just as well? It's dang sure quicker than tying the safety wire. Let's face it, it's about as practical as roofing your house with chain link fence.
These users thanked the author Chris Pile for the post: CraigG (Sun Jul 12, 2020 11:50 am)
PostPosted: Fri Jul 10, 2020 3:47 pm
Chris Pile wrote:
.............. Let's face it, it's about as practical as roofing your house with chain link fence.
laughing6-hehe laughing6-hehe laughing6-hehe
PostPosted: Fri Jul 10, 2020 3:59 pm
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
I've used crinkle/wave spring washers - no loose bolts so far.
PostPosted: Fri Jul 10, 2020 4:51 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Is this even a problem?
And why don’t split washers work?
B
PostPosted: Fri Jul 10, 2020 6:53 pm
First name: Hans
Last Name: Mattes
City: Petaluma
Zip/Postal Code: 94952
I only wish that all "problems" were this unnecessary to solve.
PostPosted: Fri Jul 10, 2020 7:44 pm
First name: Freeman
Last Name: Keller
I use belleville washers. They work just fine
However, fwiw, I have encountered three Art and Lutherie family guitars which have bolt on butt joined necks that have had loose bolts. Snugging them up fixed everything, not hard to do.
PostPosted: Fri Jul 10, 2020 7:53 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I use belleville washers as well. The heel blocks both shrink and expand due to humidity. The belleville washer have a wider diameter than the spit washers. I felt the larger diameter and the spring in the belleville washers makes them less likely to be impressed into the block.
PostPosted: Fri Jul 10, 2020 9:57 pm
Like John, I am more concerned with wood movement. I think having a bolt that is easily accessed and tighten-able is more of a priority than immobilizing the bolt.
PostPosted: Sat Jul 11, 2020 7:33 am
I have used the split washers (without problems) but for the last several builds have moved over to the belleville washers for the same reason as John.
Never had a problem, but my guitars are not necessarily subjected to big humidity swings like there may be in Taiwan.
PostPosted: Sat Jul 11, 2020 8:19 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I watched a video on YouTube about how safety wire is installed. Then I thought about what it would take to do that, and later remove it for repair work, inside the body of an acoustic guitar. No, thanks. Even if it did some good (which seems to be in question), it looks like a hard thing to do and undo from inside the box.
PostPosted: Sat Jul 11, 2020 9:06 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I have continued to use the bolts that John Hall used on a couple of kits I bought from him. They have a large head and are tightened with an Allen wrench. The size of the head bearing on the wood might have something to do with it, but in the 9 years I have had guitars out there with these bolts, nothing has loosened. Just an amateur working on #9.
PostPosted: Sat Jul 11, 2020 10:19 am
First name: John "jd"
City: Santa Barbara
Trying to picture using safety wire pliers inside a guitar...
No need to wire a dovetail laughing6-hehe
PostPosted: Sat Jul 11, 2020 4:31 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I think maybe the idea of safety wire is a solution searching for a problem. There's reasons nobody does it, (1) it's not needed and (2) it would be almost impossible to do inside the confines of a guitar body. I've done plenty of safety wire on aircraft, and I don't propose to do it where it's not needed.
Peter Havriluk
PostPosted: Sat Jul 11, 2020 6:23 pm
you can lock the bolt all you want it is the shrinkage of the wood that will make the bolt come loose
PostPosted: Sat Jul 11, 2020 9:02 pm
I agree, I use the furniture bolt shown above with no washer. Only loosening I have seen is if the guitar dried out and the headblock shrunk.
PostPosted: Mon Jul 13, 2020 5:45 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I used 10-32 fine thread lag screws when I built with bolt-on necks, coupled with large flat washers. These lag screws are commonly used on banjos. I faced the mahogany neck block with a vertical strip of hard maple for the washers to bear against. I put a 3/8" maple dowel in the neck heel for extra strength. Collings also does the dowel, but I didn't know that at the time. I see no reason to use the more common 1/4" bolt, since a #10 screw (or even a #8) is plenty strong enough, and much lighter. The fine threads are better for avoiding the loosening, but you still have wood shrinkage to deal with. That can be minimized with proper seasoning, or even torrefaction.
My bolt-on necks were constructed at least 30 years ago, and I don't recall ever having to retighten a bolt, though one of them was reset about 7 years ago.
These users thanked the author John Arnold for the post: Pmaj7 (Sun Jul 19, 2020 2:43 am)
Users browsing this forum: No registered users and 108 guests
