It is currently Sat Sep 20, 2025 9:39 pm
 Post subject: Martin neck block cover
PostPosted: Fri Aug 07, 2020 5:42 pm
First name: Brad
Last Name: Combs
Anyone know what this is typically put on with? I suspect it has to be easily removed without ruining it?
Does it actually notch into the holes for the bolts or just stuck on there with something that releases easily?
Note: Pic is not my instrument, image stolen from google. :)
Brad
PostPosted: Fri Aug 07, 2020 5:58 pm
Last one I had like that was held with double sided tape, and wasn't too difficult to remove in one piece (had to tighten a neck bolt)
These users thanked the author Colin North for the post: bcombs510 (Fri Aug 07, 2020 6:21 pm)
PostPosted: Sat Aug 08, 2020 6:31 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Yep, those serial number plates are held on with double sided tape - you know the sort with the thin foam core. You can get a thin blade in behind it, or drip something like naptha down to loosen the tape and then pry it off.
These users thanked the author Mark Mc for the post: bcombs510 (Sat Aug 08, 2020 7:24 am)
PostPosted: Sat Aug 08, 2020 12:28 pm
First name: Brad
Last Name: Combs
Thanks to you both. I picked up a branding iron with my logo in order to make plates that cover up the hardware in the neck block.
I’m using hanger bolts with cap nuts (thanks to Rod True for the recommendation of the cap nuts!!). I picked up a nice reverse counterbore from McMaster Carr and it makes easy work to countersink the cap nut. I used double stick tape for the plate. Worked fine and I was able to easily remove on a test plate.
A small detail but it does look nice through the soundhole.
Brad
PostPosted: Sat Aug 08, 2020 2:23 pm
Nice, neat, professional touch.
These users thanked the author Colin North for the post: bcombs510 (Sat Aug 08, 2020 2:45 pm)
PostPosted: Sun Aug 09, 2020 8:49 pm
First name: Josh
Looks good!
These users thanked the author joshnothing for the post: bcombs510 (Sun Aug 09, 2020 8:54 pm)
PostPosted: Mon Aug 10, 2020 7:32 am
That does look good. Nicely done Brad.
These users thanked the author SteveSmith for the post: bcombs510 (Mon Aug 10, 2020 3:14 pm)
PostPosted: Mon Aug 10, 2020 9:01 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Very elegant, Brad. I'm curious: Could you also use rare earth magnets glued to the cover plate, right at the bolt holes? They could grab onto the cap nuts.
These users thanked the author doncaparker for the post: bcombs510 (Mon Aug 10, 2020 3:14 pm)
PostPosted: Mon Aug 10, 2020 10:05 am
Hey Brad,
You just raised the bar! Now we are all going to have to do it ! gaah laughing6-hehe
It looks real nice, kudos!
These users thanked the author Clay S. for the post: bcombs510 (Mon Aug 10, 2020 3:14 pm)
PostPosted: Mon Aug 10, 2020 3:08 pm
I agree that looks cool but... Why? I remember back in the 90's the explosive discussions of Taylor bolt on versus the traditional dove tail and I figured Taylor covered the bolts because they thought it would look bad or something. It just makes it harder to reset the neck or tighten the bolts. So is there another reason I am missing for doing this type of thing other then cosmetics?
These users thanked the author jfmckenna for the post: bcombs510 (Mon Aug 10, 2020 3:14 pm)
PostPosted: Mon Aug 10, 2020 3:14 pm
First name: Brad
Last Name: Combs
100% cosmetic. :)
I played a luthier built guitar at Emerald City guitars about a year and a half ago (can't recall the name, the logo was a dolphin) and there was logo like that on the block and it looked nice through the side sound port.
PostPosted: Mon Aug 10, 2020 3:15 pm
First name: Brad
Last Name: Combs
This is a great idea, I will try that. Would make removal a snap. ;)
PostPosted: Mon Aug 10, 2020 4:01 pm
Last Name: Parker
City: Charleston
Glad you like the magnet idea! I have actually thought about doing it this way, if I go back to bolted necks.
I figure the best way to do the magnet thing is to drill very shallow pockets for the magnets in the cover plate. I've had some situations where the glue didn't hold my magnets as well as I wanted if I just glued them to the flat surface, but if I drilled little pockets for the magnets with a Forstner bit, they held on really well.
Of course, I also use pockets for the magnets that have them fully inset (flush with the surface) for things like vise jaw inserts. But I think you should want the magnets sticking out a bit, into the bolt hole.
These users thanked the author doncaparker for the post: bcombs510 (Mon Aug 10, 2020 4:02 pm)
PostPosted: Tue Aug 11, 2020 7:02 am
I think another reason for making it less accessible is to keep the end user from fiddling with the bolts. Also if you do a less than perfect job of centering the bolts in the block it hides that well. bliss
These users thanked the author Clay S. for the post: bcombs510 (Tue Aug 11, 2020 7:09 am)
PostPosted: Tue Aug 11, 2020 7:57 am
First name: Mark
Last Name: McLean
City: Sydney
I have used magnets to set the truss rod cover over the truss rod adjusting socket (@ headstock, Gibson style). It looks neater to not have any screws there.
These users thanked the author Mark Mc for the post: bcombs510 (Tue Aug 11, 2020 8:28 am)
Users browsing this forum: No registered users and 51 guests
cron
