It is currently Sat Sep 20, 2025 5:22 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2
 Post subject: Re: Frankenstein build
PostPosted: Sun Aug 09, 2020 4:50 pm
Looks good!
Where’d you get the oak?
PostPosted: Sun Aug 09, 2020 5:47 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I like that body shape a lot. It's looking good. I'm a fan of using bloodwood for binding and it looks great under finish. It looks like you got the neck to match up nicely with the cutaway. What are your plans for the edge at the end of the side in the cutaway?
PostPosted: Sun Aug 09, 2020 7:11 pm
meddlingfool wrote:
Looks good!
Aaron :) gotta day I’ve gotten most of my sets from him
PostPosted: Sun Aug 09, 2020 7:13 pm
I have to say I wish I had bound that edge before doing the binding. It this point I’m not EXACTLY sure what I can do.
I suppose I could bind it on the top and side, but it would be a high risk maneuver at this point
Maybe I’ll use krylon and just paint it black haha
PostPosted: Sun Aug 09, 2020 9:02 pm
Meh I decided why not. Using a sharp chisel I recessed slot for a binding length. I’ll plane it off eleven w the top. At least it will be somewhat of a finished edge.
PostPosted: Sun Aug 09, 2020 9:09 pm
First name: Jay
City: Bothell
State: Washington
That was what I was thinking of suggesting. Looking good!
These users thanked the author J De Rocher for the post: SnowManSnow (Sun Aug 09, 2020 10:52 pm)
PostPosted: Mon Aug 10, 2020 10:08 am
[:Y:]
PostPosted: Mon Aug 10, 2020 1:47 pm
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
I missing something here. Why would the back crack from bending? Why are you bending the back?
Hutch
PostPosted: Mon Aug 10, 2020 1:48 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I like the way you fit the heel cap into the angle of the center section. Nice touch.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: SnowManSnow (Mon Aug 10, 2020 3:54 pm)
PostPosted: Mon Aug 10, 2020 3:54 pm
No no:) the back wedge was a katalox set. I cracked the side bending the cut away and soni sides the katalox as the back center.
The OAK, cracked for no apparent reason on the back. So I cut the crack out, and inserted the katalox and marched on:)
Thanks, believe it or not it was intentional haha
PostPosted: Mon Aug 10, 2020 5:12 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I might have to borrow that some day if I ever do a three piece back! Right now, I’m working on a cherry guitar with a sapwood centerline. I made a cherry neck with a tapered maple lamination trying to follow the line of the sapwood across the back and all the way up to the peghead. Now I wish I had integrated the heel cap too.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: SnowManSnow (Mon Aug 10, 2020 5:41 pm)
PostPosted: Mon Aug 10, 2020 5:19 pm
Sheesh Bryan, that's gonna be a wiiide fretboard! beehive
PostPosted: Mon Aug 10, 2020 5:25 pm
First name: Jay
City: Bothell
State: Washington
Bryan - That tapered lamination in the neck is very cool, especially in how it extends the same general taper of the sapwood into the neck. Nice! How hard was it to pull that off?
These users thanked the author J De Rocher for the post: Bryan Bear (Mon Aug 10, 2020 9:43 pm)
PostPosted: Mon Aug 10, 2020 5:41 pm
That will be a noticeable feature!
These users thanked the author SnowManSnow for the post: Bryan Bear (Mon Aug 10, 2020 9:43 pm)
 Post subject: Frankenstein build
PostPosted: Mon Aug 10, 2020 9:22 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Yeah, I ended up trimming the fretboard width down :)
It wasn’t hard to pull off but it was a bit of a pain. Part of the issue was that I also have a rosewood arch between the neck shaft and the heel. That meant I had to make a heel block with the same taper and get it all to line up when I glued and clamped it. In the above picture you can see that the heel block is really long. It was easier to make a long tapered block than a short or for some reason. I planed the tapered maple parts matching the taper of the fretboard so the cherry parts are parallel in the final carve. I clamped it all up with wedged cauls then. I had to plane a reference edge so I could plow the truss rod slot with a plow plane. Keeping the center line was just a matter of measuring the maple and dividing by two.
I was lucky that the sapwood section tapered close to the natural neck taper so it made everything easier. The end wedge carries the same effect up to the top. I ended up darkening the maple a bit with coffee carefully brushed on to match the sapwood. Image
Bryan Bear PMoMC
PostPosted: Fri Aug 21, 2020 10:54 pm
Finally got around to pore filling
Used good Ol ZPoxy.
This is following the fill and then expo wash coat to even out everything
PostPosted: Sat Aug 22, 2020 12:24 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Looking good.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: SnowManSnow (Mon Aug 24, 2020 4:25 pm)
PostPosted: Mon Aug 24, 2020 4:23 pm
EM6000 going on
PostPosted: Mon Aug 24, 2020 5:18 pm
First name: Jay
City: Bothell
State: Washington
The bloodwood binding is looking really good and it looks like it's a good combination with the zebrawood.
PostPosted: Mon Aug 24, 2020 6:14 pm
It’s oak
PostPosted: Mon Aug 24, 2020 6:35 pm
First name: Jay
City: Bothell
State: Washington
SnowManSnow wrote:
It’s oak
Right, oak. Sorry about that. I guess I had zebrawood on the brain from another thread.
PostPosted: Mon Aug 24, 2020 7:08 pm
A few pre cure shots.
No real fretwork or anything has yet occurred
PostPosted: Thu Sep 03, 2020 3:43 pm
She’s done:)
Not perfect but right away sounds really MUCH bigger than I thought she would.
I LIKE oak as a tonewood!
Learned so much on this one.
-first cut away
-FINALLY got a neck right
- learned more about em6000
Super enjoyable build;)
Here are some close out pics
PostPosted: Thu Sep 03, 2020 11:14 pm
First name: Jay
City: Bothell
State: Washington
That's a great looking instrument. Congratulations on saving it. Looks like it was well worth it.
These users thanked the author J De Rocher for the post: SnowManSnow (Sat Sep 05, 2020 7:36 pm)
