It is currently Sat Sep 20, 2025 6:50 pm
 Post subject: Tabbed top and back
PostPosted: Thu Nov 05, 2020 9:21 am
First name: Brad
Last Name: Combs
Hello,
Have any of you gone through the trouble of setting up to use a tabbed top / back with your molds? I’m thinking like the Martin tops:
I have access to a CNC and was thinking about making new molds with the necessary alignment pins and cutting out the profile for my tops / backs to align with the pins. I’m not really trying to solve a problem per se, just wanting to play with the CNC. :)
For those that use this type of locating setup is it worth the effort? Could you share any pics of your setup?
Thanks!
Brad
 Post subject: Re: Tabbed top and back
PostPosted: Thu Nov 05, 2020 11:36 am
Hi Brad,
I do a variation of this, no cnc. I'll try to post a pic this evening.
These users thanked the author Jim Watts for the post: bcombs510 (Thu Nov 05, 2020 12:25 pm)
PostPosted: Thu Nov 05, 2020 12:10 pm
No CNC here either but the tabs are still useful. What I do has nothing to do with the mold though. Tops get tabs at the waist and one near the tail block . Backs get tabs near the neck and tail blocks. I use the tabs at the waist and small flat head screws to lock the top to my work board when I do rosettes. I CA a scrap block on the sides near the tail block tab so I can use a 1/8" pin to index the top, at the neck I just drill a hole into the neck block. I do the same on the back, two tabs and two blocks CA'd to the sides. Takes longer to explain than to do it and it lets me make sure the top and back are glued on exactly where I want them.
These users thanked the author SteveSmith for the post (total 2): Pmaj7 (Sun Nov 08, 2020 5:39 pm) • bcombs510 (Thu Nov 05, 2020 12:25 pm)
PostPosted: Thu Nov 05, 2020 12:38 pm
I use halos that way I can set the notches in the rim as well as setting braces .
PostPosted: Thu Nov 05, 2020 1:12 pm
John, my method allows me to mark the brace notches very accurately too (I'm using 1/8" x 1 1/2" stainless pins).
I have to admit I'm not sure what you mean by halos, can you explain a bit?
PostPosted: Thu Nov 05, 2020 1:18 pm
A number of violin plates show small alignment pegs that go into the top and bottom blocks. Somehow that never caught on with guitars.
PostPosted: Thu Nov 05, 2020 2:16 pm
City: Escondido
Zip/Postal Code: 92029
I'm not sure I know what "halos" are in this context. I lost mine years ago. Can you show a pic of what you mean.
PostPosted: Thu Nov 05, 2020 3:52 pm
I should of known, every time I think I thought of something cool I find out it's been done by someone else for two hundred years - ha!
PostPosted: Thu Nov 05, 2020 6:14 pm
https://www.youtube.com/watch?v=i9ubMJXhjq0&t=5s
Martin uses this technique in the top bracing department
I use these same halos to then mark the notch locations in the kerfed lining.
makes for more accurate placement
These users thanked the author bluescreek for the post (total 3): bcombs510 (Fri Nov 06, 2020 7:31 am) • TimAllen (Fri Nov 06, 2020 12:48 am) • SteveSmith (Thu Nov 05, 2020 7:37 pm)
PostPosted: Thu Nov 05, 2020 9:11 pm
This is where I think they’d be useful, too.
PostPosted: Fri Nov 06, 2020 8:11 am
it sure helps with fit and finish for sure.
PostPosted: Fri Nov 06, 2020 9:18 am
That makes sense John, thanks for explaining that.
Users browsing this forum: Cal Maier, Tom G and 61 guests
