It is currently Sat Apr 18, 2026 11:28 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Mon Aug 02, 2021 7:17 pm
Last Name: Ionta
City: Hopkinton
State: Massachusetts
Zip/Postal Code: 01748
Barry Daniels wrote:
One solution may not be appropriate in all cases and it may need to be modified depending on the type and extent of the break. A backstrap is good if the crack does not go all the way through into the nut slot or headstock veneer. It the headstock veneer is compromised, a backstrap may not be enough. A break through a Gibson truss rod nut recess may be best repaired with splines. Some breaks go directly across the grain which may need multiple techniques, like the Epi I mentioned in a previous thread.
The last time I used splines I used short and small carbon fiber bars instead of the normal wood splines.
Barry, where did you get the cf bars? I’ve seen several sources for 18” or 24” lengths but wonder if someone sells them already cut into short lengths.
PostPosted: Mon Aug 02, 2021 8:28 pm
I just cut them from long bars that I use for neck reinforcement. I like 1/4" high by 0.093" wide bars from Dragon Plate.
These users thanked the author Barry Daniels for the post: bionta (Mon Aug 02, 2021 9:55 pm)
PostPosted: Tue Aug 03, 2021 9:03 am
Last Name: Ionta
City: Hopkinton
Thanks Barry. Two more quick questions:
- Router bit - 3/32" ?
- What do you use for adhesive?
PostPosted: Tue Aug 03, 2021 12:21 pm
Yes, 3/32" router bit. West Systems epoxy with microfiber additive.
PostPosted: Tue Aug 03, 2021 1:54 pm
Last Name: Ionta
City: Hopkinton
Thanks again! Filing this away …
Users browsing this forum: No registered users and 433 guests
