It is currently Fri Sep 19, 2025 3:14 pm
 Post subject: Numero Dos....
PostPosted: Sun Sep 26, 2021 3:15 pm
First name: Roy L
Last Name: Smith
City: Apache Junction
State: Az
Zip/Postal Code: 85119
Earlier this summer I was asking about wet sanding and polishing process, as well as how best to deal with sanding thru on the edge.
Thanks to all the good responses I got, I finally managed to finish it, and, at least compared to the finish on my first, this one looks much much better. It has a cedar top, clearly louder than my first. Still need to refine the set-up/neck angle, but it sounds very nice to me. Just wanted to say thanks and show a pix. Roy
 Post subject: Re: Numero Dos....
PostPosted: Sun Sep 26, 2021 3:50 pm
Nice color combos...
These users thanked the author meddlingfool for the post: flemsmith (Sun Sep 26, 2021 3:52 pm)
PostPosted: Sun Sep 26, 2021 6:49 pm
Looks good,
Did you make the top purfling?
PostPosted: Sun Sep 26, 2021 10:45 pm
First name: Roy L
Last Name: Smith
State: Az
Heck no, it's LMI
PostPosted: Sun Sep 26, 2021 11:08 pm
Last Name: Colbert
City: Anacortes
It looks very nice!
I’d like to see more pictures please!
M
PostPosted: Mon Sep 27, 2021 2:29 am
Nice one Roy, thanks for posting a fine looking guitar.
PostPosted: Mon Sep 27, 2021 6:51 am
Looks good. Congrats on finishing #2. More photos?
PostPosted: Mon Sep 27, 2021 10:29 am
First name: Roy L
Last Name: Smith
State: Az
Few more pix...Although this is the second guitar I've built, the first was a John Hall kit, so much of the work was already done when I started. This time I bent the sides, made the mahog binding, and made the neck myself. More to learn, and more chances to make mistakes, but my confidence is higher for the next one. (I think.)
Sometimes it's the simplest things that get messed up. I already had the initials embedded in the head plate, and could tell I needed to move them up about an 1/8" inch to be decently centered before I glued it on. Damned if I didn't accidentally move them down.
The back looks to me like it needed a center strip that I didn't think it would need....
This one has the same blushing thru the lacquer problem as the first (same process), so far it's not as egregious. And I'm planning to use the West epoxy for pore fill next time and shellack all the corners, joints and rosette. Thanks for the interest, you can bet I'll want to ask a few more questions as I move forward on number 3. Roy
PostPosted: Mon Sep 27, 2021 10:53 am
Last Name: Colbert
City: Anacortes
Nice slot-head - ambitious for a second guitar, I didn’t do my first slot-head until around #60.
Welcome to the addiction! M
PostPosted: Mon Sep 27, 2021 11:02 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Looks great! Well done.
Bryan Bear PMoMC
PostPosted: Mon Sep 27, 2021 12:13 pm
First name: Freeman
Last Name: Keller
Look good, Roy.
PostPosted: Tue Sep 28, 2021 10:54 am
First name: Roy L
Last Name: Smith
State: Az
Another finish question....although this one came out better than anything else I've done, (two retops and one kit build) and reflects nicely, when I look closely out in the sun, I can see the sanding marks pretty clearly. All seem to be the same grit; I went to 1500 before I started polishing. It was looking good enough at that stage that I skipped past the first polish with Stew Mac coarse, starting with Meguire Ultra Cut. I know I can get better, just not sure the best way to go about it...finer wet sanding? Stick with 'coarse' first polish? Both? It's nitro if that's not obvious. Thanks for inputs. Roy
PostPosted: Tue Sep 28, 2021 5:23 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
B -utiful
Mike Collins
These users thanked the author Mike Collins for the post: flemsmith (Sat Oct 02, 2021 3:50 pm)
PostPosted: Tue Sep 28, 2021 6:23 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
A while ago I received training in removing scratches from transparent acrylic aircraft windshields. Short version: Start with the coarsest grit sanding in one direction. Remove scratches. Proceed through ever-finer grits until done, each time sanding 90 degrees from the direction of the prior grit until the preceding grit's scratches disappear. That way the person doing the work doesn't go to finer grits until all evidence of the prior grit disappears.
That way there's no mystery to why I can still see scratches, I'm sanding with 1600 grit sandpaper, but there were 600-grit scratches still present. Those scratches are not going away until I back up and sand them out with 800-grit sandpaper and keep climbing the ladder.
Of course, acrylic's got no grain...
Peter Havriluk
These users thanked the author phavriluk for the post: flemsmith (Sat Oct 02, 2021 3:51 pm)
PostPosted: Wed Sep 29, 2021 9:37 am
For sanding finishes I like to use micron papers. The granules are more uniformly sized than on most types of sandpaper. Trizact material is also a good way to go for the final "sanding" of finishes and is often used to polish plastic headlight housings and solid surface materials.
These users thanked the author Clay S. for the post: flemsmith (Sat Oct 02, 2021 3:53 pm)
Users browsing this forum: JimWomack and 32 guests
