It is currently Fri Sep 19, 2025 10:58 am
Post new topic Reply to topic  [ 197 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Tue Nov 16, 2021 1:42 pm
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
I wonder what caused it to lock up like that.
Hutch
PostPosted: Wed Nov 17, 2021 11:13 am
Speaking of cutting binding, here is something I posted here years ago that has served me well for cutting binding to length with a razor saw. Easy to make for custom widths. Just superglue two pieces of wood to a thin piece of plywood the proper width apart for a snug fit of the binding and cut a slot for an Xacto razor saw at 90 degrees. I use that little Xacto miter box to cut the slot.
Imageimage-13_med by Terence Kennedy, on Flickr
Imageimage-14_med by Terence Kennedy, on Flickr
These users thanked the author Terence Kennedy for the post (total 7): Aaron O (Sat Jan 22, 2022 5:24 am) • Robbie_McD (Fri Nov 19, 2021 5:38 pm) • Hesh (Fri Nov 19, 2021 8:33 am) • DannyV (Thu Nov 18, 2021 9:26 am) • joshnothing (Thu Nov 18, 2021 5:53 am) • Bryan Bear (Wed Nov 17, 2021 4:49 pm) • Chris Pile (Wed Nov 17, 2021 11:42 am)
PostPosted: Wed Nov 17, 2021 11:20 am
First name: Richard
City: Warwick
State: RI
Sweet!
Hutch
PostPosted: Thu Nov 18, 2021 8:34 am
Well, I used 2 of the tips yesterday. Using a dummy piece of plastic binding when gluing the purfling in separately from the binding. I have struggled in the past with taping the purfling tightly. I was like, "Why didn't I think of this?"
The other is cleaning out the inside corner of the binding channel with a razor knife blade. I might add that using a 3-corner file also helps to smooth out the routing edges and back cut the inside corner at the same time. It will work on everything but the inside curves, like the waist or a cut a way. I still take the inside corner off the binding. Old habits.......
I also use a small 6" flexible metal ruler, with self adhesive sand paper to clean up the channel and smooth the routing lines. Bending it lets you work the inside curves. You can smooth the sides and the bottoms of the channel with it.
These users thanked the author guitarjtb for the post (total 2): Hesh (Fri Nov 19, 2021 8:34 am) • joshnothing (Fri Nov 19, 2021 4:58 am)
PostPosted: Thu Nov 18, 2021 11:25 am
Here's a simple little trick. When you want to protect the FB edge or head stock when filing a nut (always a good idea imho) you reach something like a ruler under the strings, stick tape to it, then feed it back through.
These users thanked the author jfmckenna for the post (total 4): Durero (Sat Nov 20, 2021 5:28 pm) • Robbie_McD (Fri Nov 19, 2021 5:38 pm) • Hesh (Fri Nov 19, 2021 8:34 am) • Chris Pile (Thu Nov 18, 2021 4:17 pm)
PostPosted: Thu Nov 18, 2021 11:32 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Nice suggestion. Sure beats pushing on a piece of tape. Thanks.
Peter Havriluk
These users thanked the author phavriluk for the post: kjaffrey (Thu Nov 18, 2021 10:12 pm)
PostPosted: Thu Nov 18, 2021 2:49 pm
My tip of the day is for married guys. So if you’re married make sure your wife either has her own closet or at least has her own side. Well then you acquire as many coveralls and overalls as you can then hang in such way you have no folds and the legs touch the floor. This makes an excellent place to hide new guitars behind until you can gently introduce them into your rotation!
These users thanked the author Slim for the post (total 4): Hesh (Fri Nov 19, 2021 8:35 am) • Smylight (Thu Nov 18, 2021 10:46 pm) • jfmckenna (Thu Nov 18, 2021 4:45 pm) • Chris Pile (Thu Nov 18, 2021 4:18 pm)
PostPosted: Thu Nov 18, 2021 4:18 pm
You stole my thunder. I was gonna take a picture and post it this afternoon....
These users thanked the author Chris Pile for the post: jfmckenna (Thu Nov 18, 2021 4:44 pm)
PostPosted: Thu Nov 18, 2021 4:45 pm
I'm running out of space for wood, any suggestions? laughing6-hehe
PostPosted: Thu Nov 18, 2021 4:52 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Turn your excess wood into guitars, then hide them behind your coveralls. . .
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post (total 3): Hesh (Fri Nov 19, 2021 8:35 am) • Smylight (Thu Nov 18, 2021 10:46 pm) • jfmckenna (Thu Nov 18, 2021 4:55 pm)
PostPosted: Thu Nov 18, 2021 9:01 pm
Funny you should ask I actually have some some spruce & walnut stashed behind my wife’s piano! Also don’t forget most dressers have more room under them than you realize especially the ones that have the decorative trim along the bottom bliss
These users thanked the author Slim for the post: jfmckenna (Fri Nov 19, 2021 9:16 am)
PostPosted: Fri Nov 19, 2021 5:00 am
First name: Josh
do they make coveralls large enough to conceal woodworking machinery?
These users thanked the author joshnothing for the post (total 2): jfmckenna (Fri Nov 19, 2021 9:16 am) • Hesh (Fri Nov 19, 2021 8:36 am)
PostPosted: Sat Nov 20, 2021 9:25 pm
I like to use four blocks to locate the fingerboard onto the neck blank, I find it easier than the pins pins I used to use. I wax the side of the block that goes against the fingerboard making them easy to remove, and just a light dab of glue.
These users thanked the author Jim Watts for the post (total 3): Bryan Bear (Sun Nov 21, 2021 7:49 pm) • jfmckenna (Sun Nov 21, 2021 8:24 am) • Hesh (Sun Nov 21, 2021 3:40 am)
PostPosted: Sun Nov 21, 2021 7:52 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Wow, that is exactly what I do right down to the wax! I use offcuts of my wood binding so it is not as tall as the fretboard. As I am setting the neck and checking for centerline alignment, I can lay the straightedge along the fretboard sides without the binding scraps getting in the way.
I do the rough neck set before the fretboard is attached. It is simple to just slide the board in and out of place because of the taper.
Bryan Bear PMoMC
PostPosted: Sun Nov 21, 2021 9:45 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I'm curious about the sequence of steps you use. It appears that you would cut the excess width off the neck after gluing the fretboard on. If so, how do you deal with the radiused surface of the fretboard? Are the blocks taller than the fretboard and all the same thickness so that they provide level support and keep the neck from rocking side to side while running the neck through the bandsaw? Or is something else going on?
I've always cut the excess off before gluing the fretboard on mainly because the top surface of the neck is flat without the fretboard on which makes for accurate cutting on the bandsaw.
PostPosted: Sun Nov 21, 2021 9:59 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I can’t speak for Jim, but cut the neck to the fretboard shape with various hand tools. Once it is close, I use a chisel resting on the fretboard edge to cut/pare the rest of the neck wood flush. The. The neck gets carved from there.
Bryan Bear PMoMC
PostPosted: Mon Nov 22, 2021 11:10 am
For the last 14 or so years I have been positioning a fretboard surrogate that has dowel pins to key in the truss rod slot and marking the edges cutting close on the band saw.
ImageIMG_1158 by Terence Kennedy, on Flickr
After the fretboard is glued on (I use a locating system of two 1/8" dowels into holes drilled with a jig that keys into the truss rod slot and can be flipped over to drill the holes in the fretboard) I put several layers of binding tape on the board so it will sit flat in spite of the radius and tape in a surrogate slightly oversized nut.
ImageIMG_2239 by Terence Kennedy, on Flickr
ImageIMG_2238 by Terence Kennedy, on Flickr
Then flip it upside down and trim the excess on the router table with a template bit indexing off the fretboard.
ImageIMG_2240 by Terence Kennedy, on Flickr
It's a little scary but I have done it for years and fingers crossed, no disasters yet. I use a standard feed with light passes for most of it but climb cut at the ends. You get a nice flush surface quickly.
These users thanked the author Terence Kennedy for the post (total 2): Robbie_McD (Wed Nov 24, 2021 8:35 am) • Glen H (Mon Nov 22, 2021 9:48 pm)
PostPosted: Mon Nov 22, 2021 11:14 am
I cut the excess off on my band saw, but the fingerboard is facing up so there's no issue with a fingerboard with a radius. It's a little tricky as the neck is blocked up off the table due the heel height and peghead.
I just cut it close and use the fingerboard as a guide when shaping the neck.
PostPosted: Mon Nov 22, 2021 11:17 am
I see Terence just post this too. He's got pictures! That's how I trim the neck too, only I skip the router trim at the end.
PostPosted: Mon Nov 22, 2021 11:20 am
First name: Richard
City: Warwick
State: RI
I had an error filing up to the binding on my bound fretboard, I thought I was being so careful. The router seems like a good idea to me. I'll try it on my next one.
Hutch
PostPosted: Mon Nov 22, 2021 11:26 am
Several options for gluing on fretboards, here’s mine.
1/16” stainless pins to locate the board. Masking tape makes it easier to pull the pins.
Then I use clamps, radius or fretted doesn’t matter
PostPosted: Mon Nov 22, 2021 12:48 pm
First name: Jay
City: Bothell
State: Washington
I guess the radius of the fretboard doesn't present a problem for getting an even cut, or do you do something to keep the neck from rocking side-to-side on the fretboard?
I may give that a try on my next neck. It's basically the same thing I do to cut the fretboard taper:
PostPosted: Mon Nov 22, 2021 1:22 pm
That's a slick way to trim it, I still do it by hand.
PostPosted: Mon Nov 22, 2021 1:55 pm
First name: Richard
City: Warwick
State: RI
A hand plane makes quick work of that. I don't see any reason to use a router. I'll try it anyway and see for myself.
Hutch
PostPosted: Mon Nov 22, 2021 6:43 pm
On my original post I show using several layers of binding tape to compensate for the radius. That seems to work well to prevent rocking.
These users thanked the author Terence Kennedy for the post: J De Rocher (Mon Nov 22, 2021 7:10 pm)
