It is currently Fri Sep 19, 2025 5:20 am
Post new topic Reply to topic  [ 197 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8
PostPosted: Tue Feb 15, 2022 8:16 am
joshnothing wrote:
I saw a guy once who would leave 1/8” excess at each end of the top, cut a narrow kerf in it on center then slide a piece of matching size steel shim in the kerf and down between each the two halves of the mould where they met.
That would work too if done with reasonable precision. It wouldn’t work in my case since I use screws to lock the head and tail blocks to the mold.
These users thanked the author SteveSmith for the post: Hesh (Sun Feb 27, 2022 4:12 am)
PostPosted: Sat Feb 26, 2022 9:21 pm
First name: Brad
Last Name: Combs
I like this one as it’s easy to make and nice to have. Just a board with a 1” hole and router mounted to it. Makes the notches easy.
These users thanked the author bcombs510 for the post (total 3): flemsmith (Fri Mar 11, 2022 7:12 pm) • Robbie_McD (Sun Feb 27, 2022 6:57 pm) • Hesh (Sun Feb 27, 2022 4:12 am)
PostPosted: Sun Feb 27, 2022 4:14 am
Jim Watts wrote:
Terence Kennedy wrote:
I wonder how many older luthiers built model planes and cars and had model railroads as kids? Quite a few I bet. I sure did. I think it taught patience and attention to detail. You could also have fun blowing them up later with firecrackers.
I don't think kids do that anymore though. Well maybe they still blow things up :)
You left out setting them on fire. Oh, the memories of a childhood.
Remember the U control planes? Those just ended up in a billion pieces crashed into the ground. I eventually did better with RC gliders.
And, as with Hesh using them for target practice.
Oh the 12 gauge slug gun with riot barrel used to get the RC plane out of the tree story :)
It did work although there was little left of the plane :)
PostPosted: Sun Feb 27, 2022 10:04 am
I kept all my models, the original boxes, and all the spare parts into my middle 40's and sold them for a tidy sum to a master modeler....
These users thanked the author Chris Pile for the post: Hesh (Sun Feb 27, 2022 4:29 pm)
PostPosted: Sun Feb 27, 2022 11:43 am
State: West Somerset
Country: UK
Brad now that is neat. My cutouts are usually terrible. I Have tried balancing a small router on the lining but that doesn't really work.
I shall certainly try your idea next time.
These users thanked the author Dave m2 for the post (total 2): Hesh (Sun Feb 27, 2022 4:28 pm) • bcombs510 (Sun Feb 27, 2022 12:39 pm)
PostPosted: Sun Feb 27, 2022 12:40 pm
First name: Brad
Last Name: Combs
Yes, it’s such a head slapper. I first saw it shared by Beau Hannam on instagram.
These users thanked the author bcombs510 for the post: Hesh (Sun Feb 27, 2022 4:28 pm)
PostPosted: Sun Feb 27, 2022 1:39 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Dope slap from me, too. Gotta be something wrong with something so easy.
Thanks!
Peter Havriluk
These users thanked the author phavriluk for the post (total 2): bcombs510 (Sun Feb 27, 2022 5:48 pm) • Hesh (Sun Feb 27, 2022 4:28 pm)
PostPosted: Mon Feb 28, 2022 7:21 am
You can do something similar by using a board as an edge guide and router with a top bearing bit. That can allow you to see where you are notching a little easier and where to stop if you prefer to not cut through the side. One less jig to store and find. [:Y:]
These users thanked the author Clay S. for the post (total 2): Hesh (Mon Feb 28, 2022 10:21 am) • Robbie_McD (Mon Feb 28, 2022 9:30 am)
PostPosted: Mon Feb 28, 2022 10:31 am
Cool Brad and this is safer than how I did it.
I would mark where I wanted to remove material and blacken the area to be removed with a sharpie so I could see it. Then I used my Dr*mel... with a spiral down-cut bit set to the height of what I was tucking brace wise mounted in the StewMac Dr*mel router base and do it manually keeping it all level or trying too. Worked OK but you have the level down much better with this idea.
Great idea!
PostPosted: Mon Feb 28, 2022 10:35 am
Probably others use this, just I've never seen this posted.
2 or 3 go-bar rods help steady a top or back in a radius dish for carving braces, scrap of something helps prevent dents
Sent from my moto g(6) play using Tapatalk
These users thanked the author Colin North for the post: Hesh (Tue Mar 01, 2022 2:13 pm)
PostPosted: Tue Mar 01, 2022 10:56 am
Last Name: Colbert
City: Anacortes
Right in one!
I was installing an endpin jack this morning, went for my simple 2-minute tool and thought this could be helpful to someone. I’ve been meaning to make a prettier version….
Best, M
These users thanked the author Michaeldc for the post (total 11): kjaffrey (Sat Mar 12, 2022 7:39 am) • bftobin (Wed Mar 09, 2022 8:32 pm) • Terence Kennedy (Wed Mar 09, 2022 12:02 am) • Barry Daniels (Tue Mar 01, 2022 2:23 pm) • Hesh (Tue Mar 01, 2022 2:14 pm) • stumblin (Tue Mar 01, 2022 2:06 pm) • SteveSmith (Tue Mar 01, 2022 1:06 pm) • J De Rocher (Tue Mar 01, 2022 12:54 pm) • Robbie_McD (Tue Mar 01, 2022 12:09 pm) • Chris Pile (Tue Mar 01, 2022 11:57 am) and one more user
PostPosted: Wed Mar 02, 2022 4:23 am
Why haven't I posted this one? Quickie finish touch-up or thread locker - clear fingernail polish.
It's thick so it builds fast, works well with any finish, buffs to a nice shine easily provided you let it harden. Even has a handy brush in the cap, or use an artists brush or toothpick if need be. Can even be thinned down and sprayed from an airbrush for larger touch-ups. You can even use black or the many colored polishes available for touching up a variety of colored finishes so you don't have to buy a whole can for a touch up. Cheaper to buy, too. Works great on plastic finishes of lesser brands of instruments.
Makes a fine thread locker, too. I use it on Schaller bridges all the time that are adjustable for string spacing to keep the rollers in place. It's not permanent - a quick touch of lacquer thinner or acetone with a toothpick or artists brush softens it to move the screw or part, or when forced - it will simply pop off the chrome. Also, on electric bass strings - the thread that wraps the ball ends or the terminus of the string at the peghead sometimes wants to unravel. Fingernail polish to the rescue - it will tame that errant thread and keep it attached to the windings of the string. Less permanent than CA glue, and smells less evil.
These users thanked the author Chris Pile for the post (total 6): Hesh (Thu Mar 03, 2022 4:19 am) • Robbie_McD (Wed Mar 02, 2022 12:50 pm) • J De Rocher (Wed Mar 02, 2022 10:21 am) • Gasawdust (Wed Mar 02, 2022 9:56 am) • Michaeldc (Wed Mar 02, 2022 6:34 am) • joshnothing (Wed Mar 02, 2022 5:38 am)
PostPosted: Tue Mar 08, 2022 6:11 pm
First name: Josh
This one is almost too obvious, but if you need to get pliers involved in removing a particularly stubborn saddle, a steel fingerboard guard comes in handy. Particularly where the bridge has been finished.
These users thanked the author joshnothing for the post (total 3): Hesh (Wed Mar 09, 2022 5:48 am) • bcombs510 (Tue Mar 08, 2022 6:54 pm) • SteveSmith (Tue Mar 08, 2022 6:22 pm)
PostPosted: Tue Mar 08, 2022 7:28 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Here are two tips that I use all the time.
1. Get some 1/8" thick leather (generally very useful stuff for guitar makers and repairers) and glue some pieces to the jaws of a cheap set of Channellock pliers, gluing the rough side of the leather right to the teeth. Titebond works great. You know those soft touch pliers that StewMac sells? I am sure they are useful for some things, but not for heavy duty torque. The Channellock pliers with leather are both tough and tender. Wonderful tool to have.
2. We all deal with sanding corns on sandpaper. My favorite way to remove them, and save the sandpaper, is to keep a file cleaner handy, the kind that has soft bristles on one side and metal bristles on the other side. If the soft bristles won't remove the corns, the metal bristles will. Amazingly, the metal doesn't tear through the sandpaper, unless you really lean into it like a doofus. This works better than any other corn removal trick I have tried.
These users thanked the author doncaparker for the post (total 5): Robbie_McD (Wed Mar 09, 2022 8:45 am) • joshnothing (Wed Mar 09, 2022 7:45 am) • Hesh (Wed Mar 09, 2022 5:48 am) • Chris Pile (Wed Mar 09, 2022 1:23 am) • SteveSmith (Tue Mar 08, 2022 7:39 pm)
PostPosted: Wed Mar 09, 2022 7:27 am
Last Name: Kincheloe
I thought I'd tried that before, but maybe not. I've only ever had luck removing corns one by one with an x-acto knife, so I sweep the dust off with a toothbrush to prevent them forming in the first place.
And that reminds me, I don't use coarse sandpaper anymore since discovering that sanding belts are so much better. Very little shedding of abrasive particles, so it lasts almost forever as long as you keep it clean. Get the kind without velcro backing, as that will round over edges on whatever you're sanding.
And then for fine sanding I mostly use my XXC dia-sharp stone. Hard and flat, so it produces high quality surfaces, and again lasts forever. The only drawback is that corns develop quickly if you don't brush the dust off, and once one forms, it will quickly re-form in the same spot until you wash it with water. Not a big deal if you have a sink near your work area, but if not then stick with regular sandpaper.
These users thanked the author DennisK for the post: Hesh (Thu Mar 10, 2022 3:14 am)
PostPosted: Wed Mar 09, 2022 3:19 pm
First name: Yeaux
Last Name: Maumma
Here’s a tip or more of a tool. I don’t believe these are made any more but they still pop up on eBay and the likes. It is a snap on 3ASHA. I use this non stop for decades for trem spring installation. I know I have scratched many a guitar in my youth using needle nose pliers.
These users thanked the author Lou Thier for the post (total 3): Hesh (Thu Mar 10, 2022 10:33 am) • SteveSmith (Wed Mar 09, 2022 4:19 pm) • jfmckenna (Wed Mar 09, 2022 3:56 pm)
PostPosted: Fri Mar 11, 2022 7:52 pm
First name: Roy L
Last Name: Smith
City: Apache Junction
State: Az
Zip/Postal Code: 85119
Instead of pointing straws for glue clean-up....try bamboo skewers, couple strokes on sandpaper bevels the edge surprisingly well. Cheap in the BBQ aisle.
These users thanked the author flemsmith for the post: Hesh (Sat Mar 12, 2022 3:36 am)
PostPosted: Fri Mar 18, 2022 4:49 pm
First name: Ken
Last Name: Nagy
City: Goodrich
Polish your edge tools. I was scraping a violin down to size, and the 1" laminated steel chisel I was using wasn't getting it. The old plane blades I use as scrapers were no better, even after honing. The cheap 3/4" Craftsman worked great. I broke down and decided to sharpen everything.
I bought 2 double sided earMoo waterstones to replace a bunch of stones a year or so ago. One plastic shoebox to store them in with water. I started with 400 or 600, I don't remember what it is, up to 5,000. Some of them even needed the bench grinder. I don't have a big coarse stone.
After that, I remembered that I bought some lapping paper from Woodcraft. 5 mil 1 mil, and .3 mil. I only used the 5 mil a little, and then threw it in a drawer.
I went thought all three "grits" if you want to call it that, and the tools really shine on the ends. I tested the 1" chisel, and it works nice. I'm guessing that the polishing makes a smoother cut, and it should last longer.
They have to work better being scary sharp. The edges gleam.
It's probably better to sharpen every tool that you are using at the time. Doing all of them takes a while.
Why be normal?
These users thanked the author Ken Nagy for the post: Hesh (Fri Mar 18, 2022 7:18 pm)
PostPosted: Tue Apr 12, 2022 8:51 pm
I bought a couple of these little gooseneck LED lights for my dad to shave with... He is too blind to use them, and just does it by feel these days. They fit in the box of a flattop or through the f-holes of an archtop easily, and allow me to see with my mirrors inside the guitar when I am doing repair. They didn't cost much - got them from Amazon. They are called "Mighty Bright", and run on 3 AAA batterys. The spring clip works very well to stabilize the light, and the gooseneck works well - very flexible. There are 2 LEDS in the head, press once for 2 lights, press again for 1 light, press a third time to shut the lights off. Very handy!
https://i.imgur.com/meiukDi.jpg
https://i.imgur.com/vgICpJe.jpg
These users thanked the author Chris Pile for the post (total 3): joshnothing (Wed Apr 13, 2022 8:21 am) • Hesh (Wed Apr 13, 2022 2:48 am) • bcombs510 (Tue Apr 12, 2022 9:13 pm)
PostPosted: Wed Apr 13, 2022 4:24 pm
I was fitting a back today and can’t remember if I have posted this before but when cutting brace ends to final length you can put tape on an XActo razor saw and saw almost all the way down without worrying about damaging the top or back.
You can finish with a #11 blade.
Image8D7E8AA0-D4B1-45D8-90A9-A8C1968F17B3 by Terence Kennedy, on Flickr
These users thanked the author Terence Kennedy for the post (total 5): joshnothing (Thu Apr 14, 2022 7:44 am) • Robbie_McD (Thu Apr 14, 2022 7:17 am) • Hesh (Thu Apr 14, 2022 2:06 am) • Smylight (Wed Apr 13, 2022 6:37 pm) • Chris Pile (Wed Apr 13, 2022 5:12 pm)
PostPosted: Wed Apr 13, 2022 4:28 pm
Last Name: Parker
City: Charleston
Another way to skin the cat that Terence just mentioned is to use a veneer saw, which has a curved blade. The curve allows you to focus the cutting on just the brace. Both ways are useful.
These users thanked the author doncaparker for the post (total 3): Hesh (Thu Apr 14, 2022 2:06 am) • Terence Kennedy (Wed Apr 13, 2022 7:01 pm) • Smylight (Wed Apr 13, 2022 6:37 pm)
PostPosted: Thu Apr 14, 2022 4:30 am
Or a Hosco bracing saw, same sort of thing - used one for a few years now.
Sorry about the sixe of the pic, the saw is actually my smallest one.
These users thanked the author Colin North for the post: Smylight (Thu Apr 14, 2022 8:24 am)
