It is currently Thu Sep 18, 2025 1:17 pm
PostPosted: Sat Mar 19, 2022 1:26 pm
First name: Brad
Last Name: Combs
Hi folks,
I’m in the process of trying to up the bending game. I have been using a keenovo blanket for the last few years for both uke and guitar. I wanted to move back to a PID style controller so I picked up two of them from LMI. Two of them because I’m planning to bend the solid lining layers and the sides at the same time and want a blanket on top and bottom. That’s a topic for another day.
However, for fun, and because I had two controllers, I tested the temp at both the waist and lower bout. The lower bout temp displayed quite a bit higher throughout the whole heating process. The sensors were both placed between the blanket and top slat. No wood in there for this test, just the slats.
Is it normal to have two different temps in each zone and to have them be so far apart? I faintly recall a post about temp zones and best practices to place the sensor, but cannot seem to locate it.
Here is my setup:
Ideas are appreciated.
Brad
PostPosted: Sat Mar 19, 2022 1:46 pm
City: U.P.
I guess first I'd stick the thermocouple sensors right next to each other and see if they read the same. If they are showing the same temp, you can trust them. If not, swap thermocouples on the controllers and test. It could be they read differently and there may be a way to adjust that in the PIDs.
More likely however is that in the waist area, the clamping cauls are just sucking off heat like a heat sink and in the bout area there is less contact and less heat transfer away from the sensor.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post (total 3): Duct Tape (Mon Mar 11, 2024 9:04 am) • Pmaj7 (Mon Feb 26, 2024 12:38 am) • bcombs510 (Tue Mar 22, 2022 8:15 am)
PostPosted: Sat Mar 19, 2022 2:33 pm
yes what is the wattage of the blanket I found the Keenovo were not very good. If you don't have 5 watts per square in you can loose a lot on thermal load.
The other thing is how the heating element in the unit is.
These users thanked the author bluescreek for the post: bcombs510 (Tue Mar 22, 2022 8:15 am)
PostPosted: Sat Mar 19, 2022 2:42 pm
First name: Brad
Last Name: Combs
The blankets are from LMI. Overall wattage is 1035 and sq in is 213 so that comes to 4.85 watts / sq in. That is if all you do is divide total wattage by area. :)
Do you mean the element integrated into the blanket?
PostPosted: Sat Mar 19, 2022 4:28 pm
Last Name: Ball
Did you go through the calibration process for the PID's? They can be off quite a bit until they've been calibrated to the particular blanket that you're using.
These users thanked the author ballbanjos for the post (total 2): Pmaj7 (Mon Feb 26, 2024 12:39 am) • bcombs510 (Sat Mar 19, 2022 4:50 pm)
PostPosted: Sat Mar 19, 2022 4:52 pm
First name: Brad
Last Name: Combs
Good call, I will try that. I made the assumption it’s all from the same supplier so would work together. These controllers are marketed as being “intelligent”, which probably means they need to be trained first. :)
PostPosted: Sat Mar 19, 2022 10:50 pm
Thermocouples vary in their response to heat. Even from the same source there will be variations.
These users thanked the author Pat Foster for the post: bcombs510 (Tue Mar 22, 2022 8:15 am)
PostPosted: Mon Mar 21, 2022 10:15 am
One thing to keep in mind is that what we are using as "bending blankets" are generally used as drum heaters - a way to keep chemicals in 55 gallon drums at an optimal temperature in an unheated warehouse environment. Having a uniform temperature from end to end of the blanket is less important than having the total BTU's output in a reasonably consistent manner. Overall I think they do a pretty good job, even for our unintended purpose.
These users thanked the author Clay S. for the post (total 2): bcombs510 (Tue Mar 22, 2022 8:15 am) • Barry Daniels (Mon Mar 21, 2022 11:04 am)
PostPosted: Tue Mar 22, 2022 7:26 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I’ve done a lot of testing of monitoring methods using K-type thermocouples. It is important to know that the readings can vary among thermocouples, and the PID or temperature display can introduce its own bias, such that the same thermocouple can give different readings on different displays. And of course temperature will vary from point-to-point in your bending sandwich.
I tend to bend with 3 thermocouples and 2 displays. Having multiple readings helps to identify thermocouples that have gone “bad” (it happens). If your LMI controller has an Auber PID (at least the original ones did), there is a feature to increase or decrease the bias. You can find the detailed PID instructions on the Auber website.
These users thanked the author Tim Mullin for the post (total 2): Pmaj7 (Tue Feb 27, 2024 8:21 am) • bcombs510 (Tue Mar 22, 2022 8:15 am)
PostPosted: Sun Feb 25, 2024 12:02 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
bcombs510 wrote:
Hi folks,
Here is my setup:
Brad
Clealy LMI is gone. Where Can I find similar?
PostPosted: Sun Feb 25, 2024 1:55 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
You could make your own.
Building a PID-type blanket temperature controller
https://r.tapatalk.com/shareLink/topic? ... source=app
PostPosted: Sun Feb 25, 2024 6:46 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Did you check the TCs in boiling water? Both TCs should read the same.
You could characterize the measurement errors and apply the error to the heat range you are working in by placing both TCs in room temp water, then into boiling water, for both controllers, plotting your results then extrapolating the line(s) out to your target temperature.
Measure Twice,
Karl Borum
PostPosted: Mon Feb 26, 2024 9:02 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Tried swapping controllers? Easy enough to plug/unplug. Or trying a third thermocouple, and maybe number three agrees with number one or number two?
Peter Havriluk
PostPosted: Wed Feb 28, 2024 6:36 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Argh. How about focussing on my question? The issue above was beat up a while back????
PostPosted: Wed Feb 28, 2024 6:54 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
How about this:
https://www.ebay.com/itm/125256234823?i ... R-qimKK-Yw
These users thanked the author doncaparker for the post: Kbore (Wed Feb 28, 2024 7:20 pm)
PostPosted: Wed Feb 28, 2024 7:13 pm
Last Name: Ball
I built mine using an "Inkbird" PID from Amazon (where do they get those names???) and a solid state relay, etc. pretty much like in Tim's link. Didn't cost much to build and works fine. I don't know if anyone is building this kind of thing commercially or not.
These users thanked the author ballbanjos for the post (total 2): Kbore (Wed Feb 28, 2024 7:22 pm) • bcombs510 (Wed Feb 28, 2024 7:20 pm)
PostPosted: Wed Feb 28, 2024 8:51 pm
I have used the same LMI controllers and a Taylor kitchen thermometer since 2004. Primitive by today’s tech but they work well for me.
ImageIMG_7449 by Terence Kennedy, on Flickr
PostPosted: Thu Feb 29, 2024 3:29 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
What’s with the attitude? Your question had to do with alternatives to an LMI-made controller, right? You got more than one answer, including a step by step guide to building your own. Just go do it.
These users thanked the author Tim Mullin for the post: Kbore (Fri Mar 01, 2024 11:00 am)
PostPosted: Sat Mar 02, 2024 9:35 am
Last Name: O'Melia
City: Huntsville
State: Alabama
never mind. I appologize
Users browsing this forum: Bing [Bot] and 44 guests
