It is currently Fri Sep 19, 2025 1:14 pm
 Post subject: Crossover guitars
PostPosted: Fri Apr 08, 2022 7:46 am
I’m contemplating making a crossover instrument. Basically a nylon string guitar w specs of a steel string.
I had a Taylor crossover years ago and loved it.
Thought maybe I’d make one now:)
What’s different? How does one determine brace stiffness and such.?
Just looking for a start
 Post subject: Re: Crossover guitars
PostPosted: Fri Apr 08, 2022 8:08 am
Think of it as a classical guitar with a narrow neck and narrow string spacing at bridge. Brace it like a classical guitar.
PostPosted: Fri Apr 08, 2022 11:49 am
That’s where I’ll need to research. I’ve never braced a classical before
PostPosted: Fri Apr 08, 2022 1:26 pm
I’m doing my first crossover. Box is based on Rameriz, neck is typical steel string - dovetail, 16” radius. I made the nut 1 7/8”.
Tried to post a photo with Tapatalk but it it failed twice.
Finally
PostPosted: Fri Apr 08, 2022 1:46 pm
Brandon, don’t you have the Gore/Gilet books? There should be all the info you need in them including a bracing layout, or at least a good start anyway…
PostPosted: Fri Apr 08, 2022 2:19 pm
You can search google images for classical guitar bracing. The Torres pattern is probably the simplest (Torres is to classical fan bracing what Martin is to the x-brace in steel strings). If you go the route that jfmckenna mentioned, a classical with a narrow neck, it might be worthwhile to get a plan. luth.org has a good one in the Torres SE114 plan. Bear in mind that the lower tension in nylon strings means that the strings deflect a lot more when struck, making it more of a challenge to keep the left fingers from interfering. There's also the larger diameters of the treble strings, compared to the equivalents in steel strings.
These users thanked the author Pat Foster for the post: SnowManSnow (Fri Apr 08, 2022 8:55 pm)
PostPosted: Fri Apr 08, 2022 8:48 pm
Indeed I do. Thanks for the reminder
PostPosted: Fri Apr 08, 2022 9:28 pm
I think there’s even a classical plan…
PostPosted: Sat Apr 09, 2022 5:21 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
I did one with a L-00 body (but anything of similar size would do), falcate bracing from the G&G books, fairly light construction, bolt-on and bolt-down neck, slotted headstock. Very happy with it.
PostPosted: Sat Apr 09, 2022 7:55 am
The older Taylor crossover guitars were a 5 bar fan with a slanted lower transverse brace and a spruce bridge plate.
I built one similar, 14 fret OLF Small Jumbo shape, may still have drawings/bracing template.
These users thanked the author Colin North for the post: bcombs510 (Sat Apr 09, 2022 8:56 am)
Users browsing this forum: JimWomack and 30 guests
