It is currently Fri Sep 19, 2025 12:42 am
PostPosted: Fri Jun 24, 2022 3:35 pm
How do I properly set the handle onto a chisel?
I have a few hat keep coming out.. which is dangerous!
PostPosted: Fri Jun 24, 2022 4:21 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
When I first mate one with a handle, I clamp the chisel end in a wood-jawed clamp and forcefully twist the handle around and around in the socket until it fits really tight. Usually, that’s enough to keep it in the socket. In winter, when shrinkage loosens the handle, sometimes I twist it back in with a drop of Titebond. I don’t have to reseat them often. I love my socket chisels—no ferrule to scrap the knuckles of my hold down hand. And, I can make my own handles. Chisels never come with long enough handles.
These users thanked the author bobgramann for the post: SnowManSnow (Fri Jun 24, 2022 6:23 pm)
PostPosted: Fri Jun 24, 2022 5:09 pm
Last Name: Russell
State: Michigan USA
I chalk the socket and fit the handle to it. Once you get a good fit you shouldn't have any problems with it staying put.
I have been doing that for years and it seems to work well.
Cheers,
Bob
These users thanked the author RusRob for the post: SnowManSnow (Fri Jun 24, 2022 6:23 pm)
PostPosted: Thu Jul 28, 2022 9:03 am
First name: Patrick
Last Name: Wilson
City: Victor
Zip/Postal Code: 14564
I've made a bunch and have also used the chalk method. Works well.
Make sure the handles aren't bottoming out. If they are, you could shave off a tiny bit of the end and maybe trim back the shoulder to create a tighter fit too.
One other thing I did when making my own handles out of some Black Locust is to fit them tight in the winter when the air is dry, It kept them stuck tight in the warmer. more humid months.
Finally, I heard that a spritz of hairspray can give an extra bit of grip. A little bit of shellac would do the same thing.
PostPosted: Thu Jul 28, 2022 9:29 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Socket chisel? What's that?
Thanks!
Peter Havriluk
PostPosted: Thu Jul 28, 2022 11:55 am
Here is an article that explains the differences and the advantages of both:
https://woodandshop.com/woodworking-han ... a%20mallet.
I own both types and have no complaints about either.
Marples makes blue chip chisels with blue plastic handles, which appear to be socket chisels, but are actually tang chisels:
https://www.jimbodetools.com/products/s ... -box-70131
I paid $30 for a set of 4 and later added an 1 1/2 wide chisel for $5 when a retail store was dumping stock. Now that they are calling them "Vintage" I guess the price goes up!
If you can turn new handles (or buy them) you can find perfectly fine socket chisels for a couple bucks at the fleas and yard sales. I bought a couple of narrow long bladed T.H.Witherby chisels (needing handles) for a buck apiece when someone was moving and downsizing their stuff. bliss
