It is currently Thu Sep 18, 2025 8:25 pm
 Post subject: Size 0: 1 tone bar or 2?
PostPosted: Fri Sep 15, 2023 1:26 pm
Been over 10 years since I did a Size 0. Laying out the top just now and the plan calls for two tone bars but it looks a bit excessive to me so I'm thinking one ought to be enough ... but... I'm interested to know what those of you that have done size 0 or similar size guitar have been doing. Not so sure about the 4 finger braces either, maybe I'm just used to seeing more real estate around the braces since I usually do OM size or larger. Whadaya think?
PostPosted: Fri Sep 15, 2023 1:35 pm
Lower bout width?
PostPosted: Fri Sep 15, 2023 1:38 pm
Online
First name: Brad
Last Name: Combs
I have built three parlor sized with single tonebar and two finger braces. I believe the plan called for this as well (Antes plan).
They sound good, if that helps. :)
These users thanked the author bcombs510 for the post (total 2): Pmaj7 (Sat Sep 16, 2023 12:26 am) • SteveSmith (Fri Sep 15, 2023 1:51 pm)
PostPosted: Fri Sep 15, 2023 1:48 pm
If it's a typical 13" lower bout parlor, I'd go with one finger brace and one tone bar. Unless your top has some issues, one finger brace should be fine. I use only one finger brace on my OO tops.
These users thanked the author bftobin for the post (total 2): SteveSmith (Fri Sep 15, 2023 1:53 pm) • bcombs510 (Fri Sep 15, 2023 1:49 pm)
PostPosted: Fri Sep 15, 2023 1:49 pm
meddlingfool wrote:
Lower bout width?
LB=13 1/2"
UB=9 1/2"
OA L=19"
Online
First name: Brad
Last Name: Combs
I should clarify since Brent was more clear, I also advocate for one finger brace (2 total), which is what my parlors were.
These users thanked the author bcombs510 for the post: SteveSmith (Fri Sep 15, 2023 1:52 pm)
PostPosted: Fri Sep 15, 2023 1:52 pm
Hey Brad, do you happen to have a photo of a braced top or your template?
PostPosted: Fri Sep 15, 2023 1:57 pm
One tone bar, one fingerbrace per side for me on a 13” parlour…Image
These users thanked the author meddlingfool for the post (total 2): Pmaj7 (Sat Sep 16, 2023 12:27 am) • bcombs510 (Fri Sep 15, 2023 2:01 pm)
PostPosted: Fri Sep 15, 2023 1:58 pm
Top should be ok, it's torrified Red Spruce. Usually I'm right at 0.100" for these tops but this one came in at 0.120" after initial thinning because that's where it felt/sounded ok. It's a bit floppy across the grain for Red Spruce which is why I figured it might do ok in a parlor sized guitar.
PostPosted: Fri Sep 15, 2023 2:01 pm
Thanks Ed, that looks more like what I was thinking. Looking at yours reminds me I need to slim the bridge plate down too.
PostPosted: Fri Sep 15, 2023 2:02 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I have made 2 O size guitars so not a ton of experience (though I loved the sound of both and neither have collapsed). Both are 13.5" lower bout and use one finger brace and one tone bar.
Before I became without a workshop, I was about half way finished with a OOish size that is also 1 finger brace and one tone bar. Pretty confident it will be good also.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: SteveSmith (Fri Sep 15, 2023 2:04 pm)
PostPosted: Fri Sep 15, 2023 2:10 pm
Sounds like consensus to me. One finger brace on each side and one tone bar it is. This is going to be a retop on a hog body.
Thanks everybody!!
These users thanked the author SteveSmith for the post: Bryan Bear (Fri Sep 15, 2023 2:30 pm)
PostPosted: Fri Sep 15, 2023 2:12 pm
In practice I make my plate a little larger than on the template. I aim to make it extend 15mm from the back of the bridge at the center line…
These users thanked the author meddlingfool for the post: SteveSmith (Fri Sep 15, 2023 2:25 pm)
PostPosted: Fri Sep 15, 2023 2:25 pm
I make them a little larger too. The layout just didn’t look right to me, turns out I had put in a line wrong.
PostPosted: Fri Sep 15, 2023 2:44 pm
Online
First name: Brad
Last Name: Combs
I think you’re on your way, but here it is anyway.
These users thanked the author bcombs510 for the post: SteveSmith (Fri Sep 15, 2023 5:40 pm)
PostPosted: Fri Sep 15, 2023 3:27 pm
This is a drawing I did of my 1937 0-17 when I had the top off for repairs. Personally I prefer 2 scalloped tone bars, with a non-radius gluing surface. This is the part of a guitar that resists the top belly. Of course, these braces are very light and deeply scalloped, so 1 larger tapered tone bar may suffice.
These users thanked the author guitarjtb for the post (total 2): SteveSmith (Fri Sep 15, 2023 5:41 pm) • joshnothing (Fri Sep 15, 2023 5:14 pm)
PostPosted: Fri Sep 15, 2023 3:38 pm
Here's a pic of bracing on an L-0 I made, (13 5/8" wide lower bout. 1/4" wide bracing)
Worked out really well, loud and full, balanced sound.
Ideal "borrowed" from Bruce Sexauer.
These users thanked the author Colin North for the post (total 2): phavriluk (Sun Sep 17, 2023 10:46 pm) • SteveSmith (Fri Sep 15, 2023 5:42 pm)
PostPosted: Fri Sep 15, 2023 5:55 pm
Brad, thanks for showing that, looks like you and Ed have similar bracing patterns.
Guitarjtb, appreciate you sharing the drawing, the deep scallops would certainly allow more movement in that area which is what I feel is needed. it's always great to see the details of the old Martins and I'm partial to '37's. The best dred I've made was based on a drawing of a '37 D28 that I got from John Arnold.
Colin, thanks for showing that. Kind of the middle ground with the short tone bar over the larger empty space. Bruce Sexauer certainly comes up with some good ideas. I based my multiscale 000 on his design (with permission) and it turned out great.
These users thanked the author SteveSmith for the post (total 2): Colin North (Sat Sep 16, 2023 4:51 am) • CraigG (Fri Sep 15, 2023 9:05 pm)
PostPosted: Fri Sep 15, 2023 7:27 pm
My plan comes directly from the LMI 1-17 blueprint. Gosh, I remember the heady days of excitement buying a new blueprint…
These users thanked the author meddlingfool for the post (total 2): phavriluk (Sun Sep 17, 2023 10:46 pm) • SteveSmith (Sat Sep 16, 2023 7:03 am)
PostPosted: Sat Sep 16, 2023 12:03 am
I would consider string tension. For example if you are intending to use 12's I would go with one tone bar if by chance like Taylor and their GS mini you are intending to use 13's I would use two tone bars.
I don't know what Taylor uses but they do ship the minis with 13's so some small guitar players do use them.
Any top brace is a hedge against top distortion as well as any tonal function. More string tension more top distortion.
These users thanked the author Hesh for the post: SteveSmith (Sat Sep 16, 2023 7:04 am)
PostPosted: Sat Sep 16, 2023 4:28 am
City: Escondido
Zip/Postal Code: 92029
In my misbegotten youth I made a series of small bodied guitars (13.5”-14” lower bout). I found following the “standard” Martin X brace for a dreadnaught to be WAY too much. The guitar may have only shrunk by 20% or 30%, but the bracing ended up shrinking by more like 50% to 60%.
Long winded way of saying one tone and one finger per side should be more than enough. Even then, you will probably want to go pretty light.
These users thanked the author rlrhett for the post (total 2): Pmaj7 (Sat Sep 16, 2023 6:31 pm) • SteveSmith (Sat Sep 16, 2023 7:04 am)
PostPosted: Sun Sep 17, 2023 12:33 pm
First name: Freeman
Last Name: Keller
I have built three 12 inchers from the Scott Antes plans with one tone bar and one set of finger braces.
They have held up well, sound good and are amazingly loud. The Antes plans are thought to be a bit over built so I lightened the braces a bit. Remember that those plans are drawn as tho you were looking thru the top.
These users thanked the author Freeman for the post: SteveSmith (Sun Sep 17, 2023 1:26 pm)
Users browsing this forum: Bing [Bot] and 47 guests
