It is currently Tue May 05, 2026 3:10 pm
 Post subject: 16" Archtop build
PostPosted: Wed Dec 20, 2023 9:24 pm
First name: Martin
Last Name: Taylor
City: Central Coast
Here's my latest Archtop build. It is a 16" lower bout, 16 fret to the body join, Australian Red Cedar on top, Birdeye Maple back and sides, Australian Red Cedar neck, Rosewood Fretboard and bridge and the tailpiece is my first foray into making my own tailpiece on a small CNC. The Top and back are hand-carved and I have taken inspiration from a few builders for the f-holes. The pickup is a Kent Armstrong Slimbucker providing lovely clean Jazz through to a nice edge with some extra gain.
Martin Taylor
http://martintaylorguitars.com.au
These users thanked the author martintaylor for the post (total 4): Michaeldc (Thu Dec 21, 2023 10:54 pm) • Durero (Thu Dec 21, 2023 8:32 pm) • rbuddy (Thu Dec 21, 2023 4:08 pm) • Chris Pile (Wed Dec 20, 2023 11:54 pm)
 Post subject: Re: 16" Archtop build
PostPosted: Wed Dec 20, 2023 9:33 pm
First name: Andrew
Last Name: Gilbert
City: WANGARA
Zip/Postal Code: 6065
WOW that sure is nice looking guitar Martin. Beautiful craftsmanship
These users thanked the author as_gilbert for the post: martintaylor (Wed Dec 20, 2023 11:44 pm)
PostPosted: Wed Dec 20, 2023 9:49 pm
Sweet!
These users thanked the author SteveSmith for the post: martintaylor (Wed Dec 20, 2023 11:44 pm)
PostPosted: Wed Dec 20, 2023 9:53 pm
Online
First name: Brad
Last Name: Combs
That is lovely in every way!
These users thanked the author bcombs510 for the post: martintaylor (Wed Dec 20, 2023 11:44 pm)
PostPosted: Wed Dec 20, 2023 11:24 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
That's a beautiful guitar. That top is gorgeous. I really like the binding and purfling scheme, particularly the maple (?) binding with b/w/b side purfling. Very elegant. I also like the lack of purfling on the top and back, especially on top. The contrast of the maple binding against the cedar is a very clean and simple look. The pattern on the tailpiece reminds me of M. C. Escher tiling patterns.
These users thanked the author J De Rocher for the post: martintaylor (Wed Dec 20, 2023 11:44 pm)
PostPosted: Thu Dec 21, 2023 5:16 am
Very nice!
These users thanked the author Hesh for the post: martintaylor (Thu Dec 21, 2023 7:43 am)
PostPosted: Thu Dec 21, 2023 7:37 am
First name: Ken
Last Name: Nagy
City: Goodrich
Wonderful vision and execution Martin. The arching is beautiful. Australian Red Cedar looks stunning.
Well done.
Why be normal?
These users thanked the author Ken Nagy for the post: martintaylor (Thu Dec 21, 2023 7:43 am)
PostPosted: Thu Dec 21, 2023 12:07 pm
Last Name: Ionta
City: Hopkinton
State: Massachusetts
Zip/Postal Code: 01748
Spectacular!
These users thanked the author bionta for the post: martintaylor (Thu Dec 21, 2023 4:25 pm)
PostPosted: Thu Dec 21, 2023 2:45 pm
That’s really nice!!
These users thanked the author Jim Watts for the post: martintaylor (Thu Dec 21, 2023 4:25 pm)
PostPosted: Thu Dec 21, 2023 4:13 pm
City: U.P.
I'm surprised how much I like the bindings with the lack of contrast but I really do.
The tailpiece is outstanding and the finish perfect.
Well done!
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: martintaylor (Thu Dec 21, 2023 4:25 pm)
PostPosted: Thu Dec 21, 2023 6:11 pm
Wow. 16” is the perfect size.
These users thanked the author Terence Kennedy for the post: martintaylor (Thu Dec 21, 2023 11:52 pm)
PostPosted: Thu Dec 21, 2023 9:58 pm
Last Name: Sollod
That is wonderful! I’m just starting my first archtop. I expect it to take a lot longer than my usual steel strings and electrics. There is a lot to learn.
How did you join the neck?
www.swiftcreekguitars.com
These users thanked the author sdsollod for the post: martintaylor (Thu Dec 21, 2023 11:52 pm)
PostPosted: Fri Dec 22, 2023 12:03 am
First name: Martin
Last Name: Taylor
City: Central Coast
Hi Steve,
I use a dovetail neck joint for my archtops. The most important part is the neck angle. Unless you are using a CNC to carve the top every top is slightly different in height and so you need to make the neck angle work with the bridge you have and the thickness of the neck extension. My go-to formula is to make a small block of timber 4mm lower than the bridge and stick it where the bridge will be located with some double-sided tape. At the neck/body join I then add up the thickness of my fretboard extension (anywhere from 7mm - 16mm depending on the style of archtop I am building) and the thickness of my fretboard (usually 6.5mm at the thickest part) and then 1mm for fret height. So that could be 7mm + 6.5mm + 1mm = 14.5mm. I make a block that thick and stick it right at the body join. Then I balance a straight edge across those two points and extend it out in front of the body. I then get an angle ruler and match the angle from the front edge of the body to under the straight edge. This then becomes my neck angle for the dovetail etc. I will see if I have time to draw up a diagram and post here later.
Martin Taylor
PostPosted: Fri Dec 22, 2023 10:02 am
Martin - you really set the bar high on that one.
These users thanked the author Chris Pile for the post: martintaylor (Fri Dec 22, 2023 3:39 pm)
PostPosted: Fri Dec 22, 2023 10:14 pm
Last Name: Sollod
Martin, thank you so much for your explanation! That helps a whole lot to makes sure you have the “elevation” right for the bridge. What about making sure that the side to side neck angle is correct. On a typical steel string mortise and tenon joint you can floss to get the angle right. How do you get the angle right on a dovetail?
PostPosted: Fri Dec 22, 2023 10:23 pm
Last Name: Sollod
BTW - I purchased Robbie O'Brien's archtop course (which is quite good). The course material specifies a 4.5 degree neck angle using a jig to make sure that is the angle. You explanation makes sense but if the angle changes from build to build, how do you jig up for that?
PostPosted: Fri Dec 22, 2023 10:49 pm
Really Nice!
I love the birdseye maple.
Congratulations!
PostPosted: Sat Dec 23, 2023 2:24 am
First name: Martin
Last Name: Taylor
City: Central Coast
sdsollod wrote:
BTW - I purchased Robbie O'Brien's archtop course (which is quite good). The course material specifies a 4.5 degree neck angle using a jig to make sure that is the angle. Your explanation makes sense but if the angle changes from build to build, how do you jig up for that?
I have the Robbie O'Brie designed Neck routing jig and when I have set the angle ruler and locked it I use that to set the angle of the jig. I will attach a jpg and a pdf of my set up for measuring the angle.
Martin Taylor
PostPosted: Sat Dec 23, 2023 9:38 am
Last Name: Sollod
Fantastic illustration! Thanks Martin!
PostPosted: Sat Dec 23, 2023 12:45 pm
First name: Ken
Last Name: Nagy
City: Goodrich
I use a saw and a chisel. It works, and is easy to dial in. I don't own a router.
Martin's illustration is pretty good.
I would work with the 16mm at the block, because that is where the neck itself will be. I'd use 17.5 for where I want to be at the bridge (18mm arch?) Move the neck down watching the height in both places, and making sure it is square, and straight.
I would probably go higher; maybe 19mm or so. Mine seem to rise in height. I ran out of adjustment on my first one!
But that's because that's what you do with violins and cellos. If you've done that, it's easy. If not, it probably sounds like a lot of work!
That said.
I think I'll be making a Stauffer style neck from now on. A tight mortice on the sides, and a single bolt at the bottom of the heel. It doesn't go anywhere.
Why be normal?
