It is currently Tue Aug 05, 2025 7:36 pm
Post new topic Reply to topic  [ 1829 posts ]  Go to page Previous  1 ... 55, 56, 57, 58, 59, 60, 61 ... 74  Next
PostPosted: Tue Apr 30, 2024 4:55 am
rbuddy wrote:
I've been refining my bridge glue operation lately and have a quick tip to add.
I used to protect the top with cardboard and foil and heat the top area with a hot air gun ahead of HHG.
For the last three I tried a heat transfer block made of some handy 3/4 hardwood cut to the bridge shape and sanded to the top radius. I rounded off all the corners to protect the top if I drop it and gouged out some crude "handles" into the sides for grip. Heat by whatever means you choose.
I figured the contact with the top was about perfect and the wood would be unlikely get so hot, or hold so much heat, it would release anything unintended. Seemed like a safe approach and worked well. Nice to take more of the stress out of bridge gluing. For me, it's finally a routine process.
Heat it up, place it on the top while the bridge is heating and that's it. Eliminated heating tools other than a hotplate or something and all the protective stuff for the top. Easily warmed up the top to - hot to the touch and nothing more.
I made the bridge radius sander from MDF pushed around on a radius dish.
Very cool Brian. I have a tutorial I did on the OLF about this using the top dome with sand paper on it to shape the bridge bottom.
These days though we have moved on from this method and find a simple solution using a single edged razor blade to scrape the bridge bottom into the dome shape of the top much faster and easier. It's scrape, scrape, scrape and then trial fit and repeat until only light finger pressure is needed to have the bridge down everywhere including the wings.
Additionally there is the issue of increased "joint energy" at the molecular level where a recently scraped surface, less than 15 minute delay is said to glue better than a sanded surface that has sanding debris at the molecular level. Or, we always scrape bridge bottoms anyway just prior to gluing so scraping to shape has two benefits.
Al Carruth IIRC is who turned us all onto the idea of scraping a joint just prior to gluing years ago and we put it in practice in the commercial repair world. Thanks again Al.
These users thanked the author Hesh for the post (total 3): Chris Ide (Sun May 05, 2024 7:49 pm) • Robbie_McD (Sun May 05, 2024 5:43 pm) • rbuddy (Tue Apr 30, 2024 7:40 am)
PostPosted: Tue Apr 30, 2024 7:54 am
City: U.P.
Agree Hesh, I fit the bridge on the convex sander sometimes days or weeks ahead of the glue-up.
But I give the bottom of the bridge and the bare area of the top a light scrape just ahead of glue to clean and freshen up wood.
There was an article on surface prep for glue maybe in Fine Woodworking years ago. It suggested planed or scraped over sanded and possibly freshly done too.
On critical joints I always give a fresh scrape. I think that's a fairly common and not sure when I started or where I picked up the practice. I appreciate all of Alan's posts also, usually more in depth than I'd usually go so always something to learn.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: Hesh (Tue Apr 30, 2024 3:07 pm)
PostPosted: Thu May 02, 2024 3:58 pm
restoring a Froggy Bottom from 1978 a most interesting neck joint design. Douple tapered pin across the tenon. Doesn't let a lot of room to work.
These users thanked the author bluescreek for the post (total 3): Hesh (Sat May 04, 2024 8:02 am) • bcombs510 (Thu May 02, 2024 5:29 pm) • Kbore (Thu May 02, 2024 4:09 pm)
PostPosted: Thu May 02, 2024 4:00 pm
another pic
These users thanked the author bluescreek for the post (total 5): Hesh (Sat May 04, 2024 8:02 am) • Durero (Thu May 02, 2024 9:21 pm) • bcombs510 (Thu May 02, 2024 5:29 pm) • CraigG (Thu May 02, 2024 4:38 pm) • Kbore (Thu May 02, 2024 4:09 pm)
PostPosted: Thu May 02, 2024 4:06 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
That's the Gurian neck joint outlined in the Cumpiano/Natelson book. I actually used that neck attachment method on my very first build, using the Cumpiano/Natelson book as my guide! I quickly moved on to better methods.
These users thanked the author doncaparker for the post: bcombs510 (Thu May 02, 2024 5:29 pm)
PostPosted: Thu May 02, 2024 5:11 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Works great!
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post (total 3): Hesh (Fri May 03, 2024 6:20 am) • SteveSmith (Fri May 03, 2024 6:04 am) • bcombs510 (Thu May 02, 2024 5:29 pm)
PostPosted: Thu May 02, 2024 11:35 pm
First name: Karl
Last Name: Borum
bluescreek wrote:
another pic
John, how did you get those out?
Measure Twice,
Karl Borum
PostPosted: Fri May 03, 2024 6:20 am
Kbore wrote:
Works great!
Yay - looks great Karl nice work.
These users thanked the author Hesh for the post: Kbore (Fri May 03, 2024 9:40 am)
PostPosted: Fri May 03, 2024 6:24 am
Kbore wrote:
bluescreek wrote:
another pic
These work well for unserviceable neck joints. :) Swearing also helps.
These users thanked the author Hesh for the post (total 2): bcombs510 (Fri May 03, 2024 8:16 pm) • Kbore (Fri May 03, 2024 9:40 am)
PostPosted: Fri May 03, 2024 12:33 pm
when I looked in there I saw what I was up against. The first one went easy as the pin was below the surface of the side of the block. I cut about a 1/4 long piece off a 18 penny nail. I had to use my small adjustable wrench to tap on it , as a hammer wouldn't fit. In about 10 min it was out , so the 2nd one was one heck of a challenge. This took hours , as the pin was about 1/8 proud and I thought easy street. Well the dang thing flattened out flush to the block.
I tried about everything you can name. The holes are so far down and toward the side that you don't have a lot of working room. As an old toolmaker it was hard to get a good hand on measuring the pin hole center do I had to experiment a lot. With things so tite I had to be aware of swing area to tap and not hit anything. I even tried making a small C press but there was no room to tighted the screw. In the end. I just made a block that I could drill a hole to fit a 10 penny finish nail. I ground that to a point.This let me locate the nail on top of the I found lexan made the best holder as I could see the side of the block. I used double sided foam tape . This held the plastic , which held the nail so I could tap it out. The figuring out the holding fixture was the challange. I will convert this to a bolt on for sure
These users thanked the author bluescreek for the post (total 3): Hesh (Sat May 04, 2024 8:03 am) • bcombs510 (Fri May 03, 2024 8:16 pm) • Kbore (Fri May 03, 2024 3:05 pm)
PostPosted: Fri May 03, 2024 1:44 pm
Last Name: Parker
City: Charleston
In the Cumpiano/Natelson book, they describe how to make special long handle pliers that allow one to both drive the pins and push them back out. It would definitely be a hassle to remove the pins without the pliers. I think I still have mine somewhere, but I haven't needed them since I finished that guitar in 1996 (or thereabouts).
These users thanked the author doncaparker for the post (total 2): bcombs510 (Fri May 03, 2024 8:16 pm) • Kbore (Fri May 03, 2024 3:04 pm)
PostPosted: Sat May 04, 2024 7:24 am
First name: Brad
Last Name: Combs
Sawing and sanding
Brad
These users thanked the author bcombs510 for the post (total 7): Robbie_McD (Sun May 05, 2024 5:46 pm) • Kbore (Sat May 04, 2024 5:36 pm) • Durero (Sat May 04, 2024 1:25 pm) • SteveSmith (Sat May 04, 2024 8:19 am) • Chris Pile (Sat May 04, 2024 8:04 am) • Hesh (Sat May 04, 2024 8:04 am) • doncaparker (Sat May 04, 2024 7:42 am)
PostPosted: Sat May 04, 2024 8:04 am
bcombs510 wrote:
Sawing and sanding
Brad
Beautiful AND clean too work Brad very nice to see.
These users thanked the author Hesh for the post (total 2): Kbore (Sat May 04, 2024 5:37 pm) • bcombs510 (Sat May 04, 2024 8:49 am)
PostPosted: Sat May 04, 2024 8:05 am
Agree with Hesh - that is some outstanding work. Well done.
These users thanked the author Chris Pile for the post (total 2): Hesh (Sat May 04, 2024 12:40 pm) • bcombs510 (Sat May 04, 2024 8:49 am)
PostPosted: Sat May 04, 2024 10:53 am
City: U.P.
Too funny not to post a Saturday morning pic Brad. Swear to god not doctored, just moved the tools to the top for the photo.
Always amazes me how often different folks come to such similar methods. Often it just makes sense, others times it's almost scary.
You are more refined and your pics are better too! Some day I'll have a clean shop too.
N8ZED
These users thanked the author rbuddy for the post (total 3): SteveSmith (Sat May 04, 2024 1:45 pm) • Hesh (Sat May 04, 2024 12:41 pm) • bcombs510 (Sat May 04, 2024 11:53 am)
PostPosted: Sat May 04, 2024 12:16 pm
First name: Brad
Last Name: Combs
Love it! :D
PostPosted: Sat May 04, 2024 12:26 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I've been spending a significant portion of my time rubbing beetle excrement on a spruce and African Blackwood guitar the past week or so. Nearing the finish line soon.
These users thanked the author oval soundhole for the post (total 9): Robbie_McD (Sun May 05, 2024 5:48 pm) • Pat Foster (Sat May 04, 2024 9:05 pm) • Ken Nagy (Sat May 04, 2024 6:14 pm) • rbuddy (Sat May 04, 2024 6:07 pm) • Kbore (Sat May 04, 2024 5:38 pm) • Chris Pile (Sat May 04, 2024 4:06 pm) • bcombs510 (Sat May 04, 2024 3:20 pm) • SteveSmith (Sat May 04, 2024 1:45 pm) • Hesh (Sat May 04, 2024 12:43 pm)
PostPosted: Sat May 04, 2024 12:42 pm
Really nice Brian too!!! :D I have to tell you as a neat freak who has been called Felix Unger before, many times... it's nice to see others who are just as sick as I am :)
PostPosted: Sat May 04, 2024 12:43 pm
Wow Beautiful work Brian!!!
These users thanked the author Hesh for the post: oval soundhole (Sat May 04, 2024 8:29 pm)
PostPosted: Sat May 04, 2024 4:07 pm
Great photo, Brian.
These users thanked the author Chris Pile for the post: oval soundhole (Sat May 04, 2024 8:29 pm)
PostPosted: Sat May 04, 2024 10:36 pm
First name: Brad
Last Name: Combs
Sounds around the shop today. :)
https://youtu.be/4x4pNfYfwhM?si=NEVMf1G-xkVCBThL
These users thanked the author bcombs510 for the post (total 3): Durero (Mon May 06, 2024 12:29 am) • Hesh (Sun May 05, 2024 5:43 am) • SteveSmith (Sun May 05, 2024 4:02 am)
PostPosted: Sun May 05, 2024 5:47 am
Very cool Brad!!
Did you guys notice the orientation of Brad's nippers when he nips a fret end off? More specifically how he holds the jaws horizontal and not vertical?
This was something, a very small thing that we taught in our classes and it made me grin like an idiot this morning to see Brad doing it.
For an OLF tub of lard who wants to be the first one to correctly guess why we nip with the nippers horizontal and not vertical?
** Offer null and void for people who took our classes, only one entry per participant, offer not valid in states where it's prohibited. ;)
These users thanked the author Hesh for the post (total 2): Kbore (Mon May 13, 2024 9:02 pm) • bcombs510 (Sun May 05, 2024 8:08 am)
PostPosted: Sun May 05, 2024 8:10 am
First name: Juergen
Last Name: Gartemann
City: Bielefeld
State: NRW
Zip/Postal Code: 33719
Country: Germany
Hello Brad,
thanks for this video! Very good job, and I like the sounds so much [:Y:] ! There is only one sound I love more: the "singing" of a very sharp plane :)
Juergen
These users thanked the author Juergen for the post: bcombs510 (Sun May 05, 2024 9:13 am)
PostPosted: Sun May 05, 2024 11:23 am
City: U.P.
Great video Brad, but I couldn't figure out what was happening at 7-10 seconds. Is that a fret doctor to file back barbs on the tang? If so, what is your theory there.
Hesh, I'll bite -- cause that's the way the Summit nippers work those are the nippers I use too. I always bind fingerboards so the tangs are nipped off at the ends ahead of fretting. As such, I always nipped with the old style nipper with the cutting edge perpendicular to the FB. Reasoning has been it is less likely to send a shock wave up the fret possibly unseating it IMO. Change my mind.
Thanks guys!
N8ZED
These users thanked the author rbuddy for the post (total 2): Hesh (Tue May 14, 2024 5:55 am) • bcombs510 (Sun May 05, 2024 11:49 am)
PostPosted: Sun May 05, 2024 11:52 am
First name: Brad
Last Name: Combs
That’s correct, it’s the “Fret Barber” from StewMac. I was using that to take the tang down to .022” (slot is .024”) but only for frets 16-23, the ones over the body that are fretted through the sound hole. This was a tip from Dave Farmer. It just makes pressing them easier.
Brad
These users thanked the author bcombs510 for the post: rbuddy (Sun May 05, 2024 12:05 pm)
Users browsing this forum: CarlD and 16 guests
