It is currently Tue Apr 21, 2026 7:56 am
PostPosted: Sun Jul 07, 2024 4:54 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Does anyone use it? I have different grits of this, but only 60 grit of the cloth backed stuff. I would like to use my 120 grit roll for sanding spruce.
Sent from my SM-A546V using Tapatalk
Hutch
PostPosted: Sun Jul 07, 2024 5:28 am
this doesn't work the heat will allow the psa to let go. All drum sanders I ever saw have the spring tension unit to work with expansion. 120 is too fine and you will build up more heat. I used 60 and 80 on the drum sander before I went to wide belts
These users thanked the author bluescreek for the post (total 2): Kbore (Sun Jul 07, 2024 1:12 pm) • banjopicks (Sun Jul 07, 2024 5:38 am)
PostPosted: Sun Jul 07, 2024 5:43 am
First name: Richard
City: Warwick
State: RI
So, if o leave the backing paper on I should be good. This would just be for a finishing pass after my 60 grit hogs the wood close. I'll eventually get some more cloth backed paper, but I'm going to try this on my next guitar.
Hutch
PostPosted: Sun Jul 07, 2024 9:06 am
If the roll is wide enough you might be better off using it on a 1/4 or 1/2 sheet sander. Sanding spruce goes pretty quickly and the sanders are reasonably cheap.
PostPosted: Sun Jul 07, 2024 9:24 am
First name: Richard
City: Warwick
State: RI
I have a good ROS for doing it, so I really don't need to use my drum sander for finish sanding. It just seems like a good idea.
Hutch
Users browsing this forum: Cal Maier and 30 guests
