It is currently Sun Aug 03, 2025 12:17 am
Post new topic Reply to topic  [ 1829 posts ]  Go to page Previous  1 ... 61, 62, 63, 64, 65, 66, 67 ... 74  Next
PostPosted: Mon Sep 02, 2024 5:51 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Most of the work on the mandocello top braces is done.
These users thanked the author J De Rocher for the post (total 6): rbuddy (Thu Sep 05, 2024 12:27 am) • Kbore (Mon Sep 02, 2024 11:11 pm) • bcombs510 (Mon Sep 02, 2024 7:55 pm) • Ken Nagy (Mon Sep 02, 2024 7:05 pm) • Chris Pile (Mon Sep 02, 2024 6:52 pm) • Michaeldc (Mon Sep 02, 2024 6:27 pm)
PostPosted: Wed Sep 04, 2024 4:48 pm
My ES-335 build, in my knock down spray booth. Three more coats of Crystalac Britetone to go....then 30 days of cure.
These users thanked the author Anthony Z for the post (total 9): James Orr (Mon Sep 30, 2024 6:30 pm) • Ken Nagy (Fri Sep 06, 2024 10:53 am) • Darrel Friesen (Thu Sep 05, 2024 9:45 am) • Michaeldc (Thu Sep 05, 2024 7:16 am) • rbuddy (Thu Sep 05, 2024 12:28 am) • Kbore (Wed Sep 04, 2024 8:01 pm) • bcombs510 (Wed Sep 04, 2024 5:43 pm) • J De Rocher (Wed Sep 04, 2024 5:28 pm) • Chris Pile (Wed Sep 04, 2024 4:56 pm)
PostPosted: Tue Sep 10, 2024 8:45 am
First name: Ken
Last Name: Nagy
City: Goodrich
I glued up the little baroque guitar, that I'm making as an 8 string Uke. It has a dish in the belly, not a dome. The full size baroque guitar, and the 1600? Vihuela that I have plans for have the dished belly too.
To make a form to build on, I carved a dish into the shape of the guitar, and the vihuela. I cut a shape out of another piece of the cheap plywood, and used it as a dam to hold plaster of Paris, and I made a mold that will be the form. It sits right inside of the plywood dam, that has the neck on it too. The dished pattern used to make the mold is used to put the shape on the bridge. The bridge is glued on FIRST before anything else, so having the curvature where it should be on the form should help a lot.
I make a shape for a vihuela, and a guitar, because the guitar is longer and skinnier. The molds were made with the same dam/building board, so I have a double sided pattern for sanding bridges, the building board, and 2 plaster of Paris domed inserts to add the dish.
So I have the thing glued up. The ribs weren't long enough. But that will be fine, I'll figure out something! There are only 3 little tentalones? on the inside to hold the ribs in place. I used the blocks under the rods to mark where the line of the outline was, and butted the sides against them.
The next step is an odd one.
The Voboam guitars used a glue soaked rope, instead of a line of tentalones on the belly. The rope goes over the tentalones, and the braces. I have some rope, Oddly, the plan shows the same size rope on the little guitar as on the big one. I could do that. I'm not sure if they soaked the rope, just got it wet on one side, or did that and brushed glue on the sides and belly too. Maybe I'll see if the guy I bought the plans from knows for sure. You can't ask anyone from the 1700's.
Why be normal?
These users thanked the author Ken Nagy for the post (total 3): Darrel Friesen (Tue Sep 10, 2024 10:50 am) • DennisK (Tue Sep 10, 2024 9:40 am) • bcombs510 (Tue Sep 10, 2024 8:48 am)
PostPosted: Tue Sep 10, 2024 9:38 am
Last Name: Kincheloe
That's a whopper of a tail block! I assume it's made according to the plan, but do you have any idea why it's so big?
That's an interesting idea using rope for lining. If it were me, I'd dunk the rope in the glue pot, brush glue on the guitar, then pull the rope out of the pot while squeezing it with my fingers to remove the excess glue before laying it in the guitar.
PostPosted: Tue Sep 10, 2024 10:16 am
First name: Ken
Last Name: Nagy
City: Goodrich
Dennis, this photo will help you understand. It is undercut. The back is very thick, it is what holds it all together. The early bellies went a few frets past the neck join on the neck, for more support on the belly too.
I like your idea about how to glue the rope in.
Why be normal?
PostPosted: Wed Sep 11, 2024 8:08 am
First name: Ken
Last Name: Nagy
City: Goodrich
It always looks more like an instrument when the neck is on. Gluing the rope in was a bit messy, and I could have cut them a little longer. It will work for what it has to do.
The belly is pretty thin; a lot of it is 2mm or less; but you can see how the bearclaw, and the VERY fine growth lines really stiffen it up. There are 50 years on the bass side there; but about a dozen are in the overhang.
Why be normal?
These users thanked the author Ken Nagy for the post (total 4): J De Rocher (Wed Sep 11, 2024 10:29 am) • SteveSmith (Wed Sep 11, 2024 10:08 am) • bcombs510 (Wed Sep 11, 2024 8:57 am) • rbuddy (Wed Sep 11, 2024 8:38 am)
PostPosted: Wed Sep 11, 2024 9:13 am
City: Lawrence
Zip/Postal Code: 66047
Ken, is the rope made of hemp or something else?
PostPosted: Wed Sep 11, 2024 10:20 am
First name: Ken
Last Name: Nagy
City: Goodrich
Dave, I just checked. The label; from the trash; says, 80% cotton, 20% polyester! I saw that it said, Natural, and made in Turkey, so I thought it was all natural. Natural is the color! Yarn Bee Macrame 5mm rope from Hobby Lobby. I looked around a few stores, and that was the best thing I could find that looked like 5mm rope. I could probably find something, somewhere, more like what someone in 1700 would use.
But it seems like it worked. I have no idea where you find real rope. Tractor Supply?
Why be normal?
PostPosted: Wed Sep 11, 2024 10:53 am
Hmm, have my doubts about rope lings catching on.
Crochet perhaps, more decorative... ;)
PostPosted: Thu Sep 12, 2024 7:24 am
First name: Brad
Last Name: Combs
Working on a rosette for the dred:
Brad
These users thanked the author bcombs510 for the post (total 3): Hesh (Sun Sep 15, 2024 5:07 am) • Kbore (Thu Sep 12, 2024 10:28 am) • doncaparker (Thu Sep 12, 2024 7:32 am)
PostPosted: Thu Sep 12, 2024 9:49 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Beautiful design Brad.
Hutch
These users thanked the author banjopicks for the post: bcombs510 (Thu Sep 12, 2024 11:07 am)
PostPosted: Thu Sep 12, 2024 5:35 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Finally….
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post: bcombs510 (Thu Sep 12, 2024 6:03 pm)
PostPosted: Fri Sep 13, 2024 10:09 pm
First name: Brad
Last Name: Combs
A video showing the vacuum radius workboard - https://youtu.be/xlHxnEhtJws?si=fLDIuTMy1crCeQ-g
These users thanked the author bcombs510 for the post (total 2): Dave Rickard (Sat Sep 14, 2024 4:42 pm) • Kbore (Fri Sep 13, 2024 10:10 pm)
PostPosted: Sat Sep 14, 2024 11:29 am
First name: Karl
Last Name: Borum
Lovin’ the heating pad! First time I’v seen that.
Measure Twice,
Karl Borum
PostPosted: Sun Sep 15, 2024 9:02 am
City: U.P.
Not much since this rascal joined the team this last week. Not getting much done in the shop or sleep for that matter, but she sure is fun. (8 weeks old)
She may prove handy for dust collection and a lot of moral support I expect.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post (total 4): Michaeldc (Mon Sep 30, 2024 4:54 pm) • J De Rocher (Sun Sep 15, 2024 11:54 am) • Kbore (Sun Sep 15, 2024 11:40 am) • bcombs510 (Sun Sep 15, 2024 9:17 am)
PostPosted: Sun Sep 15, 2024 11:59 am
First name: Jay
City: Bothell
State: Washington
A future shop dog joined our family three days ago. This is Finnegan a 5-month-old possible border collie mix. Not much shop work getting done here either although I did manage to get the back fitted to the sides on a mandocello yesterday.
These users thanked the author J De Rocher for the post (total 3): rbuddy (Sun Sep 15, 2024 12:51 pm) • Michaeldc (Sun Sep 15, 2024 12:46 pm) • bcombs510 (Sun Sep 15, 2024 12:29 pm)
PostPosted: Sun Sep 15, 2024 12:49 pm
First name: Brad
Last Name: Combs
More fun with making jigs. :D
Brad
These users thanked the author bcombs510 for the post (total 4): Kbore (Mon Sep 16, 2024 10:27 pm) • rbuddy (Sun Sep 15, 2024 5:01 pm) • Durero (Sun Sep 15, 2024 4:08 pm) • doncaparker (Sun Sep 15, 2024 2:08 pm)
PostPosted: Sun Sep 22, 2024 12:04 pm
First name: Brad
Last Name: Combs
Brian, thanks again for the recommendation on the “cane tips”, they are great!
Brad
These users thanked the author bcombs510 for the post (total 3): rbuddy (Sun Sep 22, 2024 5:44 pm) • Durero (Sun Sep 22, 2024 12:27 pm) • Kbore (Sun Sep 22, 2024 12:16 pm)
PostPosted: Sun Sep 22, 2024 6:54 pm
First name: Brad
Last Name: Combs
Oh no!!
Oh, OK. :D
Brad
These users thanked the author bcombs510 for the post (total 3): Kbore (Fri Sep 27, 2024 1:31 pm) • Hesh (Mon Sep 23, 2024 6:04 am) • J De Rocher (Sun Sep 22, 2024 7:19 pm)
PostPosted: Mon Sep 23, 2024 10:56 am
State: West Somerset
Country: UK
Brad I love your neatly printed labels on all your jigs - obviously done with the CNC.
It puts our rough scrawls with felt tip pen in the shade! And that's even when we remember to do a label!
Cheers Dave
These users thanked the author Dave m2 for the post: bcombs510 (Mon Sep 23, 2024 11:12 am)
PostPosted: Mon Sep 23, 2024 11:33 am
First name: Ken
Last Name: Nagy
City: Goodrich
Brad; I looked at that a couple times before I saw what you were doing. I usually forget to even put a label in them!
Why be normal?
These users thanked the author Ken Nagy for the post: bcombs510 (Mon Sep 23, 2024 11:35 am)
PostPosted: Fri Sep 27, 2024 10:12 am
First name: Brad
Last Name: Combs
I’m not posting anything more here until someone not me, Ken or Jay posts.
:D
Brad
PostPosted: Fri Sep 27, 2024 11:23 am
First name: Juergen
Last Name: Gartemann
City: Bielefeld
State: NRW
Zip/Postal Code: 33719
Country: Germany
Hello Brad,
I think it isn't a label that you have forgotten. I think you mirrored MODEL: DC INST#24! I would not change that, it is unique!
Juergen
Gesendet von meinem SM-G950F mit Tapatalk
These users thanked the author Juergen for the post: bcombs510 (Fri Sep 27, 2024 12:20 pm)
PostPosted: Fri Sep 27, 2024 12:21 pm
First name: Brad
Last Name: Combs
Yeah, it was on purpose. :)
Dang it, broke my own rule!
PostPosted: Mon Sep 30, 2024 4:23 pm
First name: Mark
City: Seattle
This amp project is still filling my bench and my time.
It is actually closer to being done than it might appear. The reverb send, reverb return, and negative feedback have been dialed in on the breadboard appendage, and it is ready to drill a couple new holes on the control panel, and start permanent wiring.
These users thanked the author pullshocks for the post (total 5): Anthony Z (Fri Oct 04, 2024 10:18 am) • Kbore (Tue Oct 01, 2024 12:21 am) • bcombs510 (Mon Sep 30, 2024 7:43 pm) • James Orr (Mon Sep 30, 2024 6:32 pm) • Michaeldc (Mon Sep 30, 2024 4:55 pm)
