It is currently Fri Sep 12, 2025 9:20 am
PostPosted: Wed Jul 09, 2025 8:19 pm
First name: Alex
Last Name: Takacs
I'm gearing up to build a large acoustic baritone guitar, and I'd like it to have a wide lower bout (17"-18"). I'd also like to use torrefied Sitka Spruce, but I'm having trouble finding sets that are larger than 8 1/2" wide. I'd like to have at least an extra half inch on each board, so I'm looking for cuts of torrefied spruce that are a minimum of 9" wide, ideally 9.5"+. Does anybody know where I could find a top set of this size?
PostPosted: Wed Jul 09, 2025 8:43 pm
Alaska Specialty woods.....
PostPosted: Wed Jul 09, 2025 9:28 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
Brent at Alaska Specialty advertises some torrified tops at 8.5” minimum. If you called or emailed him, he might consent to picking out some for you above the minimum. That said, taking the cutoffs from the upper bout and carefully matching the grain and runout and moving them down to the wings on the lower bout would make the joints there undetectable. I’ve done where I knew it was a 4 piece top but wondered later if it was.
These users thanked the author bobgramann for the post: Kbore (Wed Jul 09, 2025 10:37 pm)
PostPosted: Thu Jul 10, 2025 5:08 am
Welcome to the OLF Alex. Sounds like a great project you have.
PostPosted: Thu Jul 10, 2025 4:35 pm
First name: R.M.
Last Name: Mottola
Yet another recommendation for Alaska Specialty here. Contact Brent and let him know your dimensional requirements. If the plates will be wider than conventional they will likely be longer than conventional too. The last oversized tops I got from him were intended for harp guitars, but worked well for my ABGs. Oh, and if it is possible to reconsider the torrified requirement, there may be more options available to you.
R.M. Mottola
LiutaioMottola.com
Author of the books Building the Steel String Acoustic Guitar, Practical Design of the Acoustic Guitar and Similar Instruments, and Mottola's Cyclopedic Dictionary of Lutherie Terms.
I don't check in here very often. If you need to contact me the best bet is via email through the contact page on my site.
PostPosted: Fri Jul 25, 2025 4:15 pm
OLF Sponsor
OLF Sponsor
First name: Brent
Last Name: Cole Sr
City: Craig
State: Alaska
Zip/Postal Code: 99921
Country: USofA
We have at least one LOL!
I just took a tape measure to the shelves. Most are at or just under 9" wide, But there are a few wider. The stack I looked at was the AAA NF sort.
Hit us up. brent@alaskawoods.com
Users browsing this forum: Bryan Bear and 28 guests
