It is currently Fri Jun 27, 2025 12:34 am
 Post subject: Anchoring Hanger Bolts
PostPosted: Sun Aug 12, 2012 2:24 pm
Last Name: Killin
I’m about to attach my neck to my body using a butt joint with hanger bolts. For those hanger bolt users out there, do you use anything type of glue to “Lock” them into the neck like CA or Epoxy?
PostPosted: Sun Aug 12, 2012 3:04 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I don't think anything is necessary but I put a little hot hide glue on them, since my glue pot is always near by.
PostPosted: Sun Aug 12, 2012 5:25 pm
I don't use any glue on hanger bolts. A 1/2" maple dowel installed through the heel providing cross grain for the theads to grab onto is more than sufficient.
Chuck
PostPosted: Mon Aug 13, 2012 3:51 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Chuck
This is a great idea. I've had them pull out of mahogany end grain before. I've got one neck that I have been looking for a fix. This is it!
Thanks.
PostPosted: Mon Aug 13, 2012 4:56 pm
First name: Woodrow
Last Name: Brackett
City: Grover
I use a maple dowel, and always have. The glue isn't to keep the bolt from pulling out, it's to keep it from unscrewing when you unscrew the nut. I doubt it's necessary, but it doesn't hurt anything.
PostPosted: Mon Aug 13, 2012 10:24 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I agree, the dowel should be all you need. But. . . I usually put in thin CA, because, well why not?
Bryan Bear PMoMC
PostPosted: Mon Aug 13, 2012 11:22 pm
Last Name: Killin
That is what I was thinking. I put in a maple dowel so structurally I think I'll be fine. But once the fret board is glued down, I'd rather not accidently unscrew the bolt from the neck.
I have a bit of time before I commit myself so I’ll weigh out the options and try not to over think it.
PostPosted: Tue Aug 14, 2012 12:11 pm
Mine are all neck resets, not new builds. I wick water thin CA in after they're installed.
https://soundcloud.com/jeffreylsuits/he ... -runnin-13
Users browsing this forum: Heath Blair and 24 guests
