It is currently Mon Jul 28, 2025 11:19 am
 Post subject: routing headstock
PostPosted: Wed Nov 28, 2012 8:22 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
I've just used a template to rout out the headstock using a flush cutter. In some places the wood chipped off. The cutter is new so I presume sharp. I'm not that worried as it's a fun instrument for a charity auction but I was wondering if others who use this technique could share some tips on avoiding chip-out?
We are all in the gutter but some of us are looking at guitars.
 Post subject: Re: routing headstock
PostPosted: Wed Nov 28, 2012 8:39 am
Last Name: Ensor
City: Springfield
State: Missouri
Cut close to your outline on the bandsaw so that you can take light passes with your router. Always avoid routing uphill on the grain. This means sometimes you will have to use a climb cut.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Wed Nov 28, 2012 8:41 am
Last Name: coloccia
Country: States
The best thing you can do is cut as close to the line as you possibly can before routing, and then route slowly. especially around the corners. It always wants to chip out around the corners because there's always unsupported wood there.
PostPosted: Wed Nov 28, 2012 10:03 am
....or use a pattern sander
Milton, ON
PostPosted: Wed Nov 28, 2012 12:01 pm
First name: William
Last Name: Snyder
City: Brooklyn
+1
Sander here as well plus a sharp chisel to define any sharp corner the sander can't get into.
PostPosted: Wed Nov 28, 2012 1:58 pm
First name: Shawn
Last Name: Smith
City: Indianapolis
http://www.3riversarchery.com/Arrow+Bui ... oduct.html
I like $2 tools.
"All of us contain Music & Truth, but most of us can't get it out."
- Mark Twain
PostPosted: Wed Nov 28, 2012 2:03 pm
I like $2 tools.
That's the idea, but I'm pretty sure that's just the cylinder for $2, not the robosander. BTW I use a 2" diameter.
Milton, ON
PostPosted: Wed Nov 28, 2012 2:13 pm
First name: Shawn
Last Name: Smith
City: Indianapolis
Dave Stewart wrote:
I like $2 tools.
I haven't ordered that one myself, but on another wood working forum some folks were chatting it up as it a super cheap pattern sander. I assumed it came with the sanding cylinder and the bearing. easily could be wrong.
- Mark Twain
PostPosted: Wed Nov 28, 2012 2:26 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
+1 for template/pattern sander http://www.leevalley.com/en/wood/page.aspx?p=59448&cat=1,42500
Fred
Fred Tellier
PostPosted: Wed Nov 28, 2012 5:23 pm
Guess I'm a bit of a neanderthal - I draw the pattern on the headplate with a template, cut close to the line using a bandsaw (with the headplate clamped to an angled jig thing to hold if flat) and then finish up freehand on an oscillating sander.
PostPosted: Wed Nov 28, 2012 5:29 pm
First name: Trevor
Last Name: Gore
City: Sydney
I generally pattern rout headstocks and there are a couple of tricks. The first is to minimise the amount you rout off, by cutting close with the bandsaw, BUT leave wood on where you would expect a blow-out. For example, I usually do the first cut across the top of the headstock, so I trim close with the bandsaw, only across the top, then pattern rout across the top, THEN bandsaw the sides, etc., cutting off any wood that blew out from the top cut. Work out the sequence of cuts with respect to where you would expect blow-out, using climb cuts if necessary and you should be able to do them all without leaving a risky cut unsupported. A spiral cutter also helps. Pattern sanders work too, of course, but are generally much larger diameter than a router bit and so limit the inside radius you can do.
http://www.goreguitars.com.au
PostPosted: Wed Nov 28, 2012 6:04 pm
Last Name: coloccia
Country: States
Half the time, I don't even do that. I just finish it by hand with rasps, scrapers and some sanding. It really doesn't take that long. I wish I was good enough to use the spindle sander. Somehow, I always end up with little bumps and dents that I need to work out by hand.
PostPosted: Wed Nov 28, 2012 6:12 pm
Trevor - the sequence thing is a great idea. Thanks for sharing that!
PostPosted: Wed Nov 28, 2012 6:24 pm
My solution for this.
PostPosted: Wed Nov 28, 2012 7:13 pm
I pattern rout with a Robosander and the Lee Valley stabilizer which helps a lot. http://www.leevalley.com/US/wood/page.a ... at=1,42500 Leaves about 1/32" proud of the pattern.
Follow that with the router table. I've had no issues with blow out with this approach. Do the same with bridges.
PostPosted: Wed Nov 28, 2012 9:35 pm
First name: kevin
Last Name: waldron
City: Bell Buckle
Zip/Postal Code: 37020
Scroll saw works wonders for doing headstocks.... Scroll saw with a large throat also has a number of other usual features for luthier.
Blessings,
Kevin
PostPosted: Wed Nov 28, 2012 10:23 pm
First name: Gary
Last Name: Lee
I use a bandsaw to rough cut followed by template routing with a Whiteside spiral flush trim, two-flute, down-cut cutter (part #RFTD2100). I have never experienced chip out.
PostPosted: Thu Nov 29, 2012 12:39 am
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
I use a .5' cutter with a top bearing. The first cut (after cutting close to the template with a coping saw) is done with a .54' bearing, and then I make one more cut with a .5" bearing. I used to just use the .5" bearing but then found that I would get burn marks and slight tear out occasionally. Now I dont.
PostPosted: Thu Nov 29, 2012 4:36 am
First name: joseph
Last Name: sallis
Country: UK
There's lots of options for me to choose from next time I have a go. The pattern sander seems the safest but maybe limiting on the shape of the headstock. Todd's and Trevor's advise is what I was looking for. Have to study Robbie's video a little closer.
Thanks everyone for your imput it's always interesting to see so many variations on one process. Any more?
PostPosted: Thu Nov 29, 2012 10:16 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
I use a template cutter and a template for my headstocks. The key is to rough cut close to your final shape using the bandsaw and to have your headstock firmly clamped to your bench. If the headstock can twist or turn even the slightest, the bit can grab and tear out a chunk o' wood.
Ken
http://www.casperguitar.com
PostPosted: Thu Nov 29, 2012 11:37 pm
2 words: Spiral Carbide.
-C
Freeborn Guitars
and home of BeauGuard©
PostPosted: Mon Dec 03, 2012 12:02 am
First name: Tom
Last Name: Langseth
City: HORSESHOE BAY
State: TEXAS
Zip/Postal Code: 78657
What Trevor said...
I learned the value of routing end grain first, then side grain, back when I was building "raised panel" cabinet doors and drawers. With same woods such as most oaks, I will always got blow out if I didn't follow that routine. 8-)
Tom
I spent most of my money on women, guitars and whiskey, the rest I wasted.
PostPosted: Mon Dec 03, 2012 8:18 am
First name: joseph
Last Name: sallis
Country: UK
tomlang wrote:
What Trevor said...
Tom
It's tips like this that are one of the reasons this forum is so great, thanks.
-C
Good tip, too, thanks.
Users browsing this forum: Cal Maier and 8 guests
