It is currently Thu Aug 14, 2025 4:56 pm
 Post subject: Superglue and shellac
PostPosted: Wed Jan 16, 2013 1:24 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
I need to use some superglue on the rosette I'm currently doing, but testing shows that it makes a stain that can't be scraped out. I think I've heard people say you should coat it in shellac first, but I've never used it and don't have a clue. idunno So what do I buy? Is the stuff in bottles called 'french polish' the same as premixed shellac? After I've glued everything down, do I have to remove the shellac before finishing?
Incidentally, could I also use it as a pore filler under varnish?
Pablo Picasso
PostPosted: Wed Jan 16, 2013 1:35 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Buy shellac flakes and alcohol, denatured works OK. Dump some flakes in a jar, pour in about as much alcohol as flakes and let it dissolve. Should only take a couple of hours. You may want to add a little more alcohol if it seems too thick.
You don't need to remove the shellac. You can use it as a pore filler, but it takes several coats.
PostPosted: Wed Jan 16, 2013 1:41 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
Zinsser universal sanding sealer, wax free shellac , available at Lowe's and various woodworking places...
MK5acoustics.com
PostPosted: Wed Jan 16, 2013 1:49 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Thanks. What sort of shellac do I need? Does it have to be dewaxed?
Edit: cross typing!
Pablo Picasso
PostPosted: Wed Jan 16, 2013 2:25 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
btw, "denatured alcohol" is, as you probably already know , USA speak for "methylated spirits" ...
PostPosted: Wed Jan 16, 2013 2:32 pm
First name: Ringo
No, not a good idea... you are much better off with other pore fillers
PostPosted: Wed Jan 16, 2013 4:37 pm
Country: England
Is shellac sanding sealer the same thing as the flakes?
PostPosted: Wed Jan 16, 2013 5:25 pm
First name: William
Last Name: Snyder
City: Brooklyn
The Zinsser sealcoat (not their shellac finish) is just dewaxed shellac and alcohol. I don't really know about others.
PostPosted: Wed Jan 16, 2013 6:25 pm
First name: William
Last Name: Snyder
City: Brooklyn
Hey Todd, when you are you talking about aerosol cans when you say spray shellac? If so, I might have to check those out-never given them a look before and could be pretty handy. Also good to know that the sealcoat contains a stabilizer-I've been buying the small cans ever since I switched over (from mixing my own) to using it for general sealing applications because I figured it would go bad before I ran through a gallon.
PostPosted: Wed Jan 16, 2013 8:02 pm
Be careful if you buy by the gallon and keep for extended periods. It'll eat through the bottom of the can. I have a well shellaced floor in an area of my shop.
PostPosted: Wed Jan 16, 2013 11:00 pm
First name: Darryl
Last Name: Young
State: AR
To Todd's point about using CA to drop fill pearl inlay in a rosette. I assume one should use medium viscosity CA for this. Any chance of it wicking under a Martin 45 style B/W plastic purfling surrounding my Ablam rosette and staining the surrounding spruce?
I'm about to start sanding/finishing so this thread is timely.
PostPosted: Wed Jan 16, 2013 11:25 pm
First name: Phil
Last Name: Hartline
City: Warrior
State: Alabama
For mixing your own from flakes, give yourself an extra day for it to dissolve. I never had much luck getting it in two hours, even though it is just dissolving. Best to give yourself plenty of time.
Phil
http://www.oleninstruments.com
"Those who tilt at windmills are only considered insane by those who can't see the dragon."
PostPosted: Wed Jan 16, 2013 11:28 pm
First name: Patrick
Last Name: Hanna
State: Missouri
If you go the route of shellac flakes and alcohol, DO buy dewaxed shellac. When dissolving the flakes, a tall olive jar (washed out, obviously) is excellent for the purpose. Shake the heck out of the bottle every fifteen or thirty minutes while your flakes are dissolving. If you don't, you might get a substantial layer of glop in the bottom that will be slow to dissolve. Label and date your mixture. After a few months, you may use it to seal jigs and fixtures, but it's best to use only fresh stuff on your instruments. When it's six months old and you have not found a use for it, discard it, wash your jar with alcohol, and mix a new batch.
Apart from this advice--most of which was learned the hard way--shellac is excellent for sealing rosette channels, binding channels, etc., before using various glues. Thinned shellac is also excellent for sealing oily woods before applying finishes.
Users browsing this forum: Bing [Bot] and 25 guests
