It is currently Sun Aug 17, 2025 10:17 am
PostPosted: Sun Feb 17, 2013 10:51 pm
First name: Larry
Last Name: Hawes
I just ordered the wrong stuff from LMI (really hate their web store) or at least purfling that I've never installed before. It's about 1/4" deep, same as the binding. I'll need more, narrower, purfling any way so I can install the bottom purfling but haven't used full height purfling before and was wondering it I even want to and what are some land mines (that I'll surely step on) to avoid.
I'm thinking for one thing if I add the bottom purfling to the binding then that combination will be taller than the binding requiring a custom channel anyway or not? Not there yet but am curious about some options.
Thank You and Best To All
PostPosted: Sun Feb 17, 2013 11:37 pm
After the main binding route,I don't like the purfling route to be more than 2/3 through the soundboard, especially if I'm doing a herringbone or somethng wider so I don't risk routing past the kerfings and separating the top from the ribs.
Old growth, shmold growth!
PostPosted: Mon Feb 18, 2013 12:30 am
First name: Trevor
Last Name: Gore
City: Sydney
LarryH wrote:
I just ordered the wrong stuff from LMI (really hate their web store) or at least purfling that I've never installed before. It's about 1/4" deep, same as the binding. I'll need more, narrower, purfling any way...
Rout a quarter inch channel in a piece of wood, saw up the middle of the channel with a narrow bandsaw blade and you have a zero clearance jig for slitting your wide purfling down to normal size (and you get twice the purfling for the price).
http://www.goreguitars.com.au
PostPosted: Mon Feb 18, 2013 1:13 am
Kewl, what do you use to slit the purfling? An x-acto?
PostPosted: Mon Feb 18, 2013 4:06 am
First name: Trevor
Last Name: Gore
City: Sydney
The bandsaw. 10TPI blade, 1mm kerf (if you'll live with the mixed units). Leaves you with two purfling strips ~2.7 high, which is pretty much what "standard" purfling is.
All the bloodwood purfling on this guitar was done like that. The purfling is 3 laminations to make the bending easier.
PostPosted: Mon Feb 18, 2013 9:11 am
Here's an early "slitter" tutorial I did if it helps
viewtopic.php?f=10117&t=19132&p=269357&hilit=slitter#p269357
Milton, ON
PostPosted: Mon Feb 18, 2013 10:13 am
First name: Larry
Last Name: Hawes
Thanks very much for the tips and oh goodie another jig :D
Users browsing this forum: ballbanjos and 17 guests
