It is currently Fri Apr 17, 2026 2:40 pm
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Nov 11, 2013 2:49 pm
First name: Fred
City: Winnipeg
Fir does like to split and chip off a piece. Also the difference in hardness between the growth rings is a bit of a pain. Because I added a piece to the top of the neck the headstock angle moved back and I lost some room I was going to use for the barrel nuts. Used threaded inserts instead. Had to drill out part of the popsicle brace so there would be clearance for the truss rod nut. Not a big deal as it is a three piece top.
Getting the neck joint perfect was a pain. Then I go and cap off the end with some birch, file it down and bugger up part of the neck joint. That fir does not take abuse all that well. So now I have to do it over again. Shaped the heel block, lined up the grain on one joint, the other did not turn out as well. Next I guess is slotting the fretboard.
PostPosted: Mon Nov 11, 2013 3:51 pm
City: chicagoland
State: illinois
fir doesn't take anything well; it is horrible wood to work with in my experience
PostPosted: Tue Dec 03, 2013 3:23 pm
First name: Fred
City: Winnipeg
Going to use some brown Purpleheart as the bridge.
Used some of the Purpleheart as the side markers, don't want to put in any makers on the front.
Had a heck of a time sanding it smooth, the dark bands would sand less creating ridges. Scraped them with a razor blade and sanded it even. Flooded the neck with CA which hardened the summer growth of the Fir. If I ever use Fir again I will CA it before getting it to the final shape. Just used Z-Poxy to level out the guitar. Even though this was my worst wood set it does not look all that bad.
PostPosted: Sun Dec 15, 2013 9:23 pm
First name: Fred
City: Winnipeg
Well nobody can accuse me of doing things the easy way. Or careful planning. Sounds bad doesn't it?
Grabbed a bag of tuners, just cheap ones as I am in learning mode, drilled the holes for them, and then found they are all right handed. Looked at another bunch I have, same thing. I never intended to make an acoustic and entered this rabbit hole with the intent of doing a couple of Telecasters. Found a store in town that has a half decent selection of tuners but the size I want to use was more than I wanted to pay. So until I get some chrome ones I will have to use some black ones (why the heck did I buy them again, oh yeah $7 with shipping).
Drilling out the holes for the tuners did not go as smoothly as it could either. The Fir split in the back a little as the drill went through even though I used a backing board. Won't will any beauty pageant with this guitar.
So next I sanded the back of the bridge to the top contour. Looked up the saddle distance with Stew Mac's calculator and was going to router out the slot. Well I did buy a bit for it, it is here somewhere. After an hour looking for it gave up on the router and got out a Dremel bit. Problem is I do not have a base for the Dremel and can only hand hold it. Good thing the Mother of Invention came by with a bunch of clamps.
Glued a piece of wood on the bridge so sliding it along the guide cuts a slot at an angle. Rather than lower the bit into the wood I slid some sheets of steel under the bridge pushing it up. Actually worked fairly well.
My next concern was getting the bridge in the right position. Heck with this 'measure twice and cut once', I decided to string up both E strings and slide the bridge till I found the right location for it.
More clamps, small dented in the top at one spot, marked off the bridge location with a piece of masking tape. I do not have the frets in yet so I took a solid copper wire and ran it across the fret location and twisted it around the back.
Might be a little premature saying it but this thing does sound like a guitar even cobbled together as it is. It has always been a concern going through all this trouble and ending up with something to hang on the wall. Only two strings and four notes but did not hear anything that sounds bad. Can't wait till it has six strings on it.
PostPosted: Wed Dec 25, 2013 11:18 pm
First name: Fred
City: Winnipeg
Where was I? Oh yeah, vacuumed on the bridge. Used a pair of vacuum cleaner motors to suck, some hose, food wrap and masking tape, worked like a charm.
Sometimes I do things backwards. Probably should have sanded the bridge off the top. Ended up not too bad anyway.
No reamer so I cut some 1/16" steel at a 3 degree taper and used it.
Still needs to be set up but does play. Caught a few dings in the last two weeks and messed up on the neck joint, next one will be better.
That was fun, let's do it again some time.
