It is currently Sun Jul 27, 2025 3:11 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jul 31, 2014 1:30 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
Thanks Kerry. No I didn't make a typo. The measurements are as I gave them. I was somewhat taken aback. But did go to Wikipedia and they certified it is actually closer to 24" then twenty three. I was sure that once I got the fretboard and it was slotted for a "Tenor" then I'd be ok. Now I think maybe the ebayer I bought it from maybe miss led me somewhat. It is a 19 fret board with lots left over. Thinking maybe made for a tenor banjo. I have no qualms about making a tailpiece and moveable bridge. Intonation is simple just move it till it's correct.
I'm quite sure I can also make a set bridge as well.
Now my question would you measure from the zero fret to the twelfth fret. Or from the nut? I would say the zero fret takes the nut out of the equation. However I could shorten the board the 1/8" that makes up the zero fret. Then I'd still be going from the nut to the saddle. The measurement at the 12th would be 11 1/4". Hope I cleared it up. Yes I was surprised at the zero fret as well as the 23 3/4" scale.
PostPosted: Thu Jul 31, 2014 1:41 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
My math was wrong. It should be 22 3/4" don't know how I did that but fit it in a hurry with my measuring tape and a piece of paper to show the bridge. I would have caught it when I measured with my straight edge. Nowhere near that stage yet however.
PostPosted: Thu Jul 31, 2014 3:27 pm
Last Name: Orr
Re your English wood guitar Nick I love it. Have you tried bending the walnut sides yet. I just tried bending some black walnut sides for an OM today and cracked both of them. Have enough left of the billet to cut another two but any info on bending would be much appreciated. I use a hot p[ipe and tried it dry and soaked with water but it just did not want to bend at all!
Cheers, Bob
PostPosted: Thu Jul 31, 2014 6:56 pm
Thanks, Bob! Really nice to hear! :D
Cheers, Bob
I'm afraid I can't give you any expert advice about bending walnut, the following signature I've been thinking of using here should explain why...
Don't let my post count on the OLF fool you, I'm a rank amateur! I just enjoy talking about guitars! :lol:
But I'll try to give some [very] non-expert advice:
I'm bending on a form with a blanket this time. I've been practicing with khaya (African hog) and there hasn't been a hint of a crack. I am a little worried about the walnut though, I took the sides down earlier to prepare them for bending and they each had a crack in exactly the same place.... Thankfully, the sides were extra wide and the cracks formed on the edge I was planning on cutting/planing off anyway. I tried to split the cracks further but they seemed to have reached their natural end, so I'm hoping/pretty sure that they won't develop again. I'm planning on thicknessing them to 2.1mm, and planing them to this kinda shape (without the recurve, just the two lines)...
I've bent sides rectangular till now but I'm trying to stack the odds in my favour by cutting off more of that danger area where the split occurred... (I should've known that'd be a danger area, if you look at the pic of my walnut again, you'll see some very short grain at the end of the sides. I should be able to get rid of all of that before bending.)
I'm going to bend moderately wet, I think. Just spraying the brown paper before wrapping it around the side. On a pipe, I'd advise you to re-wet the side with a spray bottle wherever and whenever it visibly dries out, remembering that the water will cool it down so it needs time to reheat. Other than that, the usual advice stands, I suppose: heat the area you're going to bend thoroughly and try to "feel" the wood "release" before applying too much force. In my [limited] experience, and from what I've read, it can take 5-10 minutes of heat application to an area before it "releases". That's more than I ever expect it to take. The best piece of advice I have when bending on a pipe, I only learned when bending the binding for my last guitar (after struggling to bend the sides on the pipe): When a bend is done, the waist for instance, take it off the pipe and hold it in that shape for 2 minutes minimum, or the bend won't set. I found counting to 120 or more worked well. It was a real epiphany for me! Till then, I'd been wondering why I had to keep re-bending the same area.
You're lucky to have more sides from the same billet. If I crack mine tomorrow, I'm in trouble! Did yours crack in the same place on each? did they crack along short, or otherwise dodgy grain? Or was it just too much force/not enough heating?
Hope this is of some help! And thanks again for the compliments on my English guitar design!
All the best,
Nick
EDIT: Other advice would be a thin steel slat or two to help better distribute the bending force. Or even just bending it with brown paper around it to hold in some of the moisture(?).
PostPosted: Thu Jul 31, 2014 10:16 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
I've only bent walnut once. Last week I bent two sides for a baritone Uke. Soaked overnite then bent on #5 on my Stewmac bending iron. Had no difficulties at all. Only thing is it was so pliable. If that's the correct word. Placed it in my mold and braced it in there. While bending I did spritz with water when it got dry.
PostPosted: Thu Jul 31, 2014 10:42 pm
First name: Kerry
Last Name: Werry
City: Coquitlam
State: British Columbia
Yep the zero fret takes the nut out of the equation.. Yes if you cut the board at the zero fret you could just use it with a nut as a "normal" fretboard.
Kerry
My Website http://klw-strings.com
My Luthier's Blog...http://klwstrings.blogspot.com
PostPosted: Thu Jul 31, 2014 10:47 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Thanks Kerry I did repost that my math was off. It measures 22 3/4". I'm not at all familiar with a zero nut. I've heard lots of discussion to and fro. I do have a guitar with a zero nut. Personally I guess I'm just old fashioned I like the nut. So I'll probably remove the zero fret. I feel that if I were to measure exactly to the 12th fret and double that measurement would give you you the exact saddle placement. Works on other guitars. If I do that and set the bridge I'm stuck with it. Any thoughts?
PostPosted: Fri Aug 01, 2014 12:25 pm
First name: Kerry
Last Name: Werry
City: Coquitlam
yes it's just a guitar with a bit shorter scale and 4 strings you will of course have to include whatever you do for compensation. I have found that for compensation what I do for 6 string guitars seems to work for my tenors, maybe a hair less but as i say it's not my strong point.
Kerry
PostPosted: Fri Aug 01, 2014 12:27 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Thanks Kerry
PostPosted: Sat Aug 02, 2014 4:13 pm
Glenn LaSalle wrote:
Haans wrote:
Another goal of mine is to try to achieve that Stella tone in on shorter scale. Twenty-six and 1/2" is just too long for me.
Hi Hans,
When you figure that out, I would love to get in on the secret :-). I am building a 25.4" scale GC in white oak now (albeit, it takes me a long time to finish guitars). I plan to brace it as close to the 2 Stella GC guitars that I own. I love the 26.5" scale for bottleneck... but conventional fretting, its a bear.
Glenn
I am also building a 25.4" in white oak Ready to finish.-Cant wit to hear it!
The Alfie Smith guitar I just finished has a 24.9" scale and I and the new owner are very happy with the sound-very easy to play.
PostPosted: Sat Aug 02, 2014 7:49 pm
First name: Wayne
Last Name: Brown
City: Huntersville
Zip/Postal Code: 28078
I'm building a 3/4 size or Terz guitar. B&S are of local maple (not too stunning) Scale is 21.375" Will be a Christmas gift for #2 grandson. The body is complete and need to finish carving the neck! Then on to the finishing!
PostPosted: Sun Aug 03, 2014 12:29 am
Last Name: Sonksen
City: PORTLAND
State: Oregon
Zip/Postal Code: 97216-2013
here's some pics of my latest,
https://fbcdn-sphotos-d-a.akamaihd.net/ ... 7352_n.jpg
https://fbcdn-sphotos-f-a.akamaihd.net/ ... 1c24b6af82
PostPosted: Sun Aug 03, 2014 5:20 am
13 fret 000 with Walnut from Larry Davis and Sitka top. Image
PostPosted: Sun Aug 03, 2014 6:24 am
State: Tennessee
Very nice, just saw your thread on aging the new top for the J-45 looking froward to seeing these :mrgreen:
PostPosted: Sun Aug 03, 2014 9:00 am
First name: D
Last Name: S
John Sonksen wrote:
Really nice work, John!
I bet the binding was difficult to do.
The knob depressions look perfect. The head is awesome.
The guitar and hardware finishes are very cool!
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: John Sonksen (Sun Aug 03, 2014 9:58 am)
PostPosted: Sun Aug 03, 2014 10:11 am
Last Name: Sonksen
City: PORTLAND
State: Oregon
Thanks Dan, I really worked to the edge of my skills and knowledge on this one. I was a bit nervous towards the end that it was all going to end up being too busy and wild, but I'm happy with how it came together. I need to get some better pics up after I finish a couple things.
PostPosted: Sun Aug 03, 2014 10:56 am
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
John that is one pretty guitar
These users thanked the author Lonnie J Barber for the post: John Sonksen (Sun Aug 03, 2014 12:30 pm)
PostPosted: Sun Aug 03, 2014 2:11 pm
Those 4 boxes you've got parked on the bench look great! You've been busy [:Y:]
Hope you can make it to the luthier meeting next week.
PostPosted: Sun Aug 03, 2014 7:19 pm
First name: sam
Last Name: guidry
State: michigan
Country: us
There are so many luthiers building essentially perfect examples of guitars nowadays that I feel it is hard to be original as here are only so many ways to design an acceptable guitar.
Finding a way to establish a style of your own is the true challenge of a maker after they have mastered the "construction" of the instrument.
Who you are as a maker should show through your work. My latest is an expression of how I feel when I make a guitar, or to the question of how you build a guitar.
My answer is one piece at a time ;)
PostPosted: Sun Aug 03, 2014 7:47 pm
First name: Ringo
Ha, that's pretty sweet Sam. I bet folks will wonder whether the upper bout 'pieces' will pop out to make a soundport.
PostPosted: Sun Aug 03, 2014 9:43 pm
First name: Kent
Last Name: Wilkinson
City: New Carlisle
State: Ohio
Zip/Postal Code: 45344
I can't really afford to rent a shop any more, so my current project is converting my 10 by 20 shed into a shop. Iv been insulating, running electric, and dry walling it.
PostPosted: Mon Aug 04, 2014 5:46 pm
First name: D
Last Name: S
Whoa, Nelly, Sam!
That's a bunch of spectaular mixed with awesome.
I like the clear Maple. It has the "I want to touch it" look.
Very clever design.
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: uvh sam (Mon Aug 04, 2014 7:11 pm)
PostPosted: Sat Aug 09, 2014 10:06 am
First name: Jamie
Last Name: Unden
City: Lakeside
Zip/Postal Code: 92040
I have a couple going right now. (Don't we all?)
I have an electric four pickup going for one of my grandsons:
http://www.guitarplansunlimited.com/In%20the%20shop%20pages/Jamies%20Pawn%20Shop.html
And I have a goofy thing going that I'm calling a Dano-Lego:
http://www.guitarplansunlimited.com/In%20the%20shop%20pages/Dano-Lego.html
PostPosted: Sat Aug 09, 2014 10:57 am
First name: D
Last Name: S
Those are really cool, Jamie!
Your grandson is a lucky duck!
wah
Wah-wah-wah-wah
Wah
Users browsing this forum: Freeman and 35 guests
